ii opsi-atftp 0.7.dfsg-7 amd64 advanced TFTP client
ii opsi-atftpd 0.7.dfsg-7 amd64 advanced TFTP server - opsi version with pcre, fifo and max-blksize patches
ii opsi-configed 4.0.7.5.22-2 all OPSI config editor
ii opsi-depotserver 4.0.7.3-1 all opsi depotserver configuration package
ii opsi-linux-bootimage 20170720-1 amd64 opsi bootimage for netboot tasks.
ii opsi-nagios-plugins 4.0.7.3-1 all opsi nagios plugins
ii opsi-utils 4.0.7.17-2 all utilites for working with opsi.
ii opsiconfd 4.0.7.13-1 all opsi configuration service
ii opsipxeconfd 4.0.7.8-3 all opsi pxe configuration daemon
ii python-opsi 4.0.7.45-3 all opsi python library
und jetzt starten die Dienste nicht mehr. Weder opsiconfd, noch opsipxeconfd usw...
Der Ooutput sieht folgender maßen aus:
opsiserver1:~ # /etc/init.d/opsiconfd start
Starting opsi config service..Traceback (most recent call last):
File "/usr/bin/opsiconfd", line 12, in <module>
from opsiconfd.opsiconfd import main
File "/usr/lib/python2.7/dist-packages/opsiconfd/opsiconfd.py", line 53, in <module>
from twisted.internet import epollreactor
File "/usr/lib/python2.7/dist-packages/twisted/internet/epollreactor.py", line 24, in <module>
from twisted.internet import posixbase
File "/usr/lib/python2.7/dist-packages/twisted/internet/posixbase.py", line 24, in <module>
from twisted.internet import error, udp, tcp
File "/usr/lib/python2.7/dist-packages/twisted/internet/tcp.py", line 29, in <module>
from twisted.internet._newtls import (
File "/usr/lib/python2.7/dist-packages/twisted/internet/_newtls.py", line 21, in <module>
from twisted.protocols.tls import TLSMemoryBIOFactory, TLSMemoryBIOProtocol
File "/usr/lib/python2.7/dist-packages/twisted/protocols/tls.py", line 41, in <module>
from OpenSSL.SSL import Error, ZeroReturnError, WantReadError
File "/usr/lib/python2.7/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import rand, crypto, SSL
File "/usr/lib/python2.7/dist-packages/OpenSSL/rand.py", line 11, in <module>
from OpenSSL._util import (
File "/usr/lib/python2.7/dist-packages/OpenSSL/_util.py", line 4, in <module>
binding = Binding()
File "/usr/lib/python2.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py", line 89, in __init__
self._ensure_ffi_initialized()
File "/usr/lib/python2.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py", line 113, in _ensure_ffi_initialized
libraries=libraries,
File "/usr/lib/python2.7/dist-packages/cryptography/hazmat/bindings/utils.py", line 80, in build_ffi
extra_link_args=extra_link_args,
File "/usr/lib/python2.7/dist-packages/cffi/api.py", line 340, in verify
lib = self.verifier.load_library()
File "/usr/lib/python2.7/dist-packages/cffi/verifier.py", line 75, in load_library
return self._load_library()
File "/usr/lib/python2.7/dist-packages/cffi/verifier.py", line 151, in _load_library
return self._vengine.load_library()
File "/usr/lib/python2.7/dist-packages/cffi/vengine_cpy.py", line 149, in load_library
raise ffiplatform.VerificationError(error)
cffi.ffiplatform.VerificationError: importing '/usr/lib/python2.7/dist-packages/cryptography/_Cryptography_cffi_813c10e0x7adb75f8.x86_64-linux-gnu.so': /usr/lib/python2.7/dist-packages/cryptography/_Cryptography_cffi_813c10e0x7adb75f8.x86_64-linux-gnu.so: symbol SSLv2_client_method, version OPENSSL_1.0.0 not defined in file libssl.so.1.0.0 with link time reference
.......... (failed).
Hat einer ähnliche Probleme oder kennt die Lösung?!
