OPSI and systemd
pav5088
OPSI and systemd
Beitrag von pav5088 »
I'm using a non-systemd distro here. The release notes tell me systemd is not officially supported in OPSI 4.1. To unofficially get 4.1 working is it possible for me to create some kind of unsupported 4.0-4.1 hybrid system? I'd be interested in this even if this would be significantly non-trivial. If so, could you give some idea of what I would need to do?
Re: OPSI and systemd
small disclaimer first: non-systemd-distros aren't officially supported since 4.1. So any changes are made on your own risk.
You could use the init scripts from opsi 4.0 and re-package the components that make use of systemd to use these scripts instead.
Kind regards
