ich habe eben versucht auf einem frischen ubuntu 18.04 opsi 4.1 zu installieren. leider startet der opsiconfd nicht. im syslog steht folgendes:
Nov 15 13:27:13 vmtestlnx19 systemd[1]: Starting Opsi Configuration Service...
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: Traceback (most recent call last):
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: File "/usr/bin/opsiconfd", line 6, in <module>
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: from pkg_resources import load_entry_point
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 3088, in <module>
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: @_call_aside
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 3072, in _call_aside
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: f(*args, **kwargs)
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 3101, in _initialize_master_working_set
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: working_set = WorkingSet._build_master()
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 565, in _build_master
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: ws = cls()
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 558, in __init__
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: self.add_entry(entry)
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 614, in add_entry
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: for dist in find_distributions(entry, True):
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 1964, in find_on_path
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: for dist in factory(fullpath):
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 2026, in distributions_from_metadata
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: if len(os.listdir(path)) == 0:
Nov 15 13:27:13 vmtestlnx19 opsiconfd[15989]: OSError: [Errno 13] Permission denied: '/usr/local/lib/python2.7/dist-packages/xmltodict-0.12.0.dist-info'
Nov 15 13:27:13 vmtestlnx19 systemd[1]: opsiconfd.service: Control process exited, code=exited status=1
Nov 15 13:27:13 vmtestlnx19 systemd[1]: opsiconfd.service: Failed with result 'exit-code'.
Nov 15 13:27:13 vmtestlnx19 systemd[1]: Failed to start Opsi Configuration Service.
danke
richard
