Oh noes... Autodesk
I've had SO much trouble to get that piece of shite to finally install. It took me a few weeks. Anyway, Autodesk is a crazy bunch. They don't support Windows XP anymore, but include all sorts of packages you would need on XP, such as the Windows Installer update. They check for SSE2 instructions on an amd64 cpu! They also want to install a lot of unneeded utilities. I got the .opsi file down to 780 MB, by throwing out everything you don't need.
I couldn't get the user-part of the installation running and then autocad would still use its own settings. AutoCAD is one of those wonderful programs that won't start if a few registry keys are missing. With other programs you just specify the one setting you want different, and the rest gets added. With AutoCAD that doesn't work. So I have a huge script which includes a lot of registry settings.
A part of my setup script:
I only use the 64-bit version, as a 32-bit machine will be better off running AutoCAD 2011.
[Winbatch_install_vcredist_2008SP1_32]
"%ScriptPath%\files\vcredist_x86_2008SP1_9.0.30729.6161.exe" /q
[Winbatch_install_vcredist_2008SP1_64]
"%ScriptPath%\files\vcredist_x64_2008SP1_9.0.30729.6161.exe" /q
[Winbatch_install_vcredist_2010SP1_32]
"%ScriptPath%\files\vcredist_x86_2010SP1_10.0.40219.325.exe" /passive /norestart
[Winbatch_install_vcredist_2010SP1_64]
"%ScriptPath%\files\vcredist_x64_2010SP1_10.0.40219.325.exe" /passive /norestart
[Winbatch_install_vcredist_2012UPD4_32]
"%ScriptPath%\files\vcredist_x86_2012_11.0.61030.1.exe" /install /passive /norestart
[Winbatch_install_vcredist_2012UPD4_64]
"%ScriptPath%\files\vcredist_x64_2012_11.0.61030.1.exe" /install /passive /norestart
[Winbatch_install_64]
"%ScriptPath%\files\AutoCAD\Setup.exe" /w /qb /I %ScriptPath%\files\AutoCAD\Setup.ini /t /language en-us /c ACAD: INSTALLDIR="$InstallDir64$" $MSI_License$ $MSI_Online$ $MSI_Components$
[Winbatch_install_SP2_64]
"%SystemRoot%\system32\msiexec.exe" /qb-! /p "%ScriptPath%\files\AutoCAD_2015_SP2_64bit.msp" /norestart
This is my setup.ini
[SETUP]
PLATFORM=x64
SETUP_CODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4}
TITLE=AcSetupRes.dll;1
LOG=%tmp%\Autodesk AutoCAD 2015 Setup.log
EVALMSI=SetupRes\eval.msi
PRIMARY_MSI=%platform%\acad\acad.msi
SYSUPDATE=MSI
RESOURCE_PATH=%lang%\SetupRes
INSTALL_PATH=C:\Program Files\Autodesk\
CREATE_DESKTOP_SHORTCUT=NO
LPMODE=NO_ADD_LP
DEFAULTMEDIALANGUAGE=en-US
#============================= Help Link =============================
DOCUMENT_LINK=http://www.autodesk.com/installation-help-2015-%setupuilang%
DOCUMENT_FALLBACK_LINK=Docs\acad_install_help\index.html
SYSTEMREQUIRE_LINK=http://www.autodesk.com/autocad-win-sys-reqs-2015-%setupuilang%
SYSTEMREQUIRE_FALLBACK_LINK=Docs\acad_sysreq\index.html
SUPPORT_LINK=http://www.autodesk.com/autocad-win-readme-2015-%setupuilang%
SUPPORT_FALLBACK_LINK=Readme\readme.html
#============================= Platform Requirement =============================
OSMAJVER=5
OSMINVER=1
SPMAJVER=2
#============================= UI =============================
UI_MODE=BASICUI
#============================= Deployment Info =============================
DEPLOYMENT_NAME=
CLIENT_LOGGING=YES
#EXTRA_FILES=acad;*.exe:Setup:CER:eula:3rdParty\msi:nlsdl:3rdParty\NET:setupres:%lang%
EXTRA_FILES=acad;*.exe:Setup:CER:eula:nlsdl:setupres:%lang%
#============================= Install Execute & UI Sequence =============================
#EXE_SEQUENCE=ACAD;NLM;CADM;SNAP;AUTODESK_RECAP;ACADAPPMGR;ACADFEATUREDAPPS;PERFORMANCETOOL;GLUE_PLUGIN_AUT;ADSYNC;ADAPPLICATIONMANAGER
EXE_SEQUENCE=ACAD;ADDONS
#INSTALL_SEQUENCE=NLM;CADM;SNAP;ACAD;AUTODESK_RECAP;ACADAPPMGR;ACADFEATUREDAPPS;PERFORMANCETOOL;GLUE_PLUGIN_AUT;ADSYNC;ADAPPLICATIONMANAGER
INSTALL_SEQUENCE=ACAD;ADDONS
#UI_SEQUENCE=LaunchDlg;BeginDeploymentDlg;LicenseDlg;ProductInfoDlg;ProductSelectionDlg2;ACAD;CADM;SNAP;ADSYNC;ADAPPLICATIONMANAGER;FullProgressDlg;InstallCompleteDlg;DeploymentCompleteDlg;DeploymentFailedDlg
UI_SEQUENCE=BeginDeploymentDlg;LicenseDlg;ProductInfoDlg;ProductSelectionDlg2;ACAD;ADDONS;FullProgressDlg;InstallCompleteDlg;DeploymentCompleteDlg;DeploymentFailedDlg
#============================= AdLM ProdKey Info =============================
ADLM_CONFIG_FILE=Setup\AutoCADConfig.pit
ADLM_PIT_DLL=Setup\adlmPIT.dll
ADLM_VERSION=2015.0.0.F
ADLM_TRIAL_DAYS=30
#============================= Custom Callback Function =============================
CB_FUNC=CustomPlatformCheck
CB_SOURCE=Setup\AcSetup.dll
CB_PARAM=5.2-x64;5.1-x86;http://www.autodesk.com/autocad-win-sys-reqs-2015-
CB_DESCRIPTION=Custom callback function to check platform support.
#============================= Global MSI Properties =============================
PATH_LENGTH=157
DEPLOYMENT_PLATFORM=x64
DEPLOYMENT_MODE=MINIMAL
UI_MODE=BASICUI
NETWORK_LOG_PATH=
NETWORK_LOGGING=NO
ADDON_SEQUENCE=
SETUP_LANGUAGES=en-us
[GLOBAL_MSI_PROPERTIES]
#============================= ACAD =============================
[ACAD]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk® AutoCAD® 2015
PREREQUISITE=
POSTREQUISITE=ACAD_PSPACK
EXE_PATH=%platform%\acad\acad.msi
EXE_PARAM=
EXTRA_FILES=acad;acad\*.ico
LOG=%tmp%\Autodesk AutoCAD 2015 Install.log
ROLLBACKABLE=YES
ADMIN_INSTALL=YES
PRODUCT_MESSAGE=AcSetupRes.dll;41
PRODUCT_INSTALLED_INFO_MSG=AcSetupRes.dll;70
PRODUCT_INSTALLED_INFO_URL=AcSetupRes.dll;71
DEPLOYMENTLANGUAGE=
EULA_PATH=eula
ACTION=INSTALL
REMOVE_PATH=
USE_EXTERNAL_UI=YES
EXTRA_FEATURES=Express_Tools
README_FILE=help\contexthelp\readme.htm;AcSetupRes.dll;4
LAUNCH_EXE=acad.exe
UI_SEQUENCE=InstallTypePage;ContentLocationPage;ExecutableFileSettingsPage;PathCustomizationPage_ACAD;AddAdditionalFilesPage;WorkstationSettingPage;ServicePackPageForDeploy;ServicePackPageForInstall;InfoCenterCommCenterPage;OnlineResourcesPage
MAINTENANCE_UI_SEQUENCE=OemPreinstallLicenseDlg;OemPreinstallProductInfoDlg;MaintenanceDlg;AddRemoveFeaturesDlg;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg
VC_FUNC=CheckHardwareRequirements
VC_SOURCE=Setup\AcSetup.dll
VC_PARAM=2;4;30;http://www.autodesk.com/certified-hardware
VC_DESCRIPTION=Check Hardware Requirements
SUMMARY_FUNC=LoadSummary_ACAD
SUMMARY_SOURCE=SetupAcadUi.dll
#SUBCOMPONENT=ACADAPPMGR;ACADFEATUREDAPPS;PERFORMANCETOOL;GLUE_PLUGIN_AUT
SUBCOMPONENT=
CanSpan=1
LPMODE=MUI
AVAILABLELANGUAGES=en-US
SHAREDREQUISITE=
EULA_INDEX=-1
EULA_STATE=YES
#CONFIG_TRANSFORM=acad-bla3.mst
STOCK_TRANSFORMS=
TRANSFORMS=
PATCHES=
[ACAD_en-US]
DISK_LABEL=acad2015
DISK_PROMPT=AcSetupRes.dll;11
#============================= ACAD Language Pack =============================
[ACAD_LANGPACK]
PRODUCT_NAME=AutoCAD® 2015 Language Pack
EXE_PATH=%platform%\%lang%\acad\AcadLP.msi
EXE64_PATH=%platform%\%lang%\acad\AcadLP.msi
ADMIN_INSTALL=YES
LOG=%tmp%\Autodesk AutoCAD 2015 LangPack Install.log
#============================= ACAD Product Specific Pack =============================
[ACAD_PSPACK]
PLATFORM=NATIVE
PRODUCT_NAME=AutoCAD® 2015 Product Specific Pack
EXE_PATH=%platform%\%lang%\acad\AcadPS.msi
LOG=%tmp%\Autodesk AutoCAD 2015 PSPack Install.log
ADMIN_INSTALL=YES
LPMODE=MLD_ADR
#============================= AUTODESK_RECAP =============================
EXE_PARAM=
PATCHES=
[AUTODESK_RECAP]
PLATFORM=x64
PRODUCT_NAME=Autodesk® ReCap™
PREREQUISITE=VCREDIST2008SP1X86_6161;VCREDIST2008SP1X64_6161;VCREDIST2010SP1X86;VCREDIST2010SP1X64;VCREDIST2012X86UPD4;VCREDIST2012X64UPD4;DOTNET4
EXE_PATH=%platform%\RC2015\AutodeskReCap.msi
EXE_PARAM=
EXTRA_FILES=RC2015;%platform%\RC2015\*.PIT
LOG=%tmp%\Autodesk ReCap Install.log
ROLLBACKABLE=NO
ADMIN_INSTALL=YES
PRODUCT_MESSAGE=AutodeskReCapSetupRes.dll;116
EULA_PATH=eula
ACTION=INSTALL
DISK_PROMPT=
DISK_LABEL=
REMOVE_PATH=
USE_EXTERNAL_UI=YES
PRODUCT_ICON=SetupRes\AutodeskReCap.ico
REMOVE_PREV_VERSION=YES
UI_SEQUENCE=InstallTypePage;PathCustomizationPage;AddAdditionalFilesPage;WorkstationSettingPage;ServicePackPageForDeploy;ServicePackPageForInstall
MAINTENANCE_UI_SEQUENCE=MaintenanceDlg;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg
LPMODE=MLD_ADR
[AUTODESK_RECAP_en-US]
DISK_LABEL=
DISK_PROMPT=
#============================= Block Vista version Check =============================
[ACAD_VISTA_BLOCK]
PRODUCT_NAME=Block Vista version Check
EXE_PATH=NULL
VC_FUNC=CheckForOSBlock
VC_PARAM=6.0-x64;6.0-x86;http://www.autodesk.com/autocad-win-sys-reqs-2015-%setupuilang%
VC_DESCRIPTION=Block Vista version Check
#============================= Common Autodesk Components =============================
#============================= Autodesk Tools =============================
[NLM]
PLATFORM=NATIVE
PRODUCT_NAME=Network License Manager
EXE_PATH=%platform%\%lang%\Tools\NLM\NLM.msi
EXE_PARAM=ALLUSERS=1
LOG=%tmp%\NLM Install.log
PRODUCT_MESSAGE=AcSetupRes.dll;47
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
ACTION=INSTALL
DISKCOST=8000000
INSTALL_TYPE=4
LPMODE=MLD_ADR
[CADM]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk CAD Manager Tools
PREREQUISITE=SSE2;VCREDIST2012X86UPD4;VCREDIST2012X64UPD4
EXE_PATH=%platform%\%lang%\Tools\CADManager\CADManager.msi
LOG=%tmp%\CADManager Install.log
PRODUCT_MESSAGE=AcSetupRes.dll;46
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
ACTION=INSTALL
INSTALL_TYPE=4
LPMODE=MLD_ADR
#============================= Content Service =============================
[SNAP]
PRODUCT_NAME=Autodesk Content Service
PREREQUISITE=DOTNET45;VCREDIST2008SP1X86;VCREDIST2010SP1X86;VCREDIST2012X86UPD4
EXE_PATH=%platform%\Tools\snap\ContentService.msi
EXE_PARAM=INSTALLMODE=PUBLIC AUTOSTART=1
LOG=%tmp%\Autodesk Content Service.log
PRODUCT_MESSAGE=ContentServiceRes.dll;417
IGNORE_FAILURE=YES
DISK_LABEL=acad2015
DISKCOST=37000000
INSTALL_TYPE=4
UI_SEQUENCE=Snap_InstallModePage
VC_FUNC=ACSCheck_StandAlone
VC_SOURCE=Setup\ContentServiceUI.dll
LPMODE=MLD_INV
[SNAP_en-US]
DISK_LABEL=acad2015
#============================= ContentService Language Pack Postrequisite =============================
[SNAP_LANGPACK]
PRODUCT_NAME=Autodesk Content Service Language Pack
EXE_PATH=%platform%\%lang%\Tools\snap\ContentServiceLP.msi
[SNAP_PRE]
EXE_PARAM=INSTALLMODE=PRIVATE AUTOSTART=0
IGNORE_FAILURE=YES
ACTION=INSTALL
DISK_LABEL=acad2015
DISKCOST=37000000
VC_FUNC=ACSCheck_Inline
LPMODE=MLD_INV
[SNAP_PRE_en-US]
DISK_LABEL=acad2015
[SNAP_PRE_LANGPACK]
#============================= Common Autodesk Content =============================
[CM]
PLATFORM=ALL
PRODUCT_NAME=Autodesk Material Library 2015
EXE_PATH=Content\ADSKMaterials\2015\CM\MaterialLibrary2015.msi
EXTRA_FILES=acad;Content\ADSKMaterials\2015\CM\*.cab
LOG=%tmp%\MaterialLibrary2015CM.log
ADMIN_INSTALL=NO
ACTION=INSTALL
DISKCOST=88000000
[CMILB]
PLATFORM=ALL
PRODUCT_NAME=Autodesk Material Library 2015 - Base Image Library
EXE_PATH=Content\ADSKMaterials\2015\ILB\BaseImageLibrary2015.msi
EXTRA_FILES=acad;Content\ADSKMaterials\2015\ILB\*.cab
LOG=%tmp%\MaterialLibrary2015CMILB.log
ADMIN_INSTALL=NO
ACTION=INSTALL
DISKCOST=81000000
#============================= Autodesk 360 =============================
[ADSYNC]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk® 360
EXE_PATH=%platform%\Components\Cloudsync\AdSync.msi
EXE_PARAM=ADLANGUAGE=%selectedlang%
LOG=%tmp%\CloudsyncInstall.log
ROLLBACKABLE=NO
ADMIN_INSTALL=YES
PRODUCT_MESSAGE=A360SetupUiRes.dll;300
IGNORE_FAILURE=YES
SHARED_COMPONENT=YES
ACTION=INSTALL
UI_SEQUENCE=A360CustomConfigPage
#============================= Autodesk App Manager AppStore bundle for AutoCAD =============================
[ACADAPPMGR]
PLATFORM=NATIVE
PRODUCT_NAME=Exchange App Manager
EXE_PATH=%platform%\ACADExtApps\AutodeskAppManager.msi
LOG=%tmp%\ACADExtApps_AppManager_Install.log
ADMIN_INSTALL=YES
PRODUCT_MESSAGE=AcSetupRes.dll;80
IGNORE_FAILURE=YES
ACTION=INSTALL
#============================= Autodesk SketchUp Import AppStore bundle for AutoCAD =============================
[ACADSKETCHUPIMPORT]
PLATFORM=NATIVE
PRODUCT_NAME=SketchUp Import plug-in
EXE_PATH=%platform%\ACADExtApps\AutodeskImportSkp.msi
LOG=%tmp%\ACADExtApps_SketchUpImport_Install.log
ADMIN_INSTALL=YES
PRODUCT_MESSAGE=AcSetupRes.dll;82
IGNORE_FAILURE=YES
ACTION=INSTALL
#============================= Autodesk Featured Apps AppStore bundle for AutoCAD =============================
[ACADFEATUREDAPPS]
PLATFORM=NATIVE
PRODUCT_NAME=Exchange Featured Apps plug-in
EXE_PATH=%platform%\ACADExtApps\AutodeskFeaturedApps.msi
LOG=%tmp%\ACADExtApps_FeaturedApps_Install.log
ADMIN_INSTALL=YES
PRODUCT_MESSAGE=AcSetupRes.dll;81
IGNORE_FAILURE=YES
ACTION=INSTALL
#============================= Performance Tool =============================
[PERFORMANCETOOL]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk® AutoCAD® Performance Reporting Tool
EXE_PATH=Tools\PerformanceTool\AcPerfMon.msi
EXE_PARAM=
LOG=%tmp%\Performance_Tool_Install.log
ADMIN_INSTALL=YES
PRODUCT_MESSAGE=AcSetupRes.dll;83
IGNORE_FAILURE=YES
ACTION=INSTALL
#============================= Autodesk BIM 360 Add-in for AutoCAD 2015 =============================
[GLUE_PLUGIN_AUT]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk® BIM 360™ Add-in for AutoCAD® 2015
EXE_PATH=%platform%\Components\BIM360\setup.msi
LOG=%tmp%\Autodesk BIM 360 Add-in for AutoCAD 2015 Install.log
PRODUCT_MESSAGE=AcSetupRes.dll;84
ACTION=INSTALL
#============================= Autodesk Application Manager =============================
[ADAPPLICATIONMANAGER]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk Application Manager
EXE_PATH=x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe
EXE_PARAM=
IGNORE_FAILURE=YES
ACTION=INSTALL
DISKCOST=80000000
UI_SEQUENCE=AdAppManPage
VC_FUNC=AdAppManCheck
VC_SOURCE=Setup\SetupUi.dll
VC_PARAM=1.0.51.0
HIDDEN_COMPONENT=YES
#============================= 3rd Party Components =============================
[IE]
PRODUCT_NAME=Internet Explorer
EXE_PATH=NULL
PRODUCT_MESSAGE=SetupRes.dll;209
ACTION=INSTALL
VC_FUNC=IeVerCheck
VC_PARAM=7.0.5730;7.0;1
VC_DESCRIPTION=Detecting Internet Explorer
[MSI]
PLATFORM=ALL
PRODUCT_NAME=Windows Installer Redistributable
EXE_PATH=3rdParty\msi
EXE_PARAM=/quiet /norestart
VC_FUNC=MsiVerCheck
VC_PARAM=4.0
VC_DESCRIPTION=Detecting MSI
[NLSDL]
PLATFORM=NATIVE
PRODUCT_NAME=Microsoft NLS Downlevel APIs
EXE_PATH=NLSDL\nlsdl.x86.exe
EXE64_PATH=NLSDL\nlsdl.amd64.exe
IGNORE_FAILURE=YES
[MSXML6]
PLATFORM=NATIVE
PRODUCT_NAME=MSXML 6
EXE_PATH=3rdParty\x86\msxml6\msxml6.msi
EXE64_PATH=3rdParty\x64\msxml6\msxml6_x64.msi
IGNORE_FAILURE=YES
VC_FUNC=MsxmlVerCheck
VC_PARAM=6.0
#============================= VCREDIST Begin =============================
[VCREDIST2012X86UPD4]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2012 Redistributable (x86) Update 4
EXE_PATH=3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe
EXE_PARAM=/install /quiet /norestart /log %temp%\vcredist_x86_2012_UPD4.log
IGNORE_FAILURE=YES
IGNORE_ERROR=5100
[VCREDIST2012X64UPD4]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2012 Redistributable (x64) Update 4
EXE64_PATH=3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe
EXE_PARAM=/install /quiet /norestart /log %temp%\vcredist_x64_2012_UPD4.log
IGNORE_FAILURE=YES
IGNORE_ERROR=5100
[VCREDIST2010SP1X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe
EXE_PARAM=/q /norestart /l %temp%\vcredist_x86_2010.log
IGNORE_ERROR=5100
VC_FUNC=VCx86RedisCheck
VC_PARAM={F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}
[VCREDIST2010SP1X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe
EXE_PARAM=/q /norestart /l %temp%\vcredist_x64_2010.log
IGNORE_ERROR=5100
VC_FUNC=VCx64RedisCheck
VC_PARAM={1D8E6291-B0D5-35EC-8441-6616F567A0F7}
[VCREDIST2008SP1X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={1F1C2DFC-2D24-3E06-BCB8-725134ADF989}
[VCREDIST2008SP1X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={4B6C7001-C7D6-3710-913E-5BC23FCE91E6}
[VCREDIST2008SP1X64_6161]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161
EXE64_PATH=3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}
[VCREDIST2008SP1X86_6161]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161
EXE_PATH=3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={9BE518E6-ECC6-35A9-88E4-87755C07200F}
#============================= VCREDIST End =============================
[SSE2]
PRODUCT_NAME=SSE2 Support Check
EXE_PATH=NULL
PRODUCT_MESSAGE=SSE2 Support Check
VC_FUNC=CheckForSSE2Support
VC_DESCRIPTION=SSE2 Support Check
[DOTNET4]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.0
EXE_PATH=3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe
EXE_PARAM=/q
DISKCOST=352037424
VC_FUNC=DotnetVerify
VC_PARAM=.NET Framework 4 Full
VC_DESCRIPTION=Detecting .NET 4.0 Runtime
[DOTNET45]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.5
EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotNetFx45_Full_x86_x64.exe
IGNORE_FAILURE=YES
DISKCOST=388037424
VC_PARAM=.NET Framework 4.5 Full
VC_DESCRIPTION=Detecting .NET 4.5 Runtime
[DOTNET45LANG]
PRODUCT_NAME=.NET Framework Runtime 4.5 Language Pack
EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotNetFx45LP_Full_x86_x64_%lcid%.exe
EXE_LANGS=1025;1028;1029;1030;1031;1032;1034;1035;1036;1037;1038;1040;1041;1042;1044;1045;1046;1049;1053;1055;2052;2070;3082
IGNORE_FAILURE=YES
DISKCOST=3000000
VC_FUNC=DotnetLangPacksVerCheck
VC_PARAM=%lcid%;4.5.50709
IGNORE_LANGS=1033
LPMODE=MLD_ADR
#============================= DOTNET Ends =============================
[DIRECTX]
PLATFORM=ALL
PRODUCT_NAME=DirectX Runtime
EXE_PATH=3rdParty\DirectX\DXSETUP.exe
EXE_PARAM=/silent
IGNORE_FAILURE=YES
DISKCOST=50000000
[WMF95X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Windows Media Format 9.5 Series Runtime
EXE64_PATH=3rdParty\x64\wmf\95\wmfdist64.exe
EXE_PARAM=/quiet
ROLLBACKABLE=NO
IGNORE_FAILURE=YES
ACTION=INSTALL
VC_FUNC=WMFCheck
VC_PARAM=9.5
#============================= Common Main Pages: Install Mode =============================
[LaunchDlg]
UI_CREATOR=LaunchDialog
UI_SOURCE=Setup\SetupAcadUi.dll
[LicenseDlg]
UI_CREATOR=LicenseDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL
[ProductSelectionDlg2]
UI_CREATOR=ProductSelectionDialog2
UI_POSTCONSTRUCT=SetInstallPathEditorStatus
UI_POSTCONSTRUCT_SOURCE=Setup\AcSetup.dll
[ProductInfoDlg]
UI_CREATOR=ProductInfoDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"TOOLS"
[FullProgressDlg]
UI_CREATOR=FullProgressDialog
UI_INFOTAINMENT_PATH=SetupRes\Infotainment\Images
UI_INFOTAINMENT_ELAPSE=18000
[InstallCompleteDlg]
UI_CREATOR=InstallCompleteDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"DEPLOYMENT" AND ADSK_LAUNCH_MODE<>"MINIMAL_DEPLOYMENT"
#============================= Common Main Pages: Deploy Mode =============================
[BeginDeploymentDlg]
UI_CREATOR=BeginDeploymentDialog
UI_SOURCE=Setup\DeployUi.dll
UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[DeploymentCompleteDlg]
UI_CREATOR=DeploymentCompleteDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND ADSK_SETUP_SUCCEEDED
[DeploymentFailedDlg]
UI_CREATOR=DeploymentFailedDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND NOT ADSK_SETUP_SUCCEEDED
#============================= Common Config pages: Install Mode =============================
[InstallTypePage]
UI_CREATOR=InstallTypePage
[Snap_InstallModePage]
UI_CREATOR=InstallModePage
UI_SOURCE=Setup\ContentServiceUI.dll
#============================= Common Config Pages: Deploy Mode =============================
[ContentLocationPage]
UI_CREATOR=ContentLocationPage
[PathCustomizationPage]
UI_CREATOR=PathCustomizationPage
[ExecutableFileSettingsPage]
UI_CREATOR=ExecutableFileSettingsPage
UI_SOURCE=Setup\AcDeployUi.dll
[PathCustomizationPage_ACAD]
UI_CREATOR=PathCustomizationPage_ACAD
[AddAdditionalFilesPage]
UI_CREATOR=AddAdditionalFilesPage
[WorkstationSettingPage]
UI_CREATOR=WorkstationSettingPage
[ServicePackPageForDeploy]
UI_CREATOR=ServicePackPage
[ServicePackPageForInstall]
UI_CONDITION=ADSK_RUNNING_FROM_ADMIN="FALSE" AND NOT ADSK_LAUNCH_MODE="DEPLOYMENT" AND NOT ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[InfoCenterCommCenterPage]
UI_CREATOR=InfoCenterCommCenterPage
[OnlineResourcesPage]
UI_CREATOR=OnlineResourcesPage
[AdAppManPage]
UI_CREATOR=AdAppManPage
[A360CustomConfigPage]
UI_CREATOR=CustomConfigPage
UI_SOURCE=Setup\A360SetupUi.dll
#============================= Common Main Pages: Maintenance Mode =============================
[OemPreinstallLicenseDlg]
UI_CONDITION=ADSK_OEMPREINSTALL="1"
[OemPreinstallProductInfoDlg]
[MaintenanceDlg]
UI_CREATOR=MaintenanceDialog
[AddRemoveFeaturesDlg]
UI_CREATOR=AddRemoveFeaturesDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT REINSTALL="ALL" AND NOT REMOVE="ALL"
[RepairDlg]
UI_CREATOR=RepairDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND REINSTALL="ALL"
[MaintVerifyReadyDlg]
UI_CREATOR=MaintVerifyReadyDialog
[MaintCompleteDlg]
UI_CREATOR=MaintCompleteDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND ADSK_SETUP_SUCCEEDED
[MaintFailedDlg]
UI_CREATOR=MaintFailedDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT ADSK_SETUP_SUCCEEDED
[ADDONS]
INSTALL_TYPE=
PLATFORM=NATIVE
PRODUCT_NAME=\setupres.dll;189
PRODUCT_MESSAGE=SetupRes.dll;187
LOG=%tmp%\Addons Install.log
ACTION=INSTALL
UI_SEQUENCE=AddAddonPage
AVAILABLELANGUAGES=
PREREQUISITE=
SHAREDREQUISITE=
POSTREQUISITE=
EXE_PARAM=
EULA_INDEX=-1
EULA_STATE=
CONFIG_TRANSFORM=
STOCK_TRANSFORMS=
TRANSFORMS=
[AddAddonPage]
UI_CREATOR=AddAddonPage
Look at this part:
As you can see from the commented-out INSTALL_SEQUENCE it wants to install AutoCAD Sync, some featured apps nobody uses, Recap, content service (snap) and other garbage.
The useful applications such as the sketchup import have gotten their own package.
old:
PREREQUISITE=ACAD_VISTA_BLOCK;IE;SSE2;DOTNET45;DOTNET45LANG;VCREDIST2008SP1X86;VCREDIST2008SP1X64;VCREDIST2010SP1X86;VCREDIST2010SP1X64;VCREDIST2012X86UPD4;VCREDIST2012X64UPD4;DIRECTX;MSXML6;WMF95X64;CM;CMILB;SNAP_PRE
POSTREQUISITE=ACAD_PSPACK;ACADSKETCHUPIMPORT
new:
PREREQUISITE=
The .net lamework is already an other package, the same goes for the directx9 runtime. MSXML6 is bloody standard on Windows 7 and up. And what does AutoCAD 2015 support? Windows 7 and up.
Oh, you also need this:
set $INST_LicenseServer$ = GetProductProperty("license_server","fqdn.of-your-own-license-server.local")
Set $MSI_License$ =' ACADFIRSTNAME="ICT" ACADLASTNAME="ICT" ACADORGANIZATION="ANARCHY" ACADLICENSESERVERTYPE="Single Server License" ACADLICENSETYPE="Network License" ACADSERVERFMTPATH=' + $INST_LicenseServer$ + ' ADLM_LICENSE_TYPE=#1 ACADSERIALNUMBER=45678910 ACADSERIALPREFIX=123 ACADSERVERPATH="' + $INST_LicenseServer$ + ' 000000000000" ADLM_PRODKEY=001G1 ACADSTANDALONENETWORKTYPE=3'
Set $MSI_Online$ = ' MC3_ENABLED=#0 ACAD_TEMP_CADMGR_DISPLAY_NAME="CAD Manager Channel" ACAD_ENABLE_ROUNDTRIP=#0 ACAD_LIVEUPDATE_ENABLE=#0 ACAD_LIVEUPDATE_PATCHNOTIFY=#3 ACAD_CHECK_DOTNET=0 ACAD_SEARCH_LOCATIONS_ENABLE=#0 ACAD_SUBSCRIPTIONCENTER_ENABLE=#0 ACAD_USE_ONLINE_CONTENT=#0 ADSK_DESKTOPSHORTCUT_1=0'
Set $MSI_Components$ =' ADDLOCAL=ALL REMOVE=NewTabPage,WelcomeScreen,AutodeskCloud,AutodeskSeek,CADStandards,ContentExplorer,Database,DrawingEncryption,ICSM,LTU,Migrate,ModelDoc,RefMan,ResetSettings,Samples,ACS,DCS,VLS,Tutorials,VLT,VBA'
This is easier to manage than an MST file, or using the MST file from a deployment.
