hab hier eine neue Workstation die sich nicht Installieren lässt.
Fehler Netboot:
Opsi rpc error: Backend referential integrity error: Hardware device {'vendorId': u'8086', 'maxSpeed': 10000000000, 'vendor': u'Intel Corporation', 'description': u'Ethernet interface', 'subsystemDeviceId': u'000C', 'model':
u'82599ES 10-Gigabit SFI/SFP+ Network Connection', 'deviceType': [None], 'deviceId': u'10FB', 'autoSense': u'off', 'subsystemVendorId': u'8086', 'revision': u'01', 'type': 'AuditHardware', 'hardwareClass':
u'NETWORK_CONTROLLER', 'adapterType': u'', 'name': u'82599ES 10-Gigabit SFI/SFP+ Network Connection'} not found
[5] [Feb 28 17:14:05] New session created (session.py|77)
[5] [Feb 28 17:14:05] Authorization request from host xxxx (application: opsi-linux-bootimage/20191114) (workers.py|215)
[5] [Feb 28 17:14:05] -----> Executing: backend_getInterface() (JsonRpc.py|133)
[5] [Feb 28 17:14:05] -----> Executing: configState_getClientToDepotserver([], u'xxx', True, []) (JsonRpc.py|133)
[5] [Feb 28 17:14:09] -----> Executing: user_getCredentials(u'pcpatch', u'xxx') (JsonRpc.py|133)
[5] [Feb 28 17:14:09] -----> Executing: backend_info() (JsonRpc.py|133)
[5] [Feb 28 17:14:09] -----> Executing: productOnClient_updateObjects(<ProductOnClient(clientId=u'xxx', productId=u'win10-x64', installationStatus=None, actionRequest=None)>) (JsonRpc.py|133)
[5] [Feb 28 17:14:11] -----> Executing: productOnClient_updateObjects(<ProductOnClient(clientId=u'xxx', productId=u'win10-x64', installationStatus=u'unknown', actionRequest=None)>) (JsonRpc.py|133)
[5] [Feb 28 17:14:11] -----> Executing: backend_info() (JsonRpc.py|133)
[5] [Feb 28 17:14:12] -----> Executing: backend_info() (JsonRpc.py|133)
[5] [Feb 28 17:14:12] -----> Executing: auditHardware_getConfig(None) (JsonRpc.py|133)
[5] [Feb 28 17:14:15] -----> Executing: auditHardwareOnHost_setObsolete(u'xxx') (JsonRpc.py|133)
[5] [Feb 28 17:14:15] -----> Executing: auditHardwareOnHost_createObjects([<AuditHardwareOnHost(hostId=u'xxx', hardwareClass=u'SYSTEM_SLOT', name=u'PCIEX16_1')>, <AuditHardwareOnHost(hostId=u'xxx', hardwareClass=u'...) (JsonRpc.py|133)
[3] [Feb 28 17:14:16] Building unique AuditHardwareOnHost constraint impossible! (SQL.py|2411)
[5] [Feb 28 17:14:17] -----> Executing: productOnClient_updateObjects(<ProductOnClient(clientId=u'xxx', productId=u'win10-x64', installationStatus=u'unknown', actionRequest=u'none')>) (JsonRpc.py|133)
[5] [Feb 28 17:14:17] -----> Executing: log_write(u'bootimage', u'Feb 28 17:03:10 [opsiinit] opsi init script started\nFeb 28 17:03:10 [opsiinit] opsi linux bootimage version: 20191114 (4.1)\nFeb 28 17:03:20 [opsiinit] \nFeb 28 17:03:20 [opsiinit] \n...) (JsonRpc.py|133)
[5] [Feb 28 17:14:20] Creating unix socket u'/var/run/opsipxeconfd/opsipxeconfd.socket' (OpsiPXEConfd.py|79)
ASUS TRX40-Pro
AMD Threadripper 3970X
Intel 10Gbit X520-DA2
Der Fehler scheint beim Hardware Audit der Netzwerkkarte aufzutreten.
Daniel
