[Gelöst][ValueError] Unterminated string starting at: line 1 column 2 (char 1)
Tigger
Beitrag von Tigger »
ich habe das Problem das wenn ich "Opsi Config Editor" start der mir mit folgender Fehlermeldung kommt.
Okt 18  15:53:28.341  2018 -- Opsi service error:  [ValueError] Unterminated string starting at: line 1 column 2 (char 1)
Okt 18  15:53:28.341  2018 -- JSONReMapper: Exception on reproducing  null, java.lang.NullPointerException
Nach ein wenig Recherche bin ich auf den befehl "opsi-setup --cleanup-backend" gestosen, der wirft mir folgenden raus:
Letzte Grüne Zeile:
[5] [Oct 18 16:42:58] Cleaning up config states (CleanupBackend.py|220)
[2] [Oct 18 15:42:39] Traceback: (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/bin/opsi-setup", line 1242, in <module>
    main()
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/bin/opsi-setup", line 1220, in main
    cleanupBackend()
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/dist-packages/OPSI/Util/Task/CleanupBackend.py", line 221, in cleanupBackend
    cleanUpConfigStates(backend)
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/dist-packages/OPSI/Util/Task/CleanupBackend.py", line 421, in cleanUpConfigStates
    for configState in backend.configState_getObjects():
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "<string>", line 1, in configState_getObjects
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/dist-packages/OPSI/Backend/Backend.py", line 522, in _executeMethod
    return meth(**kwargs)
 (Logger.py|798)
 (Logger.py|798)
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/dist-packages/OPSI/Backend/Backend.py", line 2477, in configState_getObjects
    for config in self._backend.config_getObjects(id=filter.get('configId')):
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "<string>", line 1, in config_getObjects
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/dist-packages/OPSI/Backend/BackendManager.py", line 437, in _dispatchMethod
    res = meth(**kwargs)
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/dist-packages/OPSI/Backend/File.py", line 1295, in config_getObjects
    return self._read('Config', attributes, **filter)
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/dist-packages/OPSI/Backend/File.py", line 834, in _read
    value = fromJson(value)
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/dist-packages/OPSI/Util/__init__.py", line 179, in fromJson
    obj = json.loads(obj)
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
    return _default_decoder.decode(s)
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
 (Logger.py|798)
[2] [Oct 18 15:42:39]   File "/usr/lib/python2.7/json/decoder.py", line 380, in raw_decode
    obj, end = self.scan_once(s, idx)
 (Logger.py|798)
[2] [Oct 18 15:42:39]      ==>>> Unterminated string starting at: line 1 column 2 (char 1) (opsi-setup|1246)
ERROR: Unterminated string starting at: line 1 column 2 (char 1)
Wenn ich im "OPSI Config Editor" / "Server-Konfiguration" Reload klicke kommt die selbe Fehlermeldung wie oben, und die liste bleibt leer. Es werden auch keine Rechner angezeigt.
Hat jemand eine Idee woran das liegen kann?
MFG Alexander
Zuletzt geändert von Tigger am 19 Okt 2018, 07:41, insgesamt 1-mal geändert.
Tigger
Re: [ValueError] Unterminated string starting at: line 1 column 2 (char 1)
habs selbst gefunden.
Ich hatte ein "remote_control" eintrag hinzugefügt in dem " enthalten waren das hat zu einem Abbruch ders Strings gefühert.
Ich hab das dann in der /var/lib/opsi/config/config.ini gelöscht und dann nochmal neu eingetragen.
Siehe da Fehler weg.
Gefunden hab ich das mit opsi-setup --cleanup-backend -l 9
Re: [Gelöst][ValueError] Unterminated string starting at: line 1 column 2 (char 1)
das könnte ein Bug sein.
Was für ein Wert war denn dort eingetragen?
