How do you change the default local administrator-password "nt123" on the win7-x64-image?
Best Regards
Change local administrator password
Re: Change local administrator password
I was told that you could extract the win7-template and edit the control-file to change keyboard-layout, but can you also edit the admin-password here?
opsi-package-manager -x /var/lib/opsi/repository/win7-x64_4.0.2-1.opsi
If you want to change the localadministrator password:
Go to :
/opt/pcbin/install/win7(-x64)/custom/unattend.xml
and search for nt123 and change the value.
Go to :
