Problems with PnPutil.exe in OPSISctipt
Tigger
Beitrag von Tigger »
Hello community!
I have written an OPSI script to install or update the drivers. When testing it with wininst.exe as an administrator, it works fine.
If I start the script with the Opsi Agent then opens the CMD window, it also looks like everything would work, but unfortunately it does not work.
;Standard Text, shown during installation
Message = Bitte warten, das Produkt wird installiert
;Set Loglevel
setLogLevel = 6
;Stop when errors
ExitOnError = false
;Syntax Fehler are shown in a seperate window
ScriptErrorMessages = on
;Do not use Single-Step Mode
TraceMode = off
;No winst-window in foreground while batchmode
StayOnTop = false
requiredWinstVersion >= "4.11.4"
DefVar $ProductId$
DefVar $ProductName$
DefVar $MinimumSpace$
DefVar $ExitCode$
DefVar $LogDir$
DefVar $InstallDir32$
DefVar $InstallDir64$
Set $ProductId$       = "Driver Install"
DefVar $BasePath$
DefVar $SysInfoManufacturer$
DefVar $SysInfoModel
DefVar $DriversPathbyAudit$
DefVar $DriversPathpreferred$
DefVar $pnputim$
set $pnputim$ = "%ScriptPath%\PnPutil.exe"
set $BasePath$ = "%ScriptDrive%\win81-x64\drivers\drivers"
set $SysInfoManufacturer$ = getValue("sysinfo.Manufacturer", getHWBiosInfoMap)
set $SysInfoModel = getValue("sysinfo.Product Name", getHWBiosInfoMap)
;set $SysInfoManufacturer$ = "Intel corporation" ;zu testzwecken enablen und anpassen
;set $SysInfoModel = "NUC6i3SYB"  ;zu testzwecken enablen und anpassen
set $DriversPathbyAudit$ = $BasePath$  + "\additional\byAudit\" + $SysInfoManufacturer$ + "\" + $SysInfoModel
set $DriversPathpreferred$ = $BasePath$  + "\preferred"
DosBatch_DriversUpdate
[DosBatch_DriversUpdate]
@echo off
for /R "$DriversPathbyAudit$" %%i in (*.inf) do (
                     echo Treiberupdate fuer "%%i"
                     "$pnputim$" -i -a "%%i"
for /R "$DriversPathbyAudit$" %%i in (*.cmd) do (
                     echo Install fuer "%%i"
                     call "%%i"
for /R "$DriversPathpreferred$" %%i in (*.inf) do (
for /R "$DriversPathpreferred$" %%i in (*.cmd) do (
                     call "%%i"
The tool PnPutil.exe is included in the OPSI directory. It is also called. It is not any different if I start the tool from the hard disk of the installed OS.
In this context, I have one more question. How can the script determine which OPSI OS package has been installed. Background of the question is that I can also automatically lay down the directory of the OS. At the moment this is hardcoded
And yes the %ScriptDrive% is working.
Greetings Alexander Koch
Zuletzt geändert von Tigger am 23 Aug 2018, 15:06, insgesamt 4-mal geändert.
Re: Treiber Installieren oder Updaten
Tigger hat geschrieben:
%ScriptDrive%?? Does that exist? That's the thing I was looking for, for my own driver update script. My version uses DPINst.exe
Great stuff, especially that version 2.10, which has been released like, three times. So there is 2.10 from the Windows DDK, 2.10 from the Windows-something-else and the 2.10 from even another Windows-thing-a-me-bob. Fantastic! Why even use version numbers if you're keeping it the same. (bunch of wankers)
I was going to say something about %ScriptDrive% but I seemed to have missed that in the manual. The thing I can say: your ProductId might not be valid.
Template says:
;$ProductId$ should be the name of the product in opsi
Tigger
Re: Driver Install or update
Hello SisterOfMercy,
Yes still exists and working
