unser System:
Opsi 4.0.7.16
auf Univention Corporate Server v4.x (aktuell)
Unser opsiconfi-Editor (Das Java- Admin- Interface) ist nicht mehr erreichbar. Habe etwas Fehlersuche betrieben, der Port 4447 ist geschlossen, der Dienst nicht gestartet. In Windows-Manier auch mal den SErver neu gestartet, aber keine Änderung.
Das sind die letzten Einträge im opsiconfd.log:
= opsi configuration service starting =
================================================================== (Logger.py|847)
[5] [Oct 28 00:03:54] Creating pid file u'/var/run/opsiconfd/opsiconfd.pid' (opsiconfd.py|653)
[5] [Oct 28 00:03:54] Starting opsiconfd main thread (opsiconfd.py|469)
[5] [Oct 28 00:03:54] Opening socket /var/run/opsiconfd/opsiconfd.socket for interprocess communication. (opsiconfd.py|438)
[5] [Oct 28 00:03:54] Added static content '/' which points to directory '/usr/share/opsiconfd/static' (opsiconfd.py|291)
[5] [Oct 28 00:03:54] Running on depot server 'opsi.evs-nb.de', exporting repository directory (opsiconfd.py|308)
[5] [Oct 28 00:03:54] Running on depot server 'opsi.evs-nb.de', exporting depot directory (opsiconfd.py|321)
[5] [Oct 28 00:03:54] Added webdav content 'repository' which points to directory '/var/lib/opsi/repository' () (opsiconfd.py|354)
[5] [Oct 28 00:03:54] Added webdav content 'depot' which points to directory '/var/lib/opsi/depot' () (opsiconfd.py|354)
[5] [Oct 28 00:03:54] Added webdav content 'configed' which points to directory '/usr/lib/configed' (u'noauth',) (opsiconfd.py|354)
[5] [Oct 28 00:03:54] Accepting HTTPS requests on 0.0.0.0:4447 (opsiconfd.py|407)
[5] [Oct 28 00:03:54] Publishing opsiconfd over zeroconf as 'opsi configuration daemon' on '4447' (opsiconfd.py|421)
[3] [Oct 28 00:03:54] Failed to publish opsiconfd over zeroconf: org.freedesktop.DBus.Error.FileNotFound: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory (opsiconfd.py|426)
[5] [Oct 30 09:43:23] Stopping opsiconfd main thread (opsiconfd.py|180)
[5] [Oct 30 09:43:23] Deleting all sessions (Session.py|231)
[5] [Oct 30 09:43:23] Uptime: 2 days, 9:39:31.367183 (opsiconfd.py|500)
[5] [Oct 30 09:43:23] Statistics: (opsiconfd.py|502)
[5] [Oct 30 09:43:23] Methodname Callcount Average processing duration (opsiconfd.py|503)
[5] [Oct 30 09:43:23] accessControl_authenticated 1 0.000s (opsiconfd.py|507)
[5] [Oct 30 09:43:23] backend_getInterface 1 0.013s (opsiconfd.py|507)
[5] [Oct 30 09:43:23] backend_info 2 0.001s (opsiconfd.py|507)
[5] [Oct 30 09:43:23] backend_setOptions 2 0.001s (opsiconfd.py|507)
[5] [Oct 30 09:43:23] configState_getObjects 2 0.142s (opsiconfd.py|507)
[5] [Oct 30 09:43:23] dispatcher_getConfig 1 0.001s (opsiconfd.py|507)
[5] [Oct 30 09:43:23] log_write 1 0.011s (opsiconfd.py|507)
[5] [Oct 30 09:43:23] productOnClient_getObjects 1 0.051s (opsiconfd.py|507)
[5] [Oct 30 09:43:23] Opsiconfd main thread exiting... (opsiconfd.py|494)
Nov 20 10:09:55 opsi opsiconfd[814]: chown: ungültiger Benutzer: „opsiconfd“
Nov 20 10:09:55 opsi opsiconfd[814]: chown: ungültiger Benutzer: „opsiconfd:opsiadmin“
Nov 20 10:09:55 opsi opsiconfd[814]: Kein Passworteintrag für Benutzer »opsiconfd«
Was könnte denn da passiert sein?
Danke!
/KNEBB
