Uefi installation clients
Hi all
I have a question and what could be wrong here. If i trie to pxe boot a non uefi machine it auto install its os that i selected in opsi admin gui for that machine. So ne needt to select what image you want.
If i do the same with an uefi machine i still need to select what os i want and enter machine name and stuff.
I activated the uefi module and i selected the machine for uefi boot. What could be wrong here?
I use elilo
I use elilo
Re: Uefi installation clients
usually when you have to enter informations like machine name and stuff this means the DHCP didn't provide the necessary information.
Do you have a diferent group setting in your DHCP for UEFI Clients?
Regards
Regards
No i dont have a different config for this. All the same subnet for normal pxe and uefi pxe.
- SisterOfMercy
Have you changed elilo.conf back to its defaults?
Hi @sisterofmercy
What should be the defaults?
- SisterOfMercy
I guess something like
But come to think of it, even a changed config file would not produce the results you get. I'm not sure if elilo does the same stuff with pipes as the legacy stuff.
default=local
label=local
root=/dev/sda1
The things that i change is the language. I can not understand what the problem is?
Please provide the complete bootimage.logckruijntjens hat geschrieben: If i do the same with an uefi machine i still need to select what os i want and enter machine name and stuff.
mail info<at>uib.de
regards
bardo wolf
OPSICONF 2024
https://opsi.org/en/opsiconf/
Basisworkshop Mainz :
17. - 20. 06. 2024
Where can i find this log?
https://download.uib.de/opsi4.1/documen ... -v4.1.html
/var/log/opsi/bootimage
In this directory are the log-files of the opsi-linux-bootimage. These log files will be named log.<IP-number>.
OPSICONF 2024
17. - 20. 06. 2024
