Habe mir daher einen Testkey zukommen lassen um zu prüfen, ob ich dann solch eine Installation ausführen kann. Leider sind meine Versuche bisher gescheitert.
Installiert ist OPSI wie folgt:
Ubuntu 16.04
opsi config editor Version 4.0.7.6.34 2018/01/10
opsiconfd version 4.1.1.10
opsipxeconfd version 4.1.1.9
opsi-windows-support 4.1.1-5
opsi-tftpd-hpa 5.2.8-47
dnsmasq Version 2.75
Windows 7 - x64 Version 4.1.0.0-9
root@bpc002252:/var/lib/opsi/depot/win7-x64# ls -ls
insgesamt 468
12 -rwxrwx--- 1 opsiconfd pcpatch 9488 Jun 20 09:38 create_driver_links.py
4 drwxrws--- 3 opsiconfd pcpatch 4096 Jun 15 09:23 custom
4 drwxrws--- 7 opsiconfd pcpatch 4096 Jun 15 15:58 drivers
4 -rwxrwx--- 1 opsiconfd pcpatch 1196 Jun 20 09:38 extract_driver_pack.py
4 drwxrws--- 7 opsiconfd pcpatch 4096 Jun 15 10:15 installfiles
8 -rw-rw---- 1 opsiconfd pcpatch 6717 Jun 20 09:38 nt6_repartition.opsiscript
4 drwxrws--- 3 opsiconfd pcpatch 4096 Jul 24 11:49 opsi
32 -rwxrwx--- 1 opsiconfd pcpatch 31200 Jun 20 09:38 opsipreparelib.py
40 -rwxrwx--- 1 opsiconfd pcpatch 40661 Jun 20 09:38 opsisetuplib.py
20 -rw-rw---- 1 opsiconfd pcpatch 20387 Jun 20 09:38 setup.opsiscript
76 -rwxrwx--- 1 opsiconfd pcpatch 75396 Jun 20 09:38 setup.py
20 -rwxrwx--- 1 opsiconfd pcpatch 16909 Jun 20 09:38 show_drivers.py
204 -rw-rw---- 1 opsiconfd pcpatch 205923 Jul 24 11:50 win7-x64.files
32 -rw-rw---- 1 opsiconfd pcpatch 29477 Jun 20 09:38 windows.png
4 drwxrws--- 5 opsiconfd pcpatch 4096 Jun 15 10:12 winpe
0 lrwxrwxrwx 1 root pcpatch 5 Jul 24 11:49 winpe_uefi -> winpe
In der "/lib/systemd/system/opsi-tftpd-hpa.service" habe ich folgenden Eintrag:
ExecStart=/usr/sbin/in.tftpd -v --listen --address :69 --secure /tftpboot/linux
interface=enp1s0
# Don't function as a DNS server:
port=0
# Log lots of extra information about DHCP transactions.
log-dhcp
# This range(s) is for the public interface, where dnsmasq functions
# as a proxy DHCP server providing boot information but no IP leases.
# Any ip in the subnet will do, so you may just put your server NIC ip here.
dhcp-range=192.168.2.0,proxy
# The boot filename.
#dhcp-boot=pxelinux.0,bpc002252,192.168.2.0
dhcp-boot=pxelinux.cfg/elilo.efi,bpc002252,192.168.2.0
# kill multicast
dhcp-option=vendor:PXEClient,6,2b
# Disable re-use of the DHCP servername and filename fields as extra
# option space. That's to avoid confusing some old or broken DHCP clients.
dhcp-no-override
# The known types are x86PC, PC98, IA64_EFI, Alpha, Arc_x86,
# Intel_Lean_Client, IA32_EFI, BC_EFI, Xscale_EFI and X86-64_EFI
pxe-service=X86PC, "Boot from network", pxelinux
pxe-service=X86-64_EFI, "Boot from network", pxelinux.cfg/elilo.efi
pxe-service=BC_EFI, "Boot from network", pxelinux.cfg/elilo.efi
Wenn ich bei dem Client dann UEFI aktiviere und im BIOS den UEFI einstelle, dann kommt am Client nur
>>Start PXE over IPv4, Press [ESC] to EXIT ...
root@bpc002252:/tftpboot/linux/pxelinux.cfg# ls -ls
insgesamt 268
0 prw-r--r-- 1 root root 0 Jul 24 12:00 01-80-ce-62-d6-ed-1b
0 lrwxrwxrwx 1 root pcpatch 12 Jun 15 08:13 default -> default.menu
4 -rw-rw-r-- 1 opsiconfd pcpatch 931 Feb 8 16:27 default.menu
4 -rw-rw-r-- 1 opsiconfd pcpatch 34 Feb 8 16:27 default.nomenu
4 -rw-rw-r-- 1 opsiconfd pcpatch 43 Feb 8 16:27 elilo.conf
232 -rw-rw-r-- 1 opsiconfd pcpatch 236130 Feb 8 16:27 elilo.efi
4 -rw-rw-r-- 1 opsiconfd pcpatch 166 Feb 8 16:27 install
4 -rw-rw-r-- 1 opsiconfd pcpatch 308 Feb 8 16:27 install3264
4 -rw-rw-r-- 1 opsiconfd pcpatch 206 Feb 8 16:27 install-elilo-x64
4 -rw-rw-r-- 1 opsiconfd pcpatch 194 Feb 8 16:27 install-elilo-x86
4 -rw-rw-r-- 1 opsiconfd pcpatch 182 Feb 8 16:27 install-x64
4 -rw-rw-r-- 1 opsiconfd pcpatch 60 Aug 11 2015 memtest86
Folgende Logs habe ich gefunden:
/var/log/syslog
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 available DHCP subnet: 192.168.2.0/255.255.255.0
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 vendor class: PXEClient:Arch:00007:UNDI:003016
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 PXE(enp1s0) 80:ce:62:d6:ed:1b proxy
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 Marken: enp1s0
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 Name der Bootdatei: pxelinux.cfg/elilo.efi
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 Naechster Server: 192.168.2.0
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 broadcast response
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 sent size: 1 option: 53 message-type 2
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 sent size: 4 option: 54 server-identifier 192.168.2.252
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 sent size: 9 option: 60 vendor-class 50:58:45:43:6c:69:65:6e:74
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 sent size: 17 option: 97 client-machine-id 00:52:2f:a8:07:07:c2:11:e8:a4:c3:80:ce:62...
Jul 24 12:22:05 bpc002252 dnsmasq-dhcp[2296]: 618734107 sent size: 44 option: 43 vendor-encap 06:01:03:0a:04:00:50:58:45:08:07:80:01:01...
Nachtrag:
Vollständigkeitshalber der selbe Log, wenn ich auf Legacy umschalte und die Option "UEFI" beim Client deaktiviere:
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 available DHCP subnet: 192.168.2.0/255.255.255.0
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 vendor class: PXEClient:Arch:00000:UNDI:002001
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 PXE(enp1s0) 192.168.2.170 80:ce:62:d6:ed:1b pxelinux.0
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 Marken: enp1s0
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 Name der Bootdatei: pxelinux.0
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 N▒chster Server: 192.168.2.252
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 broadcast response
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 sent size: 1 option: 53 message-type 5
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 sent size: 4 option: 54 server-identifier 192.168.2.252
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 sent size: 9 option: 60 vendor-class 50:58:45:43:6c:69:65:6e:74
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 sent size: 17 option: 97 client-machine-id 00:52:2f:a8:07:07:c2:11:e8:a4:c3:80:ce:62...
Jul 24 16:27:48 bpc002252 dnsmasq-dhcp[3469]: 1675029787 sent size: 10 option: 43 vendor-encap 47:04:80:00:00:00:06:01:02:ff
Jul 24 16:27:49 bpc002252 in.tftpd[3534]: RRQ from 192.168.2.170 filename pxelinux.0
Jul 24 16:27:49 bpc002252 in.tftpd[3534]: tftp: client does not accept options
Jul 24 16:27:49 bpc002252 in.tftpd[3535]: RRQ from 192.168.2.170 filename pxelinux.0
Jul 24 16:27:49 bpc002252 in.tftpd[3536]: RRQ from 192.168.2.170 filename pxelinux.cfg/522fa807-07c2-11e8-a4c3-80ce62d6ed1b
Jul 24 16:27:49 bpc002252 in.tftpd[3537]: RRQ from 192.168.2.170 filename pxelinux.cfg/01-80-ce-62-d6-ed-1b
Jul 24 16:27:49 bpc002252 in.tftpd[3538]: RRQ from 192.168.2.170 filename install
Jul 24 16:27:51 bpc002252 in.tftpd[3539]: RRQ from 192.168.2.170 filename miniroot.bz2
