ich versuche derzeit OPSI auf einem Bana Pi mit Debian 8.2 zu installieren. In einem alten Thread hatten wir mal drüber gesprochen, dass in der experimental die Abhängigkeit zum Bootimage aufgehoben wird. Nun kommen hier neue Abhängigkeiten die Probleme machen:
# aptitude install opsi-depotserver-expert
The following NEW packages will be installed:
duplicity{a} fontconfig{a} fontconfig-config{a} iproute{ab} libcairo2{a} libdatrie1{a} libdb5.1{a} libdbi1{a} libdbus-glib-1-2{a} libfontconfig1{a}
libfreetype6{a} libmagic1{a} libpango1.0-0{a} libpixman-1-0{a} librrd4{a} librsync1{a} libthai-data{a} libthai0{a} libx11-6{a} libx11-data{a}
libxau6{a} libxcb-render0{a} libxcb-shm0{a} libxcb1{a} libxdmcp6{a} libxft2{a} libxrender1{a} lsb-release{a} lshw{a} opsi-depotserver-expert
opsi-utils{a} opsiconfd{a} opsipxeconfd{a} pkg-config{a} python-avahi{a} python-dbus{a} python-dbus-dev{a} python-gdbm{a} python-gnupginterface{a}
python-ldap{a} python-ldaptor{a} python-m2crypto{a} python-magic{a} python-mysqldb{a} python-newt{ab} python-openssl{a} python-opsi{a} python-pam{a}
python-pkg-resources{a} python-pyasn1{a} python-pyparsing{a} python-rrdtool{a} python-sqlalchemy{a} python-support{a} python-twisted{a}
python-twisted-bin{a} python-twisted-conch{a} python-twisted-core{a} python-twisted-lore{a} python-twisted-mail{a} python-twisted-names{a}
python-twisted-news{a} python-twisted-runner{a} python-twisted-web{a} python-twisted-words{a} python-zope.interface{a} tftpd{a} ttf-dejavu-core{a}
zsync{a}
The following packages are RECOMMENDED but will NOT be installed:
libatm1 pciutils python-gi python-gobject-2 python-paramiko python-qt4-dbus python-serial python-sqlalchemy-ext ttf-bitstream-vera ttf-dejavu
0 packages upgraded, 69 newly installed, 0 to remove and 0 not upgraded.
Need to get 13.5 MB of archives. After unpacking 45.8 MB will be used.
The following packages have unmet dependencies:
dpkg : Breaks: fontconfig (< 2.11.0-6.2~) but 2.9.0-7.1 is to be installed.
iproute : Conflicts: arpd which is a virtual package.
python-newt : Depends: libnewt0.52 (= 0.52.14-11.1) but 0.52.17-1+b1 is installed.
iproute2 : Conflicts: arpd which is a virtual package.
Conflicts: iproute (< 20130000-1) but 20120521-3+b3 is to be installed.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) fontconfig [Not Installed]
2) iproute [Not Installed]
3) libpango1.0-0 [Not Installed]
4) librrd4 [Not Installed]
5) opsi-depotserver-expert [Not Installed]
6) opsi-utils [Not Installed]
7) opsiconfd [Not Installed]
8) opsipxeconfd [Not Installed]
9) python-newt [Not Installed]
10) python-opsi [Not Installed]
11) python-rrdtool [Not Installed]
sieht mal so aus, als wenn die standard-Repos, die du verwendest etwas krumm sind. Bei sowas hilft nur zu versuchen die Conflicte manuell zu lösen. Ich würde hiermit anfangen:
Ich würde erst mal versuchen das arpd zu bekommen für deine Plattform.
Was auch manchmal hilft, apt-get statt aptitude und andersrum zu verwenden. Manchmal hilft das auch schon, auch wenn es schräg ist. Das könnte das iproute-Conflict vielleicht besser handlen, aber arpd fehlt und das bekommt dann auch apt-get nicht hin.
For productive opsi installations we recommend support contracts. http://www.uib.de
deb http://ftp.de.debian.org/debian/ wheezy main
deb-src http://ftp.de.debian.org/debian/ wheezy main
deb http://security.debian.org/ wheezy/updates main
deb-src http://security.debian.org/ wheezy/updates main
deb http://download.opensuse.org/repositories/home:/uibmz:/opsi:/opsi40-experimental/Debian_8.0/ ./
Wo tritt die Meldung denn auf?
Wird das configed direkt auf dem Pi gestartet oder von einem anderen Rechner aus?
Außerdem: welche Version wird verwendet?
danke für Eure prompte Hilfe. Problem lag daran, dass es wohl Probleme gab mit dem einspielen der minimal Pakete. Hab dieses noch einmal neu von Hand gestartet mit -vv und sieh da. Läuft
