ich habe mir ein IrfanView OPSI-Packet in Anlehnung an wiki/doku.php?id=userspace:irfanview_4.x gebaut.
Dieses bricht direkt am Anfang der delsub.ins ab, mit einer Fehlermeldung, die mir noch nie untergekommen ist:
Exception in CreateAndProcessScript: Handling Aktionsliste: Range check error
(290) [1] [Feb 20 15:47:53:072] [iview] Prog: force_min_loglevel: 0
(291) [1] [Feb 20 15:47:53:072] [iview] Prog: default_loglevel: 7
(292) [1] [Feb 20 15:47:53:072] [iview] Prog: debug_prog: False
(293) [1] [Feb 20 15:47:53:072] [iview] Prog: debug_lib: False
(294) [1] [Feb 20 15:47:53:072] [iview] Prog: ScriptErrorMessages: False
(295) [1] [Feb 20 15:47:53:072] [iview] Prog: AutoActivityDisplay: False
(297) [1] [Feb 20 15:47:53:119] [iview]
(298) [1] [Feb 20 15:47:53:119] [iview] ============ Version 4.12.0.25 script "p:\iview\setup.ins"
(299) [1] [Feb 20 15:47:53:119] [iview] used script encoding: cp1252
(300) [1] [Feb 20 15:47:53:119] [iview] used system encoding: cp1252
(301) [1] [Feb 20 15:47:53:119] [iview] start: 2019-02-20 15:47:53
(302) [1] [Feb 20 15:47:53:119] [iview] installing product: iview_4.52-0.12
(305) [1] [Feb 20 15:47:53:121] [iview] opsi-script running as "SYSTEM"
(306) [1] [Feb 20 15:47:53:121] [iview] opsi-script running with admin privileges
(307) [1] [Feb 20 15:47:53:121] [iview] opsi-script running in standard script mode
(308) [1] [Feb 20 15:47:53:121] [iview] executing: "C:\Program Files (x86)\opsi.org\opsi-client-agent\opsi-winst\winst32.exe"
(309) [1] [Feb 20 15:47:53:121] [iview] system infos:
(313) [1] [Feb 20 15:47:53:122] [iview] DEU - System default locale
(319) [1] [Feb 20 15:47:53:122] [iview] MS Windows 10.0 64 Bit, Release: 1809, Edition: PRODUCT_PROFESSIONAL
(320) [1] [Feb 20 15:47:53:122] [iview] opsi service version : 4
(321) [1] [Feb 20 15:47:53:122] [iview]
(326) [4] [Feb 20 15:47:53:171] [iview] Warning: depricated: <LogLevel=> please use <setLogLevel=>
(327) [1] [Feb 20 15:47:53:171] [iview] LogLevel was 7
(328) [1] [Feb 20 15:47:53:171] [iview] LogLevel set to 13
(399) [4] [Feb 20 15:47:53:180] [iview] Property not existing in GetProductProperty - using default
(485) [5] [Feb 20 15:47:53:183] [iview] comment: Show product picture
(496) [5] [Feb 20 15:47:53:196] [iview] comment: Deinstalliere alte Versionen
(499) [5] [Feb 20 15:47:53:196] [iview] message Deinstalliere alte Versionen
(508) [5] [Feb 20 15:47:53:200] [iview] comment: Start uninstall sub section
(545) [5] [Feb 20 15:47:53:227] [iview] comment: uninstall sub section [1]
(549) [3] [Feb 20 15:47:53:228] [iview] Exception in CreateAndProcessScript: Handling Aktionsliste: Range check error
(550) [1] [Feb 20 15:47:53:228] [iview] ___________________
(551) [1] [Feb 20 15:47:53:228] [iview] script finished: failed
(552) [1] [Feb 20 15:47:53:228] [iview] 0 errors
(553) [1] [Feb 20 15:47:53:228] [iview] 0 warnings
(554) [1] [Feb 20 15:47:53:228] [iview]
(555) [1] [Feb 20 15:47:53:228] [iview] installed product: iview Version: 4.52-0.12
(556) [1] [Feb 20 15:47:53:228] [iview]
comment "uninstall sub section [1]"
Set $UninstallProgram32$ = $InstallDir32$ + "\" + $Inst_Prg$
Set $UninstallProgram64$ = $InstallDir64$ + "\" + $Inst_Prg$
if (($INST_SystemType$ = "x86 System") and ($INST_architecture$ = "system specific")) or ($INST_architecture$ = "both") or ($INST_architecture$ = "32 only")
Message "Uninstalling " + $ProductName$ + " 32 Bit..."
if FileExists($UninstallProgram32$)
comment "Uninstall program found, starting uninstall"
Winbatch_uninstall_32
comment "Removing "+$InstallDir32$
Files_uninstall_32
sub_check_exitcode
if ($INST_SystemType$ = "64 Bit System") and (($INST_architecture$ = "system specific") or ($INST_architecture$ = "both") or ($INST_architecture$ = "64 only"))
Message "Uninstalling " + $ProductName$ + " 64 Bit..."
if FileExists($UninstallProgram64$)
Winbatch_uninstall_64
comment "Removing "+$InstallDir64$
Files_uninstall_64
sub_check_exitcode
comment "uninstall sub section [4]"
