Im Moment ist die Version 4.0.1.24 (2012/02/22) in einer VM installiert.
Ideen zur Lösung?
MfG
Running package script 'postinst'
Traceback:
line 411 in '_runPackageScript' in file '/usr/lib/pymodules/python2.6/OPSI/Util/Product.py'
line 730 in 'execute' in file '/usr/lib/pymodules/python2.6/OPSI/System/Posix.py'
==>>> Command '/tmp/.opsi.unpack.lQ9zp/OPSI/postinst' timed out atfer 600 seconds
Traceback:
line 298 in 'installPackage' in file '/usr/lib/pymodules/python2.6/OPSI/Backend/Depotserver.py'
line 421 in 'runPostinst' in file '/usr/lib/pymodules/python2.6/OPSI/Util/Product.py'
line 415 in '_runPackageScript' in file '/usr/lib/pymodules/python2.6/OPSI/Util/Product.py'
==>>> Failed to execute package script 'postinst' of package '/var/lib/opsi/repository/opsi-template-with-admin_4.0.2-2.opsi': Command '/tmp/.opsi.unpack.lQ9zp/O PSI/postinst' timed out atfer 600 seconds
Traceback:
line 1060 in '<module>' in file '/usr/bin/opsi-product-updater'
line 1054 in 'main' in file '/usr/bin/opsi-product-updater'
line 565 in 'processUpdates' in file '/usr/bin/opsi-product-updater'
line 1 in 'depot_installPackage' in file '<string>'
line 423 in '_executeMethod' in file '/usr/lib/pymodules/python2.6/OPSI/Backend/Backend.py'
line 114 in 'depot_installPackage' in file '/usr/lib/pymodules/python2.6/OPSI/Backend/Depotserver.py'
line 385 in 'installPackage' in file '/usr/lib/pymodules/python2.6/OPSI/Backend/Depotserver.py'
==>>> Backend error: Failed to install package '/var/lib/opsi/repository/opsi-template-with-admin_4.0.2-2.opsi' on depot 'opsi.meta-1.local': Failed to execute p ackage script 'postinst' of package '/var/lib/opsi/repository/opsi-template-with-admin_4.0.2-2.opsi': Command '/tmp/.opsi.unpack.lQ9zp/OPSI/postinst' timed out atfer 600 seconds
ERROR: Backend error: Failed to install package '/var/lib/opsi/repository/opsi-template-with-admin_4.0.2-2.opsi' on depot 'opsi.meta-1.local': Failed to execute packa ge script 'postinst' of package '/var/lib/opsi/repository/opsi-template-with-admin_4.0.2-2.opsi': Command '/tmp/.opsi.unpack.lQ9zp/OPSI/postinst' timed out atfer 600 seconds
