Upgrade from ubuntu 12 to ubuntu 16 and opsi 4.0.5 to 4.0.7
Radek
Beitrag von Radek »
I have beed trying to upgrade from ubuntu12 to ubuntu16 because I need newer version of opsi. I have mannaged to upgrade to ubuntu14 and opsi 4.0.7 with no problem, but if I upgrade to ubuntu 16 things start to get wierd... After launching configed.jnpl I a get error message that I haven't beent able to resolve by myselfe. https://imgur.com/a/7mIQO . Do you have any ideas what should I try ?
Thank you
Re: Upgrade from ubuntu 12 to ubuntu 16 and opsi 4.0.5 to 4.0.7
Hi Radek,
did you also update your opsi packages after updating to Ubuntu 16.04?
Cheers
Radek
Beitrag von Radek »
I have tried following :
upgrade to ubuntu14 then opsi to 4.0.7 then to ubuntu 16
upgrade to ubuntu16 then opsi to 4.0.7
upgrade to ubuntu14 then opsi to 4.0.7 and that is where I am right now, it is working.
Don't know how but it is... If you have any ideas what should I try let me know, I will be more than happy to upgrade to ubuntu 16 with working opsi.
Thank you.
if you update to 16.04 please see getting started
Also, run the usual commands
opsi-set-rights
Cheers
Radek hat geschrieben:After launching configed.jnpl I a get error message that I haven't beent able to resolve by myselfe. https://imgur.com/a/7mIQO . Do you have any ideas what should I try ?
This could be a problem with TLS between opsi-configed and opsiconfd.
The currently suggested workaround is to force the usage of TLSv1 (the configed localboot product has a property to do so) or if you already have it installed you can also alter the start command to be like javaw -Dhttps.protocols=TLSv1.
To get access to configed you can use the configed-setup.exe.
Sorry for the inconvenience. We are working on solving this permanently.
Kind regards
Radek
Beitrag von Radek »
Thank you for your time and suggestions. I am going to stick to opsi on ubuntu 14 for now, I dont have more time to spend on this.
Kind regards
Radek
ueluekmen
Beitrag von ueluekmen »
this is possible, but notice, that you cannot start opsi-configed on Ubuntu 14.04 directly, because 14.04 has Java 7. opsi-Configed needs Java 8 to run. If you don't start opsi-configed directly on your server, than you can stay on 14.04 until its end of support.
