ich habe bereits seit längerem Probleme mit meiner OPSI Installation und bekomme diese einfach nicht in den Griff.
Wenn ich den OPSI-configed starte auf einem Rechner kommt diese Meldung (ebenso beim Aktualisieren der Ansicht)
Feb 08 13:32:40.930 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:32:40.957 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:37:55.709 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:37:56.005 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:37:56.005 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:37:56.297 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:37:56.298 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:37:56.574 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:37:56.575 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:37:56.874 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:37:56.875 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:37:57.138 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:37:57.139 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:37:57.436 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:37:57.437 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:37:57.707 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:37:57.707 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:37:57.978 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:37:57.978 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:37:58.271 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:37:58.273 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:38:25.556 2017 -- Error in setSoftwareInfoPage: java.lang.NullPointerException
Wenn ich mir die Lizenzen anzeigen lassen will kommt folgende Meldung (bis gestern ging das gar nicht, nur direkt auf dem Server)
Feb 08 13:40:34.590 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:40:34.590 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:40:36.920 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:40:36.920 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:40:39.083 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:40:39.084 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:40:41.019 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:40:41.019 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:40:41.769 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:40:41.770 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:42:29.043 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:42:29.044 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:42:30.656 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:42:30.657 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:42:32.725 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:42:32.726 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:42:34.595 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:42:34.596 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Feb 08 13:42:35.366 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Feb 08 13:42:35.366 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
Vielen Dank schon mal für eure Hilfe
Gruss Sascha
