ich habe endlich Zeit gefunden mich mit dem Thema powershellCall zu beschäftigen. Leider finde ich meinen Fehler nicht.
Ich habe folgendes Beispiel aus dem opsi script manual kopiert. https://download.uib.de/opsi_stable/doc ... lCall_list
comment "1"
DefVar $exitcode$
set $exitcode$ = powershellCall('Get-Process -ProcessName "opsi*"')
comment "2"
DefStringList $list2$
set $list2$ = powersshellCall('Get-Process -ProcessName "opsi*"')
(133) [5] [Mai 13 08:39:11:603] [lra_test] comment: 1
(134) [6] [Mai 13 08:39:11:604] [lra_test] Set $exitcode$ = powershellCall('Get-Process -ProcessName "opsi*"')
(135) [5] [Mai 13 08:39:11:604] [lra_test] PowerhellCall Executing: Get-Process -ProcessName "opsi*" ; mode: sysnative
(136) [6] [Mai 13 08:39:11:604] [lra_test] ShellCall Executing: "C:\WINDOWS\\cmd64.exe" /C "powershell.exe get-executionpolicy"
(137) [6] [Mai 13 08:39:12:334] [lra_test] ShellCall Executing: "C:\WINDOWS\\cmd64.exe" /C "powershell.exe set-executionpolicy RemoteSigned"
(138) [6] [Mai 13 08:39:13:056] [lra_test]
(139) [6] [Mai 13 08:39:13:056] [lra_test] Execution of tmp-internal powershell.exe winst /sysnative
(140) [6] [Mai 13 08:39:13:602] [lra_test] ExitCode 0
(141) [6] [Mai 13 08:39:13:610] [lra_test] Search "c:\opsi.org\tmp\"
(142) [6] [Mai 13 08:39:13:610] [lra_test] Search "c:\opsi.org\tmp\_opsiscript_*"
(143) [6] [Mai 13 08:39:13:612] [lra_test] ShellCall Executing: "C:\WINDOWS\\cmd64.exe" /C "powershell.exe set-executionpolicy Restricted"
(144) [6] [Mai 13 08:39:14:339] [lra_test] The value of the variable "$exitcode$" is now: "0"
(145) [5] [Mai 13 08:39:14:339] [lra_test] comment: 2
(146) [6] [Mai 13 08:39:14:340] [lra_test] Set $list2$ = powersshellCall('Get-Process -ProcessName "opsi*"')
(147) [2] [Mai 13 08:39:14:341] [lra_test] Syntax Error in Section: Actions (Command in line 45 in section: Actions; file: setup.opsiscript; section start at line: 1; origin: setup.opsiscript; line: 45): $list2$ = powersshellCall('Get-Process -ProcessName "opsi*"') -> powersshellCall('Get-Process -ProcessName "opsi*"') no valid Expressionstr for a string list
(148) [2] [Mai 13 08:39:14:341] [lra_test] Syntax Error in Section: Actions (Command in line 46 in section: Actions; file: setup.opsiscript; section start at line: 1; origin: setup.opsiscript; line: 46): EndIf -> expected
(149) [1] [Mai 13 08:39:14:341] [lra_test] ___________________
(150) [1] [Mai 13 08:39:14:341] [lra_test] script finished: failed
(151) [1] [Mai 13 08:39:14:341] [lra_test] 2 errors
