I opened a post for that in French community but no answer at this time. I run under version 4.1 of OPSI.
I have a problem very close, in fact i can see all directories in shares but no files at all, and they are present in command line. I try to changes ownership, permissions without any success.
Do you have any idea about that ?
Thanks a lot,
Regards,
Guillaume
No Client Agent Files.
Re: No Client Agent Files.
please do not reply on post this old as they are probably about a different problem even though symptons may be the same.
What OS & Samba version is your server running?
How are you trying to access the share?
If it is from a Windows 10 computer: what version?
Kind regards
Kind regards
Hi Niko,
Would you like me creating a new post for that, before answering ?
Regards,
Guillaume
Regards,
Guillaume
Hi Guillaume,
I've split the topic and we can continue here
kind regards
kind regards
I encountered the same. I added ntlm auth = yes in smb.conf. I was able to access the folders but after I re-install OPSI packages, I can't access again. I downloaded client agent (.opsi) file from repo and install it manually but I am having permission problems.
Thanks.
Thanks.
finally I changed my method and I reinstalled the machine with OVF template, and everything work very well now. Buy the way, the most important for me is to have a proof of concept and the ability to deploy applications quickly, control what users install on their computers, and in the next futur deploy OS and Drivers for all my computers.
Thank you,
Guillaume
Thank you,
Guillaume
