Hello OPSI team,
when I try to upgrade from windows 7 to Windows 10 build 1909 it:
1) switches to opsiSetupUser
2) installes files
3) reboots
4) Windows installation
5) logs automatically in as opsiSetupUser (Windows 10)
6) I click no cortana, no error repoert to microsoft, no penwriting, no no no no no until windows starts
7 ) starts opsiclientd_event_starter_asInvoker.exe and hangs there forever
(also the opsi client window doesn't show up on startup under windows 10 anymore)
8) When I restart it still logs automatically into windows 10 as opsiSetupUser and the opsiclientd_event_starter_asInvoker.exe appears
according to the OPSI Config Editor the Installation is still running
it happens on every PC in my company so I can't roll it out yet without having a lot of work to do.
The Microfoft tools works better but compromise the whole bandwidth with several win 10 downloads
I would prefer the OPSI package but how to make it work till the end?
Windows 7 upgrade to windows 10
Re: Windows 7 upgrade to windows 10
here is the logfile
https://www.file-upload.net/download-13 ... e.txt.html
When I stop the windows10-upgrade setup and set the opsi-client agent setup, everything seems fine. The last login as opsiSetupUser with the invoker
seems a bit useless to me. Better would be to just end the installation and start the opsi-client agent setup.
