WinPE boot for Windows 7 stuck on splash screen
ttblum
Beitrag von ttblum »
Hello,
I'm trying out opsi, and I'm trying to deploy an unattended Windows 7 install.
I generated a WinPE image using the 'Product configuration-->opsi-winpe-->once' method. I copied the Win7Pro64bit DVD ISO to /var/lib/opsi/depot/win7-x64/installfiles, ran 'opsi-setup --set-rights' on that directory and ran 'opsi-set-rights' .
When I tried deploying this to a VirtualBox machine it only shows the Windows 10 WinPE splash screen. One of my CPU cores goes to 100% indefinitely, and it gets stuck there:
There is no spinning circle, though, only the Windows logo.
Has anyone else had this? I'll deploy this to physical hardware next to see if there's a difference.
Re: WinPE boot for Windows 7 stuck on splash screen
No.
which version of virtual box yua are running?
Which OS did you choose for creating the machine (win7 or win10)?
I'll recommend win10
regards,
ttblum
Thanks, that worked, I changed the VirtualBox machine to Windows 10 and it booted and installed Windows OK.
I was getting:
'o:\win7-x64\installfiles\setup.exe' is not a recognized as an internal or external command, operable program or batch file
but I realized that I had copied the ISO file into /var/lib/opsi/depot/win7-x64/installfiles, not the actual contents of the DVD.
