Hello,
Sometimes when I manually create a new client I forgot the check 'EUFI boot' (I have the EUFI license).
Is there a way to make EUFI boot the default?
						Make EUFI boot the default
Re: Make EUFI boot the default
Set the config (not config state!) clientconfig.dhcpd.filename to linux/pxelinux.cfg/elilo.efi.
import OPSIRe: Make EUFI boot the default
you can do this via the config editor, server configuration/host parameters/clientconfig/clientconfig.dhpcd.filename
in order to work correctly, use the current configed version.
