Bin neu hier ...
Ich habe auf einer VM mit opsi 4.1 das Update laufen lassen:
opsi-package-updater -vv update
Dort erscheint:
Installing package '/var/lib/opsi/repository/win2008-r2_4.1.0.1-9.opsi'
Installing package file '/var/lib/opsi/repository/win2008-r2_4.1.0.1-9.opsi' on depot 'opsi.meine-domain.de'
Client data dir set to '/var/lib/opsi/depot'
Getting meta data from package '/var/lib/opsi/repository/win2008-r2_4.1.0.1-9.opsi'
Executing: /bin/cat "/var/lib/opsi/repository/win2008-r2_4.1.0.1-9.opsi" | /bin/cpio --quiet --extract --list
Using encoding 'UTF-8'
Executing: /bin/cat "/var/lib/opsi/repository/win2008-r2_4.1.0.1-9.opsi" | /bin/cpio --quiet --extract --make-directories --unconditional --preserve-modification-time --verbose --no-preserve-owner "OPSI*"
Exit code: 0
Executing: /bin/zcat "/tmp/.opsi.unpack.kbGvT/OPSI/OPSI.cpio.gz" | /bin/cpio --quiet --extract --list
Executing: /bin/zcat "/tmp/.opsi.unpack.kbGvT/OPSI/OPSI.cpio.gz" | /bin/cpio --quiet --extract --make-directories --unconditional --preserve-modification-time --verbose --no-preserve-owner
Exit code: 0
Creating product in backend
Creating product <NetbootProduct(id=u'win2008-r2', name=u'Windows Server 2008 R2 - x64', productVersion=u'4.1.0.1', packageVersion=u'9')>
Writing opsi package control file '/var/lib/opsi/config/products/win2008-r2_4.1.0.1-9.netboot'
Product 'win2008-r2' currently locked on depot 'opsi.meine-domain.de'
Cleaning up
Traceback:
File "/usr/lib/python2.7/dist-packages/OPSI/Backend/Depotserver.py", line 494, in installPackage
raise installingPackageError
==>>> Backend temporary error: Product 'win2008-r2' currently locked on depot 'opsi.meine-domain.de'
Traceback:
File "/usr/bin/opsi-package-updater", line 341, in <module>
exitCode = main()
File "/usr/bin/opsi-package-updater", line 312, in main
opu.processUpdates()
File "/usr/lib/python2.7/dist-packages/OPSI/Util/Task/UpdatePackages/Updater.py", line 363, in processUpdates
backend.depot_installPackage(filename=packageFile, propertyDefaultValues=propertyDefaultValues, tempDir=self.config.get('tempdir', '/tmp'))
File "<string>", line 1, in depot_installPackage
File "/usr/lib/python2.7/dist-packages/OPSI/Backend/Backend.py", line 523, in _executeMethod
return meth(**kwargs)
File "/usr/lib/python2.7/dist-packages/OPSI/Backend/Depotserver.py", line 125, in depot_installPackage
suppressPackageContentFileGeneration=suppressPackageContentFileGeneration
File "/usr/lib/python2.7/dist-packages/OPSI/Backend/Depotserver.py", line 497, in installPackage
raise BackendError(u"Failed to install package '%s' on depot '%s': %s" % (filename, depotId, installationError))
==>>> Backend error: Failed to install package '/var/lib/opsi/repository/win2008-r2_4.1.0.1-9.opsi' on depot 'opsi.meine-domain.de': Backend temporary error: Product 'win2008-r2' currently locked on depot 'opsi.meine-domain.de'
ERROR: Backend error: Failed to install package '/var/lib/opsi/repository/win2008-r2_4.1.0.1-9.opsi' on depot 'opsi.meine-domain.de': Backend temporary error: Product 'win2008-r2' currently locked on depot 'opsi.meine-domain.de'
Zudem habe ich bereits ein "remove" versucht mit dem Befehl:
opsi-package-manager -r win2008-r2
Ein Fehler ist aufgetreten:
Fehler beim Bearbeiten von Uninstall of package(s) win2008-r2 on depot u'opsi.meine-domain.de':
Failed to mount '//opsi/opsi_depot': Command '/bin/mount -t cifs -o "credentials=/tmp/.cifs-credentials.opsi" //opsi/opsi_depot /tmp/.cifs-mount.zVe1z' failed (32):
mount error(13): Permission denied
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
ERROR: Failed to process command 'remove': 1 errors during the processing of tasks.
