Vielen Dank! Das Problem mit "opsi-setup --set-rights" wurde durch die Deinstallation des "opsi-winst-test" Pakets behoben
Das heißt, das läuft jetzt schonmal durch.
Der Fehler, mit der bootimage-Meldung allerdings ist nach wie vor präsent
Hier mal die gewünschten Ausgaben:
user@server:~$ locale
LANG=C
LANGUAGE=
LC_CTYPE="C"
LC_NUMERIC="C"
LC_TIME="C"
LC_COLLATE="C"
LC_MONETARY="C"
LC_MESSAGES="C"
LC_PAPER="C"
LC_NAME="C"
LC_ADDRESS="C"
LC_TELEPHONE="C"
LC_MEASUREMENT="C"
LC_IDENTIFICATION="C"
LC_ALL=
user@server:~$ sudo ls -la /var/lib/opsi/depot/opsi-winst-test/test-files/testFiles/nonascii-names
total 20
drwxrws--- 2 opsiconfd pcpatch 4096 Apr 11 2016 .
drwxrws--- 6 opsiconfd pcpatch 4096 Apr 11 2016 ..
-rw-rw---- 1 opsiconfd pcpatch 6 Jan 26 2015 start1 end.txt
-rw-rw---- 1 opsiconfd pcpatch 6 Jan 26 2015 start15-??????????????????????????????-end.txt
-rw-rw---- 1 opsiconfd pcpatch 6 Jan 26 2015 start7-??????????????-end.txt
user@server:~$ ls -la /tftpboot/linux/
total 198988
drwxrwxr-x 3 opsiconfd pcpatch 4096 Sep 22 11:38 .
drwxr-xr-x 3 root root 4096 Nov 19 2013 ..
-rw-rw-r-- 1 opsiconfd pcpatch 12372 Aug 26 12:14 chain.c32
lrwxrwxrwx 1 opsiconfd pcpatch 14 Aug 26 12:14 install -> vmlinuz-driver
lrwxrwxrwx 1 opsiconfd pcpatch 18 Aug 26 12:14 install-x64 -> vmlinuz-x64-driver
lrwxrwxrwx 1 opsiconfd pcpatch 11 Aug 26 12:14 install64 -> install-x64
-rw-rw-r-- 1 opsiconfd pcpatch 137084 Mar 20 2011 memtest86
-rw-rw-r-- 1 opsiconfd pcpatch 150024 Aug 23 2013 memtest86+-5.01
-rw-rw-r-- 1 opsiconfd pcpatch 52272 Aug 26 12:14 menu.c32
-rw-rw-r-- 1 opsiconfd pcpatch 91169458 Aug 26 12:14 miniroot-20160706.bz2
-rw-rw-r-- 1 opsiconfd pcpatch 92014218 Aug 26 12:14 miniroot-x64-20160706.bz2
lrwxrwxrwx 1 opsiconfd pcpatch 25 Aug 26 12:14 miniroot-x64.bz2 -> miniroot-x64-20160706.bz2
lrwxrwxrwx 1 opsiconfd pcpatch 21 Aug 26 12:14 miniroot.bz2 -> miniroot-20160706.bz2
-rw-rw-r-- 1 opsiconfd pcpatch 15710 Aug 26 12:14 pxelinux.0
drwxrwxr-x 2 opsiconfd pcpatch 4096 Sep 22 11:38 pxelinux.cfg
-rw-rw-r-- 1 opsiconfd pcpatch 10185872 Aug 26 12:14 vmlinuz-driver
-rw-rw-r-- 1 opsiconfd pcpatch 9996240 Aug 26 12:14 vmlinuz-x64-driver
... wobei die Datei /var/lib/opsi/depot/opsi-winst-test/test-files/testFiles/nonascii-names ja mitlerweile nicht mehr auf dem system existiert.
edit:
ich hab hier mal den letzten Teil des bootimage (in Zeile 52 steht die Fehlermeldung):
[5] [Feb 20 11:35:41] Using product property to get licensekey (master.py|1202)
[6] [Feb 20 11:35:41] Product license key: (master.py|1210)
[5] [Feb 20 11:35:41] Fetching pcpatch password... (master.py|1214)
[7] [Feb 20 11:35:41] Executing jsonrpc method 'user_getCredentials' on host 10.0.0.13 (JSONRPC.py|104)
[7] [Feb 20 11:35:41] Starting new HTTPS connection (0) to 10.0.0.13:4447 (HTTP.py|574)
[7] [Feb 20 11:35:41] Connection established to: 10.0.0.13 (HTTP.py|587)
[7] [Feb 20 11:35:41] Failed to get peer cert: 'NoneType' object has no attribute 'getpeercert' (HTTP.py|164)
[7] [Feb 20 11:35:41] Closing connection: <httplib.HTTPSConnection instance at 0x8e9c36c> (HTTP.py|502)
[7] [Feb 20 11:35:41] Content-Type: gzip-application/json;charset=utf-8, Content-Encoding: gzip (JSONRPC.py|659)
[7] [Feb 20 11:35:41] Expecting compressed data from server (JSONRPC.py|663)
[6] [Feb 20 11:35:41] Decrypting password... (master.py|1221)
[7] [Feb 20 11:35:41] Executing jsonrpc method 'host_getObjects' on host 10.0.0.13 (JSONRPC.py|104)
[7] [Feb 20 11:35:42] Closing connection: <httplib.HTTPSConnection instance at 0x8eaca8c> (HTTP.py|502)
[7] [Feb 20 11:35:42] Content-Type: gzip-application/json;charset=utf-8, Content-Encoding: gzip (JSONRPC.py|659)
[7] [Feb 20 11:35:42] Expecting compressed data from server (JSONRPC.py|663)
[6] [Feb 20 11:35:42] Mounting 'smb://server/opsi_depot' to '/mnt/opsi' (Repository.py|1143)
[7] [Feb 20 11:35:42] Command 'mount' found at: '/bin/mount' (Posix.py|641)
[6] [Feb 20 11:35:42] Executing: /bin/mount -t cifs -o "iocharset=utf8,domain=server,credentials=/tmp/.cifs-credentials.server" //server/opsi_depot /mnt/opsi (Posix.py|661)
[6] [Feb 20 11:35:42] Using encoding 'UTF-8' (Posix.py|692)
[7] [Feb 20 11:35:42] Exit code: 0 (Posix.py|749)
[5] [Feb 20 11:35:42] Copying action script 'win7-x64/setup.py' from depot to '/tmp/setup.py' (master.py|1314)
[7] [Feb 20 11:35:42] MessageSubject 'copy_overall' created (Message.py|112)
[7] [Feb 20 11:35:42] ProgressSubject 'copy_overall' created (Message.py|238)
[7] [Feb 20 11:35:42] MessageSubject 'copy_current' created (Message.py|112)
[7] [Feb 20 11:35:42] ProgressSubject 'copy_current' created (Message.py|238)
[6] [Feb 20 11:35:42] Copying from 'win7-x64/setup.py' to '/tmp/setup.py' (Repository.py|469)
[7] [Feb 20 11:35:42] Length of binary data to download: 44302 bytes (Repository.py|685)
[7] [Feb 20 11:35:42] Transfer in from <open file u'/mnt/opsi/win7-x64/setup.py', mode 'rb' at 0x8dff910> to <open file u'/tmp/setup.py', mode 'wb' at 0x8dffb78>, dynamic bandwidth False, max bandwidth 0 (Repository.py|338)
[6] [Feb 20 11:35:42] Transfered 43.26 kByte in 0.00 minutes, average speed was 3368.19 kByte/s (Repository.py|370)
[6] [Feb 20 11:35:42] Copy done (Repository.py|552)
[7] [Feb 20 11:35:42] Executing jsonrpc method 'productOnClient_updateObjects' on host 10.0.0.13 (JSONRPC.py|104)
[7] [Feb 20 11:35:42] Starting new HTTPS connection (0) to 10.0.0.13:4447 (HTTP.py|574)
[7] [Feb 20 11:35:42] Connection established to: 10.0.0.13 (HTTP.py|587)
[7] [Feb 20 11:35:42] Failed to get peer cert: 'NoneType' object has no attribute 'getpeercert' (HTTP.py|164)
[7] [Feb 20 11:35:42] Closing connection: <httplib.HTTPSConnection instance at 0x8eb43cc> (HTTP.py|502)
[7] [Feb 20 11:35:44] MessageSubject 'script' created (Message.py|112)
[7] [Feb 20 11:35:44] Executing jsonrpc method 'productOnClient_updateObjects' on host 10.0.0.13 (JSONRPC.py|104)
[7] [Feb 20 11:35:44] Starting new HTTPS connection (0) to 10.0.0.13:4447 (HTTP.py|574)
[7] [Feb 20 11:35:44] Connection established to: 10.0.0.13 (HTTP.py|587)
[7] [Feb 20 11:35:44] Failed to get peer cert: 'NoneType' object has no attribute 'getpeercert' (HTTP.py|164)
[7] [Feb 20 11:35:44] Closing connection: <httplib.HTTPSConnection instance at 0x8eb418c> (HTTP.py|502)
[7] [Feb 20 11:35:44] Content-Type: gzip-application/json;charset=utf-8, Content-Encoding: gzip (JSONRPC.py|659)
[7] [Feb 20 11:35:44] Expecting compressed data from server (JSONRPC.py|663)
[2] [Feb 20 11:35:45] Traceback: (Logger.py|742)
[2] [Feb 20 11:35:45] line 1389 in '<module>' in file '/usr/local/bin/master.py' (Logger.py|742)
[2] [Feb 20 11:35:45] line 21 in '<module>' in file '/tmp/setup.py' (Logger.py|742)
[2] [Feb 20 11:35:45] ==>>> This product requires opsi-linux-bootimage version >= 20140118 (master.py|1437)
[7] [Feb 20 11:35:45] Backend: <OPSI.Backend.JSONRPC.JSONRPCBackend instance at 0x8be9dec> (master.py|1440)
[7] [Feb 20 11:35:45] ProductId: win7-x64 (master.py|1441)
[7] [Feb 20 11:35:45] ClientId: wstest88.firma.de (master.py|1442)
[7] [Feb 20 11:35:45] ProductOnClient: <ProductOnClient clientId 'wstest88.firma.de', productId 'win7-x64', installationStatus 'unknown', actionRequest 'none'> (master.py|1443)
[6] [Feb 20 11:35:45] Updating productOnClient: {'actionProgress': u'', 'actionResult': u'failed', 'clientId': u'wstest88.firma.de', 'modificationTime': None, 'actionRequest': u'none', 'targetConfiguration': None, 'productVersion': None, 'productType': u'NetbootProduct', 'type': u'ProductOnClient', 'lastAction': None, 'packageVersion': None, 'actionSequence': None, 'installationStatus': u'unknown', 'productId': u'win7-x64'} (master.py|1454)
[7] [Feb 20 11:35:45] Executing jsonrpc method 'productOnClient_updateObjects' on host 10.0.0.13 (JSONRPC.py|104)
[7] [Feb 20 11:35:45] Starting new HTTPS connection (0) to 10.0.0.13:4447 (HTTP.py|574)
[7] [Feb 20 11:35:45] Connection established to: 10.0.0.13 (HTTP.py|587)
[7] [Feb 20 11:35:45] Failed to get peer cert: 'NoneType' object has no attribute 'getpeercert' (HTTP.py|164)
[7] [Feb 20 11:35:45] Closing connection: <httplib.HTTPSConnection instance at 0x8eacccc> (HTTP.py|502)
[7] [Feb 20 11:35:45] Content-Type: gzip-application/json;charset=utf-8, Content-Encoding: gzip (JSONRPC.py|659)
[7] [Feb 20 11:35:45] Expecting compressed data from server (JSONRPC.py|663)
[5] [Feb 20 11:35:54] Writing log to service (master.py|1468
