[resolved] SSD disk M.2 PCIe NVMe not found
bourhis
Beitrag von bourhis »
I can't install Windows on a new laptop Dell Precision 7730 with a M.2 PCIe NVMe SSD Disk.
The error message is "no harddisk found".
What can I do ?
Best regards.
Zuletzt geändert von bourhis am 13 Nov 2019, 10:18, insgesamt 1-mal geändert.
Re: SSD disk M.2 PCIe NVMe not found
When do you get this error? During OPSI-Bootimage or when WinPE is already running?
bourhis
During OPSI Boot Image
Well Dells are sometimes very special.
Check of Intel VMD is deactivated, also the checkboxes of VMD devices.
SATA mode should bei AHCI.
Also check in Uefi: general Options -> advanced boot options -> Attempt legacy boot.
Regards
bourhis
That's works !
Thanks.
Re: [resolved] SSD disk M.2 PCIe NVMe not found
which point exactly did work?
Regards
bourhis
The Opsi-boot-image find the disk after the Bios adjustements : "AHCI mode" and "Attempt legacy boot"
Then, the entire installation process was completed normally.
