Problem with installation
I am trying to install opsi 3.4 on my debian server but I am getting this error all the time:
Traceback:
line 1447 in '<module>' in file '/usr/bin/opsi-admin'
line 434 in 'exit' in file '/usr/bin/opsi-admin'
==>>> Failed to execute 'method createServer server_name domain.cz': Method 'createServer' is not valid
ERROR: Failed to execute 'method createServer server_name domain.cz': Method 'createServer' is not valid
dpkg: error processing opsi-depotserver (--configure):
subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
opsi-depotserver
I tried to look into /usr/bin/opsi-admin and there is no method createServer.
Do you have any idea, what is wrong?
Thank you for your answers.
Best regards,
Pavel
- j.schneider
- uib-Team
Re: Problem with installation
opsi-admin -d -l9 method createServer server_name domain.cz
OS reports 'ovss.domain.cz' as default domain
Using default domain 'ovss.domain.cz'
Skipping local authorization
arg[0]: method
arg[1]: createServer
arg[2]: ovss155
arg[3]: ovss.domain.cz
Execute: method createServer ovss155 ovss.domain.cz
parseCmdline(): char 'm', quote: None, pipe: False, cur: 0, params: []
parseCmdline(): char 'e', quote: None, pipe: False, cur: 0, params: ['m']
parseCmdline(): char 't', quote: None, pipe: False, cur: 0, params: ['me']
parseCmdline(): char 'h', quote: None, pipe: False, cur: 0, params: ['met']
parseCmdline(): char 'o', quote: None, pipe: False, cur: 0, params: ['meth']
parseCmdline(): char 'd', quote: None, pipe: False, cur: 0, params: ['metho']
parseCmdline(): char ' ', quote: None, pipe: False, cur: 0, params: ['method']
parseCmdline(): char 'c', quote: None, pipe: False, cur: 1, params: ['method']
parseCmdline(): char 'r', quote: None, pipe: False, cur: 1, params: ['method', 'c']
parseCmdline(): char 'e', quote: None, pipe: False, cur: 1, params: ['method', 'cr']
parseCmdline(): char 'a', quote: None, pipe: False, cur: 1, params: ['method', 'cre']
parseCmdline(): char 't', quote: None, pipe: False, cur: 1, params: ['method', 'crea']
parseCmdline(): char 'e', quote: None, pipe: False, cur: 1, params: ['method', 'creat']
parseCmdline(): char 'S', quote: None, pipe: False, cur: 1, params: ['method', 'create']
parseCmdline(): char 'e', quote: None, pipe: False, cur: 1, params: ['method', 'createS']
parseCmdline(): char 'r', quote: None, pipe: False, cur: 1, params: ['method', 'createSe']
parseCmdline(): char 'v', quote: None, pipe: False, cur: 1, params: ['method', 'createSer']
parseCmdline(): char 'e', quote: None, pipe: False, cur: 1, params: ['method', 'createServ']
parseCmdline(): char 'r', quote: None, pipe: False, cur: 1, params: ['method', 'createServe']
parseCmdline(): char ' ', quote: None, pipe: False, cur: 1, params: ['method', 'createServer']
parseCmdline(): char 'o', quote: None, pipe: False, cur: 2, params: ['method', 'createServer']
parseCmdline(): char 'v', quote: None, pipe: False, cur: 2, params: ['method', 'createServer', 'o']
parseCmdline(): char 's', quote: None, pipe: False, cur: 2, params: ['method', 'createServer', 'ov']
parseCmdline(): char 's', quote: None, pipe: False, cur: 2, params: ['method', 'createServer', 'ovs']
parseCmdline(): char '1', quote: None, pipe: False, cur: 2, params: ['method', 'createServer', 'ovss']
parseCmdline(): char '5', quote: None, pipe: False, cur: 2, params: ['method', 'createServer', 'ovss1']
parseCmdline(): char '5', quote: None, pipe: False, cur: 2, params: ['method', 'createServer', 'ovss15']
parseCmdline(): char ' ', quote: None, pipe: False, cur: 2, params: ['method', 'createServer', 'ovss155']
parseCmdline(): char 'o', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155']
parseCmdline(): char 'v', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'o']
parseCmdline(): char 's', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ov']
parseCmdline(): char 's', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovs']
parseCmdline(): char '.', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovss']
parseCmdline(): char 'd', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovss.']
parseCmdline(): char 'o', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovss.d']
parseCmdline(): char 'm', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovss.do']
parseCmdline(): char 'a', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovss.dom']
parseCmdline(): char 'i', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovss.doma']
parseCmdline(): char 'n', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovss.domai']
parseCmdline(): char '.', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovss.domain']
parseCmdline(): char 'c', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovss.domain.']
parseCmdline(): char 'z', quote: None, pipe: False, cur: 3, params: ['method', 'createServer', 'ovss155', 'ovss.domain.c']
cmdline: method createServer ovss155 ovss.domain.cz
paramPos: -1, currentParam: ovss.domain.cz, params: ['method', 'createServer', 'ovss155', 'ovss.domain.cz']
Traceback:
line 627 in 'execute' in file '/usr/bin/opsi-admin'
line 1035 in 'execute' in file '/usr/bin/opsi-admin'
==>>> Method 'createServer' is not valid
Failed to execute 'method createServer ovss155 ovss.domain.cz': Method 'createServer' is not valid
Traceback:
==>>> Failed to execute 'method createServer ovss155 ovss.domain.cz': Method 'createServer' is not valid
ERROR: Failed to execute 'method createServer ovss155 ovss.domain.cz': Method 'createServer' is not valid
root@ovss155:/var/lib/opsi# nslookup 10.0.16.155
Server: 10.0.16.130
Address: 10.0.16.130#53
155.16.0.10.in-addr.arpa name = ovss155.ovss.domain.cz.
root@ovss155:/var/lib/opsi# getent hosts `hostname -f`
10.0.16.155 ovss155.ovss.domain.cz ovss155
- j.schneider
- uib-Team
please post output of:
opsi-admin -d -l9 method getPossibleMethods_listOfHashes
arg[0]: method
arg[1]: getPossibleMethods_listOfHashes
Execute: method getPossibleMethods_listOfHashes
parseCmdline(): char 'g', quote: None, pipe: False, cur: 1, params: ['method']
parseCmdline(): char 'e', quote: None, pipe: False, cur: 1, params: ['method', 'g']
parseCmdline(): char 't', quote: None, pipe: False, cur: 1, params: ['method', 'ge']
parseCmdline(): char 'P', quote: None, pipe: False, cur: 1, params: ['method', 'get']
parseCmdline(): char 'o', quote: None, pipe: False, cur: 1, params: ['method', 'getP']
parseCmdline(): char 's', quote: None, pipe: False, cur: 1, params: ['method', 'getPo']
parseCmdline(): char 's', quote: None, pipe: False, cur: 1, params: ['method', 'getPos']
parseCmdline(): char 'i', quote: None, pipe: False, cur: 1, params: ['method', 'getPoss']
parseCmdline(): char 'b', quote: None, pipe: False, cur: 1, params: ['method', 'getPossi']
parseCmdline(): char 'l', quote: None, pipe: False, cur: 1, params: ['method', 'getPossib']
parseCmdline(): char 'e', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibl']
parseCmdline(): char 'M', quote: None, pipe: False, cur: 1, params: ['method', 'getPossible']
parseCmdline(): char 'e', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleM']
parseCmdline(): char 't', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMe']
parseCmdline(): char 'h', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMet']
parseCmdline(): char 'o', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMeth']
parseCmdline(): char 'd', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMetho']
parseCmdline(): char 's', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethod']
parseCmdline(): char '_', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods']
parseCmdline(): char 'l', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_']
parseCmdline(): char 'i', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_l']
parseCmdline(): char 's', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_li']
parseCmdline(): char 't', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_lis']
parseCmdline(): char 'O', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_list']
parseCmdline(): char 'f', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_listO']
parseCmdline(): char 'H', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_listOf']
parseCmdline(): char 'a', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_listOfH']
parseCmdline(): char 's', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_listOfHa']
parseCmdline(): char 'h', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_listOfHas']
parseCmdline(): char 'e', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_listOfHash']
parseCmdline(): char 's', quote: None, pipe: False, cur: 1, params: ['method', 'getPossibleMethods_listOfHashe']
cmdline: method getPossibleMethods_listOfHashes
paramPos: -1, currentParam: getPossibleMethods_listOfHashes, params: ['method', 'getPossibleMethods_listOfHashes']
Executing: getPossibleMethods_listOfHashes()
Took 0.000s to process getPossibleMethods_listOfHashes()
[{'color': '\x1b[0;32;40m', 'text': '[ '}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "productActionRequests",'}, {'color': '\x1b[0;32;40m', 'text': ' "*hostId",'}, {'color': '\x1b[0;32;40m', 'text': ' "*options"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "adjustProductActionRequests"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "productStates",'}, {'color': '\x1b[0;32;40m', 'text': ' "*objectIds",'}, {'color': '\x1b[0;32;40m', 'text': ' "*options"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "adjustProductStates"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "*depotIds"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "areDepotsSynchronous"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "authenticated"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "checkForErrors"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "createOpsiBase"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "exit"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getBackendInfos_listOfHashes"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "path"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getDiskSpaceUsage"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "*hostId"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getDomain"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getHostRSAPublicKey"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "hostId"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getHostname"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "hostId"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getIpAddress"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "filename"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getMD5Sum"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "*lang"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getOpsiHWAuditConf"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getOpsiInformation_hash"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getPcpatchRSAPrivateKey"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getPossibleMethods_listOfHashes"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getPossibleProductActionRequests_list"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getPossibleProductInstallationStatus_list"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getPossibleRequirementTypes_list"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "productId",'}, {'color': '\x1b[0;32;40m', 'text': ' "depotId"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "getProductType"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "filename",'}, {'color': '\x1b[0;32;40m', 'text': ' "*force",'}, {'color': '\x1b[0;32;40m', 'text': ' "*defaultProperties",'}, {'color': '\x1b[0;32;40m', 'text': ' "*tempDir"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "installPackage"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "oldfile",'}, {'color': '\x1b[0;32;40m', 'text': ' "deltafile",'}, {'color': '\x1b[0;32;40m', 'text': ' "newfile"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "librsyncPatchFile"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "filename"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "librsyncSignature"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "hostId",'}, {'color': '\x1b[0;32;40m', 'text': ' "*args"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "setPXEBootConfiguration"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "productId",'}, {'color': '\x1b[0;32;40m', 'text': ' "*force",'}, {'color': '\x1b[0;32;40m', 'text': ' "*deleteFiles"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "uninstallPackage"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ' "hostId"'}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "unsetPXEBootConfiguration"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "userIsAdmin"'}, {'color': '\x1b[0;32;40m', 'text': ' },'}, {'color': '\x1b[0;32;40m', 'text': ' { '}, {'color': '\x1b[0;32;40m', 'text': ' "params" : '}, {'color': '\x1b[0;32;40m', 'text': ' [ '}, {'color': '\x1b[0;32;40m', 'text': ''}, {'color': '\x1b[0;32;40m', 'text': ' ],'}, {'color': '\x1b[0;32;40m', 'text': ' "name" : "userIsHost"'}, {'color': '\x1b[0;32;40m', 'text': ' }'}, {'color': '\x1b[0;32;40m', 'text': ']'}]
"params" :
"*hostId",
"*options"
"params" :
"productStates",
"*objectIds",
"*options"
"params" :
"*depotIds"
"params" :
"params" :
"params" :
"params" :
"name" : "exit"
"params" :
"params" :
"path"
"params" :
"*hostId"
"params" :
"params" :
"hostId"
"params" :
"hostId"
"params" :
"filename"
"params" :
"*lang"
"params" :
"params" :
"params" :
"params" :
"params" :
"params" :
"params" :
"productId",
"depotId"
"params" :
"filename",
"*force",
"*tempDir"
"params" :
"oldfile",
"deltafile",
"newfile"
"params" :
"filename"
"params" :
"hostId",
"*args"
"params" :
"productId",
"*force",
"*deleteFiles"
"params" :
"hostId"
"params" :
"params" :
- j.schneider
- uib-Team
Seems to be a configuration issue.
Please try to purge all opsi packages and reinstall.
apt-get remove --purge python-opsi opsi-depotserver
apt-get install opsi-depotserver
