acpi_walk_namespace failed
bobzbobz
Beitrag von bobzbobz »
Hello
We are running into a problem when trying to PXE-boot.
This error is shown:
https://www.dropbox.com/s/v79v595mlyrv7 ... 4.jpg?dl=0
Re: acpi_walk_namespace failed
How much memory does this computer have?
Otherwise, maybe a bios update may help. Tried changing UEFI/legacy mode to see if that helps?
bobzbobz
The problem occurs on all of our clients (different hardware).
We have tried "reinstalling" boot-image and also with the newest "test-boot-image", but nothing seems to work.
which version of the bootimage is installed?
It's kind of unexpected to break on a larger amount of clients
Do you have any opsi-linux-bootimage.append parameters active?
Reagrds
bobzbobz
Hello
opsi-linux-bootimage ver. 20200506-1
We dont have any .append parameters active.
bobzbobz
Do you have a download mirror for 20200416?
Then we can test if the error also appears there.
bobzbobz hat geschrieben:Do you have a download mirror for 20200416?
I don't have one for the packages, but there's always the boot cds: https://download.uib.de/opsi4.1/stable/boot-cd/
bobzbobz
The 20200506-1 image works if I specifically chose x64-bootimage.
in this case you shoudl use the arhcitecure property in updated windows products
through this you can select the bootimage architecure.
regards
mathias
