Wim-Capture Fehlermeldung
HOsman
Beitrag von HOsman »
wir erhalten folgende Fehlermeldung beim ausführen des opsi-wim-capture Pakets:
(8165)    [5] [Jun 14 15:33:24:031] [opsi-wim-capture]   message Check for WinPE Partition ....
(8174)    [5] [Jun 14 15:33:24:034] [opsi-wim-capture]     comment: hide winpe
(8178)    [5] [Jun 14 15:33:24:035] [opsi-wim-capture]     ShellCall Executing: "C:\Windows\\cmd64.exe" /C "diskpart.exe /s c:\opsi.org\data\diskpart.txt"
(8236)    [5] [Jun 14 15:33:28:264] [opsi-wim-capture]   message Prepare winpe for snapshot ....
(8239)    [5] [Jun 14 15:33:28:266] [opsi-wim-capture]   comment: Enable PE partition....
(8325)    [5] [Jun 14 15:33:32:536] [opsi-wim-capture]   message Read network driver from pe ....
(8354)    [5] [Jun 14 15:33:32:545] [opsi-wim-capture]       comment: Read drvload line from old work.cmd ...
(8358)    [3] [Jun 14 15:33:32:546] [opsi-wim-capture]           Error on loading file: Unable to open file "Y:\opsi\work.cmd"
(8401)    [5] [Jun 14 15:33:32:549] [opsi-wim-capture]   message Create work.cmd ....
(8412)    [5] [Jun 14 15:33:32:552] [opsi-wim-capture]   comment: new >=4.0.7.4 work.cmd with opsi-script
(9199)    [5] [Jun 14 15:33:32:570] [opsi-wim-capture]   message Copy capture.opsiscript ....
(9203)    [5] [Jun 14 15:33:32:574] [opsi-wim-capture]   Execution of: Files_copy_capture_opsiscript
(9204)    [5] [Jun 14 15:33:32:574] [opsi-wim-capture]
(9219)    [3] [Jun 14 15:33:32:580] [opsi-wim-capture]     Error:  Directory Y:\opsi\ does not exist and cannot be created
(9234)    [3] [Jun 14 15:33:32:583] [opsi-wim-capture]     Error:  Directory Y:\opsi\ does not exist and cannot be created
(9237)    [5] [Jun 14 15:33:32:583] [opsi-wim-capture]   message Update opsiscript ?
(9241)    [4] [Jun 14 15:33:32:588] [opsi-wim-capture]       File "Y:\opsi\opsi-script\files\opsi-winst\winst32.exe" does not exist
(9253)    [5] [Jun 14 15:33:32:589] [opsi-wim-capture]     message Opsiscript update...
(9257)    [5] [Jun 14 15:33:32:592] [opsi-wim-capture]     Execution of: Files_copy_opsiscript
(9258)    [5] [Jun 14 15:33:32:592] [opsi-wim-capture]
(9274)    [3] [Jun 14 15:33:32:596] [opsi-wim-capture]       Error:  Directory Y:\opsi\opsi-script\ does not exist and cannot be created
(9278)    [4] [Jun 14 15:33:32:597] [opsi-wim-capture]         File "Y:\opsi\opsi-script\files\opsi-winst\winst32.exe" does not exist
(9288)    [5] [Jun 14 15:33:32:598] [opsi-wim-capture]   Execution of: Files_copy_opsiscript_u
(9289)    [5] [Jun 14 15:33:32:598] [opsi-wim-capture]
(9305)    [3] [Jun 14 15:33:32:601] [opsi-wim-capture]     Error:  Directory Y:\opsi\opsi-script\ does not exist and cannot be created
(9336)    [4] [Jun 14 15:33:32:603] [opsi-wim-capture]     Prog: Warning: Y:\opsi\work.cmd could not be saved back - will retry, error message: "Invalid filename"
(9338)    [4] [Jun 14 15:33:32:705] [opsi-wim-capture]     Prog: Warning: Y:\opsi\work.cmd could not be saved back - will retry, error message: "Invalid filename"
(9340)    [4] [Jun 14 15:33:32:809] [opsi-wim-capture]     Prog: Warning: Y:\opsi\work.cmd could not be saved back - will retry, error message: "Invalid filename"
(9342)    [4] [Jun 14 15:33:32:911] [opsi-wim-capture]     Prog: Warning: Y:\opsi\work.cmd could not be saved back - will retry, error message: "Invalid filename"
(9344)    [3] [Jun 14 15:33:33:014] [opsi-wim-capture]     Prog: Error: Y:\opsi\work.cmd could not be saved back - will not retry, error message: "Invalid filename"
(9350)    [3] [Jun 14 15:33:33:019] [opsi-wim-capture]     Error: Could not save work command file ...
(9353)    [2] [Jun 14 15:33:33:020] [opsi-wim-capture]     Error level set to fatal
(9355)    [1] [Jun 14 15:33:33:021] [opsi-wim-capture] ___________________
(9356)    [1] [Jun 14 15:33:33:021] [opsi-wim-capture] script finished: failed
(9357)    [1] [Jun 14 15:33:33:021] [opsi-wim-capture] 6 errors
(9358)    [1] [Jun 14 15:33:33:021] [opsi-wim-capture] 2 warnings
Das Paket wird mit diesen Optionen ausgeführt:
http://www.bilder-upload.eu/show.php?fi ... 043836.png
HOsman
Re: Wim-Capture Fehlermeldung
welche Version des Produkts wird eingesetzt?
niko
HOsman
es wird die Version 4.1.0.1-2 verwendet.
hosman
HOsman
ich habe den Fehler gefunden. Das wim-capture Paket sowie der OPSI-Server haben beide den Laufwerksbuchstaben Y: verwendet.
Durch das ändern von $pePartLetter$ in der setup.opsiscript Datei im wim-capture Ordner läuft das Paket ohne Probleme durch.
Hosman
