ich versuche seit einigen Stunden, einen OPSI Client auf einem Windows 10 Pro System über das Script "Service_setup.cmd" zu installieren, jedoch scheitert dies kläglich.
Der OPSI Server ist erfolgreich gestartet, Windows 7 Clients, welche bereits OPSI in Betrieb haben, funktionieren.
OPSI-Version: 4.0.7
OPSI-Server: Debian Jessie
Client: Windows 10 Pro 1607
folgendes sagt mein Logfile auf dem Client:
[5] [Jan 31 08:07:42:115] comment: *** Create client ***
[5] [Jan 31 08:07:42:119]
[5] [Jan 31 08:07:42:119] Set $INST_ServiceResult$ = getReturnListFromSection('opsiservicecall_createClient')
[5] [Jan 31 08:07:42:122]
[5] [Jan 31 08:07:42:122] Execution of opsiservicecall_createClient
[6] [Jan 31 08:07:42:122] "method": "host_createOpsiClient"
[3] [Jan 31 08:07:42:122] Error: service not initialized
[3] [Jan 31 08:07:42:122] Error: no connection to service
[6] [Jan 31 08:07:42:122] retrieving strings from getReturnListFromSection [switch to loglevel 7 for debugging]
[7] [Jan 31 08:07:42:122]
[5] [Jan 31 08:07:42:122] EndIf
[5] [Jan 31 08:07:42:122] If
[5] [Jan 31 08:07:42:122] $INST_userIsAdmin$ = "true" <<< result false
[5] [Jan 31 08:07:42:122] not ($INST_userIsAdmin$ = "true") <<< result true
[5] [Jan 31 08:07:42:122] Then
[5] [Jan 31 08:07:42:126]
[5] [Jan 31 08:07:42:126] Set $INST_ServiceResult$ = getReturnListFromSection('opsiservicecall_close_session')
[5] [Jan 31 08:07:42:129]
[5] [Jan 31 08:07:42:129] Execution of opsiservicecall_close_session
[6] [Jan 31 08:07:42:129] "method": "backend_exit"
[3] [Jan 31 08:07:42:129] Error: service not initialized
[3] [Jan 31 08:07:42:129] Error: no connection to service
[6] [Jan 31 08:07:42:129] retrieving strings from getReturnListFromSection [switch to loglevel 7 for debugging]
[7] [Jan 31 08:07:42:129]
[5] [Jan 31 08:07:42:133] comment: after creation use host/key autheticated service
[6] [Jan 31 08:07:42:137] Marked error number 18
[1] [Jan 31 08:07:42:141] LogLevel was 7
[1] [Jan 31 08:07:42:141] LogLevel set to 7
[5] [Jan 31 08:07:42:144]
[5] [Jan 31 08:07:42:144] Execution of opsiservicecall_authenticated
[6] [Jan 31 08:07:42:144] "method": "authenticated"
[6] [Jan 31 08:07:42:149] JSON Bench for backend_info "params":[],"id":1} Start: 08:07:42:144 Time: 00:00:00:005
[3] [Jan 31 08:07:42:149] Error: retrieveJSONObject --- opsi service problem ----> unexpected Result from webservice in retrieveJSONObject, number of lines: 0
[6] [Jan 31 08:07:42:152] JSON Bench for getOpsiInformation_hash "params":[],"id":1} Start: 08:07:42:149 Time: 00:00:00:003
[3] [Jan 31 08:07:42:152] Error: retrieveJSONObject --- opsi service problem ----> unexpected Result from webservice in retrieveJSONObject, number of lines: 0
[5] [Jan 31 08:07:42:152] opsi Server Version :
[4] [Jan 31 08:07:42:152] opsi service version could not retrieved, perhaps no connection
[3] [Jan 31 08:07:42:152] Error: no connection to service
[5] [Jan 31 08:07:42:152] If
[5] [Jan 31 08:07:42:152] errorsOccuredSinceMark > 0 <<< result true
[5] [Jan 31 08:07:42:152] Then
[6] [Jan 31 08:07:42:152] Marked error number 20
[5] [Jan 31 08:07:42:153] comment: scripted login by client id / hostkey failed -> we don't retry
[5] [Jan 31 08:07:42:153] comment: giving up
[5] [Jan 31 08:07:42:153] Set $INST_Authenticated$ = "false"
[6] [Jan 31 08:07:42:153] The value of the variable "$INST_Authenticated$" is now: "false"
[5] [Jan 31 08:07:42:154] Error level set to fatal
[5] [Jan 31 08:07:42:154] Process aborted
[6] [Jan 31 08:07:42:154]
[6] [Jan 31 08:07:42:154] ~~~~~~~ End Sub ~~~~~~~ sub_sub_create_client
Kann mir eventuell jemand auf die Sprünge helfen?
Oliver
