(1418) [7] [Apr 26 09:27:50] Found filesystem: ntfs with blkid tool, using now this filesystemtype. (Posix.py|1558)
(1419) [7] [Apr 26 09:27:50] Partition found =>>> number: 3, start: 112658 MB (14362 cyl), end: 116753 MB (14883 cyl), size: 4094 MB (522 cyl), type: 12, fs: ntfs, boot: False (Posix.py|1593)
(1420) [7] [Apr 26 09:27:50] Waiting for device '/dev/sda3' to appear (Posix.py|1598)
(1421) [7] [Apr 26 09:27:50] Device '/dev/sda3' found (Posix.py|1606)
(1422) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1423) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1424) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1425) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1426) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1427) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1428) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1429) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1430) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk -L --no-reread -uS -l /dev/sda (Posix.py|768)
(1431) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1432) [7] [Apr 26 09:27:50] >>> (Posix.py|845)
(1433) [7] [Apr 26 09:27:50] >>> Disk /dev/sda: 30401 cylinders, 255 heads, 63 sectors/track (Posix.py|845)
(1434) [7] [Apr 26 09:27:50] >>> Units: sectors of 512 bytes, counting from 0 (Posix.py|845)
(1435) [7] [Apr 26 09:27:50] >>> (Posix.py|845)
(1436) [7] [Apr 26 09:27:50] >>> Device Boot Start End #sectors Id System (Posix.py|845)
(1437) [7] [Apr 26 09:27:50] >>> /dev/sda1 * 2048 209717247 209715200 7 HPFS/NTFS/exFAT (Posix.py|845)
(1438) [7] [Apr 26 09:27:50] >>> /dev/sda2 209731584 230737919 21006336 7 HPFS/NTFS/exFAT (Posix.py|845)
(1439) [7] [Apr 26 09:27:50] >>> /dev/sda3 230737920 239110143 8372224 12 Compaq diagnostics (Posix.py|845)
(1440) [7] [Apr 26 09:27:50] >>> /dev/sda4 0 - 0 0 Empty (Posix.py|845)
(1441) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1442) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1443) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1444) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1445) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1446) [6] [Apr 26 09:27:50] Total sectors of disk '/dev/sda': 488397168, 512 bytes per cylinder (Posix.py|1658)
(1447) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1448) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1449) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1450) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1451) [7] [Apr 26 09:27:50] Partition sector values =>>> number: 1, start: 2048 sec, end: 209717247 sec, size: 209715200 sec (Posix.py|1643)
(1452) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1453) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1454) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1455) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1456) [7] [Apr 26 09:27:50] Partition sector values =>>> number: 2, start: 209731584 sec, end: 230737919 sec, size: 21006336 sec (Posix.py|1643)
(1457) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1458) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1459) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1460) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1461) [7] [Apr 26 09:27:50] Partition sector values =>>> number: 3, start: 230737920 sec, end: 239110143 sec, size: 8372224 sec (Posix.py|1643)
(1462) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1463) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1464) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1465) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1466) [6] [Apr 26 09:27:50] Executing: cat /sys/block/sda/queue/rotational (Posix.py|768)
(1467) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1468) [7] [Apr 26 09:27:50] >>> 0 (Posix.py|845)
(1469) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1470) [7] [Apr 26 09:27:50] Found disk =>>> dev: '/dev/sdb', size: 931.00 GB (Posix.py|950)
(1471) [6] [Apr 26 09:27:50] Executing: /sbin/modprobe edd (Posix.py|768)
(1472) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1473) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1474) [6] [Apr 26 09:27:50] Using geo_override.so for all disks. (Posix.py|1302)
(1475) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1476) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1477) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1478) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1479) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk -L --no-reread -s -uB /dev/sdb (Posix.py|768)
(1480) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1481) [7] [Apr 26 09:27:50] >>> 976762584 (Posix.py|845)
(1482) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1483) [6] [Apr 26 09:27:50] Size of disk '/dev/sdb': 1000204886016 Byte / 953869 MB (Posix.py|1441)
(1484) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1485) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1486) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1487) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1488) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk -L --no-reread -l /dev/sdb (Posix.py|768)
(1489) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1490) [7] [Apr 26 09:27:50] >>> (Posix.py|845)
(1491) [7] [Apr 26 09:27:50] >>> Disk /dev/sdb: 121601 cylinders, 255 heads, 63 sectors/track (Posix.py|845)
(1492) [7] [Apr 26 09:27:50] >>> Units: cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0 (Posix.py|845)
(1493) [7] [Apr 26 09:27:50] >>> (Posix.py|845)
(1494) [7] [Apr 26 09:27:50] >>> Device Boot Start End #cyls #blocks Id System (Posix.py|845)
(1495) [7] [Apr 26 09:27:50] >>> /dev/sdb1 0+ 121601- 121602- 976761560 83 Linux (Posix.py|845)
(1496) [7] [Apr 26 09:27:50] >>> /dev/sdb2 0 - 0 0 0 Empty (Posix.py|845)
(1497) [7] [Apr 26 09:27:50] >>> /dev/sdb3 0 - 0 0 0 Empty (Posix.py|845)
(1498) [7] [Apr 26 09:27:50] >>> /dev/sdb4 0 - 0 0 0 Empty (Posix.py|845)
(1499) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1500) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1501) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1502) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1503) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1504) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1505) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1506) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1507) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1508) [6] [Apr 26 09:27:50] Total cylinders of disk '/dev/sdb': 121601, 8225280 bytes per cylinder (Posix.py|1523)
(1509) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1510) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1511) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1512) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1513) [7] [Apr 26 09:27:50] Trying using Blkid (Posix.py|1551)
(1514) [6] [Apr 26 09:27:50] Executing: /sbin/blkid -o value -s TYPE /dev/sdb1 (Posix.py|768)
(1515) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1516) [7] [Apr 26 09:27:50] >>> ext4 (Posix.py|845)
(1517) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1518) [7] [Apr 26 09:27:50] Found filesystem: ext4 with blkid tool, using now this filesystemtype. (Posix.py|1558)
(1519) [7] [Apr 26 09:27:50] Partition found =>>> number: 1, start: 0 MB (0 cyl), end: 953875 MB (121601 cyl), size: 953875 MB (121602 cyl), type: 83, fs: ext4, boot: False (Posix.py|1593)
(1520) [7] [Apr 26 09:27:50] Waiting for device '/dev/sdb1' to appear (Posix.py|1598)
(1521) [7] [Apr 26 09:27:50] Device '/dev/sdb1' found (Posix.py|1606)
(1522) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1523) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1524) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1525) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1526) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1527) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1528) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1529) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1530) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1531) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1532) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1533) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1534) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1535) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1536) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1537) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1538) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk -L --no-reread -uS -l /dev/sdb (Posix.py|768)
(1539) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1540) [7] [Apr 26 09:27:50] >>> (Posix.py|845)
(1541) [7] [Apr 26 09:27:50] >>> Disk /dev/sdb: 121601 cylinders, 255 heads, 63 sectors/track (Posix.py|845)
(1542) [7] [Apr 26 09:27:50] >>> Units: sectors of 512 bytes, counting from 0 (Posix.py|845)
(1543) [7] [Apr 26 09:27:50] >>> (Posix.py|845)
(1544) [7] [Apr 26 09:27:50] >>> Device Boot Start End #sectors Id System (Posix.py|845)
(1545) [7] [Apr 26 09:27:50] >>> /dev/sdb1 2048 1953525167 1953523120 83 Linux (Posix.py|845)
(1546) [7] [Apr 26 09:27:50] >>> /dev/sdb2 0 - 0 0 Empty (Posix.py|845)
(1547) [7] [Apr 26 09:27:50] >>> /dev/sdb3 0 - 0 0 Empty (Posix.py|845)
(1548) [7] [Apr 26 09:27:50] >>> /dev/sdb4 0 - 0 0 Empty (Posix.py|845)
(1549) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1550) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1551) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1552) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1553) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1554) [6] [Apr 26 09:27:50] Total sectors of disk '/dev/sdb': 1953525168, 512 bytes per cylinder (Posix.py|1658)
(1555) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1556) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1557) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1558) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1559) [7] [Apr 26 09:27:50] Partition sector values =>>> number: 1, start: 2048 sec, end: 1953525167 sec, size: 1953523120 sec (Posix.py|1643)
(1560) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1561) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1562) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1563) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1564) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1565) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1566) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1567) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1568) [6] [Apr 26 09:27:50] Executing: /sbin/sfdisk --version (Posix.py|768)
(1569) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1570) [7] [Apr 26 09:27:50] >>> sfdisk from util-linux 2.25.1 (Posix.py|845)
(1571) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1572) [6] [Apr 26 09:27:50] Executing: cat /sys/block/sdb/queue/rotational (Posix.py|768)
(1573) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1574) [7] [Apr 26 09:27:50] >>> 1 (Posix.py|845)
(1575) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1576) [5] [Apr 26 09:27:50] We have more than one disk: 2 disks - looking for multi_disk_mode (opsisetuplib.py|635)
(1577) [5] [Apr 26 09:27:50] Check if disk /dev/sdb is ssd or classic (rotational) HD (opsisetuplib.py|85)
(1578) [5] [Apr 26 09:27:50] Disk /dev/sdb is rotational (Classic HD) (opsisetuplib.py|92)
(1579) [5] [Apr 26 09:27:50] dual_disk_mode is prefer_ssd - so we use disk 0 (opsisetuplib.py|651)
(1580) [5] [Apr 26 09:27:50] Using disk device /dev/sda (setup.py|337)
(1581) [5] [Apr 26 09:27:50] backup_partition_on_same_disk = False - so we use for backup disk 1 (opsisetuplib.py|664)
(1582) [5] [Apr 26 09:27:50] backup_partition_on_same_disk: False - backupdiskindex 1 (setup.py|339)
(1583) [5] [Apr 26 09:27:50] Will restore image: sal-default (setup.py|408)
(1584) [5] [Apr 26 09:27:50] Original image file name sal-default changed to internal image file name sal-default (setup.py|412)
(1585) [5] [Apr 26 09:27:50] /dev/sda1 exists as device - fine (opsisetuplib.py|198)
(1586) [5] [Apr 26 09:27:50] Partition /dev/sda1 has a correct block alignment (opsisetuplib.py|106)
(1587) [6] [Apr 26 09:27:50] Executing: blkid (Posix.py|768)
(1588) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1589) [7] [Apr 26 09:27:50] >>> /dev/sda1: LABEL="system" UUID="84DC461EDC460ABE" TYPE="ntfs" PARTUUID="31ec9a53-01" (Posix.py|845)
(1590) [7] [Apr 26 09:27:50] >>> /dev/sda2: LABEL="data" UUID="6B8338E0044DB0B7" TYPE="ntfs" PARTUUID="31ec9a53-02" (Posix.py|845)
(1591) [7] [Apr 26 09:27:50] >>> /dev/sda3: LABEL="WINPE" UUID="456090BD1ACF939A" TYPE="ntfs" PARTUUID="31ec9a53-03" (Posix.py|845)
(1592) [7] [Apr 26 09:27:50] >>> /dev/sdb1: LABEL="opsidata" UUID="f5043aa2-b5dc-4424-bc5b-caf873efb4d3" TYPE="ext4" PARTUUID="876c80f2-01" (Posix.py|845)
(1593) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1594) [6] [Apr 26 09:27:50] Executing: blkid -o value -s LABEL /dev/sda1 (Posix.py|768)
(1595) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1596) [7] [Apr 26 09:27:50] >>> system (Posix.py|845)
(1597) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1598) [5] [Apr 26 09:27:50] /dev/sda1 exists as device with label: system (opsisetuplib.py|335)
(1599) [5] [Apr 26 09:27:50] /dev/sda1 has label system (opsisetuplib.py|690)
(1600) [5] [Apr 26 09:27:50] /dev/sda1 exists as expected - fine (opsisetuplib.py|692)
(1601) [5] [Apr 26 09:27:50] /dev/sda2 exists as device - fine (opsisetuplib.py|198)
(1602) [5] [Apr 26 09:27:50] Partition /dev/sda2 has a correct block alignment (opsisetuplib.py|106)
(1603) [6] [Apr 26 09:27:50] Executing: blkid (Posix.py|768)
(1604) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1605) [7] [Apr 26 09:27:50] >>> /dev/sda1: LABEL="system" UUID="84DC461EDC460ABE" TYPE="ntfs" PARTUUID="31ec9a53-01" (Posix.py|845)
(1606) [7] [Apr 26 09:27:50] >>> /dev/sda2: LABEL="data" UUID="6B8338E0044DB0B7" TYPE="ntfs" PARTUUID="31ec9a53-02" (Posix.py|845)
(1607) [7] [Apr 26 09:27:50] >>> /dev/sda3: LABEL="WINPE" UUID="456090BD1ACF939A" TYPE="ntfs" PARTUUID="31ec9a53-03" (Posix.py|845)
(1608) [7] [Apr 26 09:27:50] >>> /dev/sdb1: LABEL="opsidata" UUID="f5043aa2-b5dc-4424-bc5b-caf873efb4d3" TYPE="ext4" PARTUUID="876c80f2-01" (Posix.py|845)
(1609) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1610) [6] [Apr 26 09:27:50] Executing: blkid -o value -s LABEL /dev/sda2 (Posix.py|768)
(1611) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1612) [7] [Apr 26 09:27:50] >>> data (Posix.py|845)
(1613) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1614) [5] [Apr 26 09:27:50] /dev/sda2 exists as device with label: data (opsisetuplib.py|335)
(1615) [5] [Apr 26 09:27:50] /dev/sda2 has label data (opsisetuplib.py|700)
(1616) [5] [Apr 26 09:27:50] /dev/sda2 exists as expected at 4 partions with label data - checking next partition (opsisetuplib.py|709)
(1617) [5] [Apr 26 09:27:50] /dev/sda3 exists as device - fine (opsisetuplib.py|198)
(1618) [5] [Apr 26 09:27:50] Partition /dev/sda3 has a correct block alignment (opsisetuplib.py|106)
(1619) [6] [Apr 26 09:27:50] Executing: blkid (Posix.py|768)
(1620) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1621) [7] [Apr 26 09:27:50] >>> /dev/sda1: LABEL="system" UUID="84DC461EDC460ABE" TYPE="ntfs" PARTUUID="31ec9a53-01" (Posix.py|845)
(1622) [7] [Apr 26 09:27:50] >>> /dev/sda2: LABEL="data" UUID="6B8338E0044DB0B7" TYPE="ntfs" PARTUUID="31ec9a53-02" (Posix.py|845)
(1623) [7] [Apr 26 09:27:50] >>> /dev/sda3: LABEL="WINPE" UUID="456090BD1ACF939A" TYPE="ntfs" PARTUUID="31ec9a53-03" (Posix.py|845)
(1624) [7] [Apr 26 09:27:50] >>> /dev/sdb1: LABEL="opsidata" UUID="f5043aa2-b5dc-4424-bc5b-caf873efb4d3" TYPE="ext4" PARTUUID="876c80f2-01" (Posix.py|845)
(1625) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1626) [6] [Apr 26 09:27:50] Executing: blkid -o value -s LABEL /dev/sda3 (Posix.py|768)
(1627) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1628) [7] [Apr 26 09:27:50] >>> WINPE (Posix.py|845)
(1629) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1630) [5] [Apr 26 09:27:50] /dev/sda3 exists as device with label: WINPE (opsisetuplib.py|335)
(1631) [5] [Apr 26 09:27:50] /dev/sda3 has label WINPE (opsisetuplib.py|717)
(1632) [5] [Apr 26 09:27:50] /dev/sda3 exists as expected - fine (opsisetuplib.py|719)
(1633) [5] [Apr 26 09:27:50] Change to backup disk with index: 1 - Device name/dev/sdb (opsisetuplib.py|729)
(1634) [5] [Apr 26 09:27:50] /dev/sdb1 exists as device - fine (opsisetuplib.py|198)
(1635) [5] [Apr 26 09:27:50] Partition /dev/sdb1 has a correct block alignment (opsisetuplib.py|106)
(1636) [6] [Apr 26 09:27:50] Executing: blkid (Posix.py|768)
(1637) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1638) [7] [Apr 26 09:27:50] >>> /dev/sda1: LABEL="system" UUID="84DC461EDC460ABE" TYPE="ntfs" PARTUUID="31ec9a53-01" (Posix.py|845)
(1639) [7] [Apr 26 09:27:50] >>> /dev/sda2: LABEL="data" UUID="6B8338E0044DB0B7" TYPE="ntfs" PARTUUID="31ec9a53-02" (Posix.py|845)
(1640) [7] [Apr 26 09:27:50] >>> /dev/sda3: LABEL="WINPE" UUID="456090BD1ACF939A" TYPE="ntfs" PARTUUID="31ec9a53-03" (Posix.py|845)
(1641) [7] [Apr 26 09:27:50] >>> /dev/sdb1: LABEL="opsidata" UUID="f5043aa2-b5dc-4424-bc5b-caf873efb4d3" TYPE="ext4" PARTUUID="876c80f2-01" (Posix.py|845)
(1642) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1643) [6] [Apr 26 09:27:50] Executing: blkid -o value -s LABEL /dev/sdb1 (Posix.py|768)
(1644) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1645) [7] [Apr 26 09:27:50] >>> opsidata (Posix.py|845)
(1646) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1647) [5] [Apr 26 09:27:50] /dev/sdb1 exists as device with label: opsidata (opsisetuplib.py|335)
(1648) [5] [Apr 26 09:27:50] /dev/sdb1 has label opsidata (opsisetuplib.py|743)
(1649) [5] [Apr 26 09:27:50] /dev/sdb1 exists as expected - fine (opsisetuplib.py|745)
(1650) [5] [Apr 26 09:27:50] /dev/sdb1 exists as device - fine (opsisetuplib.py|198)
(1651) [5] [Apr 26 09:27:50] Partition /dev/sdb1 has a correct block alignment (opsisetuplib.py|106)
(1652) [6] [Apr 26 09:27:50] Executing: blkid (Posix.py|768)
(1653) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1654) [7] [Apr 26 09:27:50] >>> /dev/sda1: LABEL="system" UUID="84DC461EDC460ABE" TYPE="ntfs" PARTUUID="31ec9a53-01" (Posix.py|845)
(1655) [7] [Apr 26 09:27:50] >>> /dev/sda2: LABEL="data" UUID="6B8338E0044DB0B7" TYPE="ntfs" PARTUUID="31ec9a53-02" (Posix.py|845)
(1656) [7] [Apr 26 09:27:50] >>> /dev/sda3: LABEL="WINPE" UUID="456090BD1ACF939A" TYPE="ntfs" PARTUUID="31ec9a53-03" (Posix.py|845)
(1657) [7] [Apr 26 09:27:50] >>> /dev/sdb1: LABEL="opsidata" UUID="f5043aa2-b5dc-4424-bc5b-caf873efb4d3" TYPE="ext4" PARTUUID="876c80f2-01" (Posix.py|845)
(1658) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1659) [6] [Apr 26 09:27:50] Executing: blkid -o value -s LABEL /dev/sdb1 (Posix.py|768)
(1660) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1661) [7] [Apr 26 09:27:50] >>> opsidata (Posix.py|845)
(1662) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1663) [5] [Apr 26 09:27:50] /dev/sdb1 exists as device with label: opsidata (opsisetuplib.py|335)
(1664) [5] [Apr 26 09:27:50] /dev/sdb1 has label opsidata (opsisetuplib.py|764)
(1665) [5] [Apr 26 09:27:50] /dev/sdb1 exists as expected - fine (opsisetuplib.py|766)
(1666) [5] [Apr 26 09:27:50] Partition numbers are now: system=1, data=2, swap=3, backup=1 (opsisetuplib.py|767)
(1667) [5] [Apr 26 09:27:50] /mntimg does not exists as directory - creating (opsisetuplib.py|343)
(1668) [6] [Apr 26 09:27:50] Executing: mkdir -p /mntimg (Posix.py|768)
(1669) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1670) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1671) [5] [Apr 26 09:27:50] /dev/sdb1 exists as device - fine (opsisetuplib.py|198)
(1672) [5] [Apr 26 09:27:50] Partition /dev/sdb1 has a correct block alignment (opsisetuplib.py|106)
(1673) [6] [Apr 26 09:27:50] Executing: blkid (Posix.py|768)
(1674) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1675) [7] [Apr 26 09:27:50] >>> /dev/sda1: LABEL="system" UUID="84DC461EDC460ABE" TYPE="ntfs" PARTUUID="31ec9a53-01" (Posix.py|845)
(1676) [7] [Apr 26 09:27:50] >>> /dev/sda2: LABEL="data" UUID="6B8338E0044DB0B7" TYPE="ntfs" PARTUUID="31ec9a53-02" (Posix.py|845)
(1677) [7] [Apr 26 09:27:50] >>> /dev/sda3: LABEL="WINPE" UUID="456090BD1ACF939A" TYPE="ntfs" PARTUUID="31ec9a53-03" (Posix.py|845)
(1678) [7] [Apr 26 09:27:50] >>> /dev/sdb1: LABEL="opsidata" UUID="f5043aa2-b5dc-4424-bc5b-caf873efb4d3" TYPE="ext4" PARTUUID="876c80f2-01" (Posix.py|845)
(1679) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1680) [6] [Apr 26 09:27:50] Executing: blkid -o value -s LABEL /dev/sdb1 (Posix.py|768)
(1681) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1682) [7] [Apr 26 09:27:50] >>> opsidata (Posix.py|845)
(1683) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1684) [5] [Apr 26 09:27:50] /dev/sdb1 exists as device with label: opsidata (opsisetuplib.py|335)
(1685) [5] [Apr 26 09:27:50] /dev/sdb1 exists as expected - fine (setup.py|484)
(1686) [5] [Apr 26 09:27:50] mountpoint /mntimg exists (opsisetuplib.py|357)
(1687) [5] [Apr 26 09:27:50] mountpoint /mntimg >> /dev/null 2>&1 (opsisetuplib.py|362)
(1688) [5] [Apr 26 09:27:50] Nothing mounted on /mntimg - fine (opsisetuplib.py|377)
(1689) [5] [Apr 26 09:27:50] /dev/sdb1 is not mounted (opsisetuplib.py|401)
(1690) [6] [Apr 26 09:27:50] Executing: sync (Posix.py|768)
(1691) [6] [Apr 26 09:27:50] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1692) [7] [Apr 26 09:27:50] Exit code: 0 (Posix.py|852)
(1693) [5] [Apr 26 09:27:50] mount /dev/sdb1 /mntimg (opsisetuplib.py|421)
(1694) [5] [Apr 26 09:27:56] /dev/sdb1 mounted on /mntimg - fine.. (opsisetuplib.py|425)
(1695) [7] [Apr 26 09:27:56] Parsing ini file '/mntimg/sal-default/img.ini' (__init__.py|518)
(1696) [7] [Apr 26 09:27:56] Trying to lock file '/mntimg/sal-default/img.ini' (0/2000) (__init__.py|216)
(1697) [7] [Apr 26 09:27:56] File '/mntimg/sal-default/img.ini' locked after 0 millis (__init__.py|237)
(1698) [7] [Apr 26 09:27:56] Finished reading file after 0.008 seconds (__init__.py|595)
(1699) [5] [Apr 26 09:27:56] Reading image meta data: filesystem: ntfs (setup.py|523)
(1700) [5] [Apr 26 09:27:56] Reading image meta data: opsiproduct: opsi-local-image-win10-x64 (setup.py|525)
(1701) [5] [Apr 26 09:27:56] Reading image meta data: imagedate: Mon Apr 23 13:03:44 2018 (setup.py|527)
(1702) [5] [Apr 26 09:27:56] Reading image meta data: AveRate: 11980.8 (setup.py|529)
(1703) [5] [Apr 26 09:27:56] Reading image meta data: GPT: False (setup.py|531)
(1704) [5] [Apr 26 09:27:56] Reading image meta data: No uefiFirstBoot entries found (setup.py|540)
(1705) [5] [Apr 26 09:27:56] Existing system partition size = 102406 (setup.py|711)
(1706) [5] [Apr 26 09:27:56] Existing winPE partition size = 4094 (setup.py|717)
(1707) [5] [Apr 26 09:27:56] change id of partition /dev/sda 1 to 07 (setup.py|760)
(1708) [6] [Apr 26 09:27:56] Executing: sfdisk --change-id /dev/sda 1 07 (Posix.py|768)
(1709) [6] [Apr 26 09:27:56] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1710) [7] [Apr 26 09:27:56] >>> sfdisk: Done (Posix.py|845)
(1711) [7] [Apr 26 09:27:56] Exit code: 0 (Posix.py|852)
(1712) [5] [Apr 26 09:27:56] change id of partition /dev/sda 3 to 12 (setup.py|762)
(1713) [6] [Apr 26 09:27:56] Executing: sfdisk --change-id /dev/sda 3 12 (Posix.py|768)
(1714) [6] [Apr 26 09:27:56] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1715) [7] [Apr 26 09:27:56] >>> sfdisk: Done (Posix.py|845)
(1716) [7] [Apr 26 09:27:56] Exit code: 0 (Posix.py|852)
(1717) [5] [Apr 26 09:27:56] Activate (set boot flag) on partition /dev/sda1 (setup.py|769)
(1718) [6] [Apr 26 09:27:56] Executing: sfdisk -A /dev/sda 1 (Posix.py|768)
(1719) [6] [Apr 26 09:27:56] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1720) [7] [Apr 26 09:27:56] >>> sfdisk: Done (Posix.py|845)
(1721) [7] [Apr 26 09:27:56] Exit code: 0 (Posix.py|852)
(1722) [6] [Apr 26 09:27:56] Executing: sfdisk -l (Posix.py|768)
(1723) [6] [Apr 26 09:27:56] Using encoding 'ANSI_X3.4-1968' (Posix.py|801)
(1724) [7] [Apr 26 09:27:56] >>> (Posix.py|845)
(1725) [7] [Apr 26 09:27:56] >>> Disk /dev/sda: 30401 cylinders, 255 heads, 63 sectors/track (Posix.py|845)
(1726) [7] [Apr 26 09:27:56] >>> Units: cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0 (Posix.py|845)
(1727) [7] [Apr 26 09:27:56] >>> (Posix.py|845)
(1728) [7] [Apr 26 09:27:56] >>> Device Boot Start End #cyls #blocks Id System (Posix.py|845)
(1729) [7] [Apr 26 09:27:56] >>> /dev/sda1 * 0+ 13054- 13055- 104857600 7 HPFS/NTFS/exFAT (Posix.py|845)
(1730) [7] [Apr 26 09:27:56] >>> /dev/sda2 13055+ 14362- 1308- 10503168 7 HPFS/NTFS/exFAT (Posix.py|845)
(1731) [7] [Apr 26 09:27:56] >>> /dev/sda3 14362+ 14883- 522- 4186112 12 Compaq diagnostics (Posix.py|845)
(1732) [7] [Apr 26 09:27:56] >>> /dev/sda4 0 - 0 0 0 Empty (Posix.py|845)
(1733) [7] [Apr 26 09:27:56] >>> (Posix.py|845)
(1734) [7] [Apr 26 09:27:56] >>> Disk /dev/sdb: 121601 cylinders, 255 heads, 63 sectors/track (Posix.py|845)
(1735) [7] [Apr 26 09:27:56] >>> Units: cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0 (Posix.py|845)
(1736) [7] [Apr 26 09:27:56] >>> (Posix.py|845)
(1737) [7] [Apr 26 09:27:56] >>> Device Boot Start End #cyls #blocks Id System (Posix.py|845)
(1738) [7] [Apr 26 09:27:56] >>> /dev/sdb1 0+ 121601- 121602- 976761560 83 Linux (Posix.py|845)
(1739) [7] [Apr 26 09:27:56] >>> /dev/sdb2 0 - 0 0 0 Empty (Posix.py|845)
(1740) [7] [Apr 26 09:27:56] >>> /dev/sdb3 0 - 0 0 0 Empty (Posix.py|845)
(1741) [7] [Apr 26 09:27:56] >>> /dev/sdb4 0 - 0 0 0 Empty (Posix.py|845)
(1742) [7] [Apr 26 09:27:56] Exit code: 0 (Posix.py|852)
(1743) [7] [Apr 26 09:27:56] MessageSubject 'backup_restore' created (Message.py|99)
(1744) [7] [Apr 26 09:27:56] ProgressSubject 'backup_restore' created (Message.py|227)
(1745) [7] [Apr 26 09:27:56] Created Progress box: <OPSI.UI.SnackProgressBox object at 0xb517d92c> (setup.py|797)
(1746) [5] [Apr 26 09:27:56] restoreImage(/dev/sda, 1, /mntimg/sal-default/sal-default.img, <ProgressSubject type: , id: backup_restore>, partclone, ntfs, False) (setup.py|61)
(1747) [5] [Apr 26 09:27:56] Image type is partclone (setup.py|128)
(1748) [6] [Apr 26 09:27:56] Restoring partclone image '/mntimg/sal-default/sal-default.img' to '/dev/sda1' (setup.py|133)
(1749) [5] [Apr 26 09:27:56] Restoring partclone image using command: partclone.restore -C --force --source /mntimg/sal-default/sal-default.img --output /dev/sda1 (setup.py|149)
(1750) [6] [Apr 26 09:27:56] Executing: partclone.restore -C --force --source /mntimg/sal-default/sal-default.img --output /dev/sda1 (Posix.py|768)
(1751) [7] [Apr 26 09:27:56] -->>> Partclone v0.2.86
http://partclone.org (setup.py|176)
(1752) [7] [Apr 26 09:27:56] -->>> Starting to restore image (/mntimg/sal-default/sal-default.img) to device (/dev/sda1) (setup.py|176)
(1753) [7] [Apr 26 09:27:56] -->>> restore: open /mntimg/sal-default/sal-default.img error (setup.py|176)
(1754) [6] [Apr 26 09:27:56] Save image: restore: open /mntimg/sal-default/sal-default.img error (setup.py|188)
(1755) [7] [Apr 26 09:27:56] -->>> Error exit (setup.py|176)
(1756) [7] [Apr 26 09:27:56] -->>> read image_hdr error (setup.py|176)
(1757) [7] [Apr 26 09:27:56] -->>> This is not partclone image. (setup.py|176)
(1758) [7] [Apr 26 09:27:56] -->>> Calculating bitmap... Please wait... done! (setup.py|176)
(1759) [7] [Apr 26 09:27:56] -->>> File system: (setup.py|176)
(1760) [6] [Apr 26 09:27:56] Save image: File system: (setup.py|188)
(1761) [7] [Apr 26 09:27:56] -->>> Device size: 0 Byte = 0 Blocks (setup.py|176)
(1762) [6] [Apr 26 09:27:56] Save image: Device size: 0 Byte = 0 Blocks (setup.py|188)
(1763) [7] [Apr 26 09:27:56] -->>> Space in use: 0 Byte = 0 Blocks (setup.py|176)
(1764) [6] [Apr 26 09:27:56] Save image: Space in use: 0 Byte = 0 Blocks (setup.py|188)
(1765) [7] [Apr 26 09:27:56] -->>> Free Space: 0 Byte = 0 Blocks (setup.py|176)
(1766) [7] [Apr 26 09:27:56] -->>> Block size: 0 Byte (setup.py|176)
(1767) [7] [Apr 26 09:27:56] -->>> timeout 1 (setup.py|223)
(1768) [7] [Apr 26 09:27:56] -->>> timeout 2 (setup.py|223)
(1769) [7] [Apr 26 09:27:56] -->>> timeout 3 (setup.py|223)
############################################################################# timeout 4-9997 entfernt
(11764) [7] [Apr 26 09:27:57] -->>> timeout 9998 (setup.py|223)
(11765) [7] [Apr 26 09:27:57] -->>> timeout 9999 (setup.py|223)
(11766) [7] [Apr 26 09:27:57] -->>> timeout 10000 (setup.py|223)
(11767) [2] [Apr 26 09:27:58] Traceback: (Logger.py|757)
(11768) [2] [Apr 26 09:27:58] File "/usr/local/bin/master.py", line 1461, in <module>
(11769) execfile(actionScript)
(11770) (Logger.py|757)
(11771) [2] [Apr 26 09:27:58] File "/tmp/setup.py", line 802, in <module>
(11772) restoreImage(diskDevice = disk.device, partition = int(systemPartitionNumber), imageType = "partclone", filesystem = filesystem, imageFile = u"%s" % (realimagefile), useGpt = useGpt, progressSubject=progressSubject)
(11773) (Logger.py|757)
(11774) [2] [Apr 26 09:27:58] File "/tmp/setup.py", line 220, in restoreImage
(11775) raise Exception(u"Failed: %s" % lastMsg)
(11776) (Logger.py|757)
(11777) [2] [Apr 26 09:27:58] ==>>> Failed: Block size: 0 Byte (master.py|1509)
(11778) [7] [Apr 26 09:27:58] Backend: <JSONRPCBackend(host=u'opsi.isw.uni-stuttgart.de', deflate=False)> (master.py|1512)
(11779) [7] [Apr 26 09:27:58] ProductId: opsi-local-image-restore (master.py|1513)
(11780) [7] [Apr 26 09:27:58] ClientId: tmp04.isw.uni-stuttgart.de (master.py|1514)
(11781) [7] [Apr 26 09:27:58] ProductOnClient: <ProductOnClient(clientId=u'tmp04.isw.uni-stuttgart.de', productId=u'opsi-local-image-restore', installationStatus=u'unknown', actionRequest=u'none')> (master.py|1515)
(11782) [7] [Apr 26 09:27:58] Executing jsonrpc method 'productOnClient_updateObjects' on host u'opsi.isw.uni-stuttgart.de' (JSONRPC.py|115)
(11783) [7] [Apr 26 09:27:58] Posting request... (JSONRPC.py|713)
(11784) [7] [Apr 26 09:27:58] Starting new HTTPS connection (0) to opsi.isw.uni-stuttgart.de:4447 (HTTP.py|648)
(11785) [7] [Apr 26 09:27:58] Connection established to: opsi.isw.uni-stuttgart.de (HTTP.py|650)
(11786) [7] [Apr 26 09:27:58] Closing connection: <httplib.HTTPSConnection instance at 0xb5132f4c> (HTTP.py|569)
(11787) [7] [Apr 26 09:27:58] Content-Type: gzip-application/json;charset=utf-8, Content-Encoding: deflate (JSONRPC.py|730)
(11788) [7] [Apr 26 09:27:58] Expecting deflated data from server (backwards compatible) (JSONRPC.py|738)
(11789) [5] [Apr 26 09:27:58] Writing log to service (master.py|1536)
