Nachträglich .inf Treiber installieren
jnko
Beitrag von jnko »
Ich muss auf Clients (Win10) nachträglich einen .INF - Treiber installieren und stoße dabei leider auf Probleme.
WinBatch_InstallInfDriver /Sysnative /RunElevated
[WinBatch_InstallInfDriver]
RUNDLL32.EXE SETUPAPI.DLL,InstallHinfSection DefaultInstall 132 %ScriptPath%\RNDIS.inf
wird quittiert mit
[5] [Nov 01 14:44:41:991] Execution of WinBatch_InstallInfDriver
[6] [Nov 01 14:44:41:994]   Call "RUNDLL32.EXE SETUPAPI.DLL,InstallHinfSection DefaultInstall 132 C:\TEMP\mindusb-rndis-driver\RNDIS.inf"
[6] [Nov 01 14:44:41:997]      Waiting until the called process is finished
[6] [Nov 01 14:44:42:000]   Start process elevated
[3] [Nov 01 14:44:42:006]   RUNDLL32.EXE SETUPAPI.DLL,InstallHinfSection DefaultInstall 132 C:\TEMP\mindusb-rndis-driver\RNDIS.inf .... CreateProcessAsUser Error 1314 (A required privilege is not held by the client.\r\n)
[3] [Nov 01 14:44:42:009]   Error: RUNDLL32.EXE SETUPAPI.DLL,InstallHinfSection DefaultInstall 132 C:\TEMP\mindusb-rndis-driver\RNDIS.inf .... CreateProcessAsUser Error 1314 (A required privilege is not held by the client.\r\n)
Also keine ausreichenden Rechte, oder genauer UAC möchte das nicht.
Hat jemand eine Idee wie man das hinbekommen könnte?
BTW: das ganze per pnputil.exe führt zu gleichem Fehler.
Re: Nachträglich .inf Treiber installieren
DPInst might be an alternative. The great thing about DPInst is that there are different versions all with the same version number, 2.1. Which is just fucking great.
https://technet.microsoft.com/en-us/ff544842(v=vs.96)
Of course microsoft removed this from newer versions of the windows disaster kit:
https://docs.microsoft.com/en-us/window ... guidelines
jnko
Beitrag von jnko »
SisterOfMercy hat geschrieben: Of course microsoft removed this from newer versions of the windows disaster kit:
Thanks.! Useless to mention that I use Win10.... Does any older (Win8) version of DPInst still works in Win10?
Or any other idea?
jnko hat geschrieben:Thanks.! Useless to mention that I use Win10.... Does any older (Win8) version of DPInst still works in Win10?
I think it still works. They just don't include it anymore in the kit. So you should get a previous version of it somewhere.
