Hi all,
I have a question.
I have a Windows 2008 domain up and running.
Now I'm thinking about implementing OPSI to install and manage client systems (software wise).
So far I can get things running, but I can't get the systems to join the domain (at least not with the unattend.xml).
Can anyone point me in the right direction?
The domain is called jurriens.local.
The user Administrator is a domain admin with the password password.
The xml is attached, and any help is much appreciated.
Thanx in advance.
Guido Jurriens
Join Windows 7 x64 to domain
- unattend.xml
- unattend.xml
- (14.68 KiB) 123-mal heruntergeladen
Re: Join Windows 7 x64 to domain
delete <!-- and --> before and after this part:
Regards
<component name="Microsoft-Windows-UnattendedJoin" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Identification>
<Credentials>
<Domain>jurriens</Domain>
<Password>password</Password>
<Username>Administrator</Username>
</Credentials>
<DebugJoin>false</DebugJoin>
<JoinDomain>jurriens</JoinDomain>
<UnsecureJoin>false</UnsecureJoin>
</Identification>
</component>
minidump
minidump
Thank you very much...
I think I've looked to much at the code so I overread it
