Ich habe ein kleines Testscript mittels winst32 .exe, welches einfach einen Registryschlüssel samt Unterelemente löschen soll.
Dieser enthält aber einen Umlaut und wird nicht von OPSI gefunden.
Ich habe auch schon mit dem encoding Befehl herumgespielt und das Encoding der Skriptdatei an sich geändert, aber es heisst immer der Schlüssel wird nicht gefunden.
Registry_Local_Clean_Findphone /SysNative
[Registry_Local_Clean_Findphone]
DeleteKey [HKEY_CURRENT_USER\Software\Häger+Busch]
[1] [Mrz 27 15:10:47:549] --
[1] [Mrz 27 15:10:47:550] --
[1] [Mrz 27 15:10:47:550] c:\opsi.org\log\opsi-script-part-Nh43Sk34.log
[1] [Mrz 27 15:10:47:551] opsi-script 4.12.0.7 started at 27.03.2018 09:50:22
[1] [Mrz 27 15:10:47:552] opsi-script log file with encoding utf8
[6] [Mrz 27 15:10:47:552] Using old Depot path: p:\
[1] [Mrz 27 15:10:47:554]
[1] [Mrz 27 15:10:47:555] ============ Version 4.12.0.7 script "C:\package-workbench\test2.opsiscript"
[1] [Mrz 27 15:10:47:555] used script encoding: cp1252
[1] [Mrz 27 15:10:47:556] used system encoding: cp1252
[1] [Mrz 27 15:10:47:556] start: 2018-03-27 15:10:47
[1] [Mrz 27 15:10:47:557] on client named "FV"
[1] [Mrz 27 15:10:47:558] loggedin user "Administrator"
[1] [Mrz 27 15:10:47:558] opsi-script running as "Administrator"
[1] [Mrz 27 15:10:47:559] opsi-script running with admin privileges
[1] [Mrz 27 15:10:47:560] opsi-script running in standard script mode
[1] [Mrz 27 15:10:47:560] executing: "C:\Program Files (x86)\opsi.org\opsi-client-agent\opsi-winst\winst32.exe"
[1] [Mrz 27 15:10:47:561] system infos:
[1] [Mrz 27 15:10:47:562] 08-00-27-38-B0-55 - PC hardware address
[1] [Mrz 27 15:10:47:563] FV - IP name
[1] [Mrz 27 15:10:47:564] 10.0.2.31 - IP address
[1] [Mrz 27 15:10:47:565] DEU - System default locale
[1] [Mrz 27 15:10:47:565] MS Windows 6.1 64 Bit, Edition: Enterprise Edition
[1] [Mrz 27 15:10:47:566]
[6] [Mrz 27 15:10:47:567] Registry key [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion] opened
[6] [Mrz 27 15:10:47:569] Key closed
[5] [Mrz 27 15:10:47:607] Execution of: Registry_Local_Clean_Findphone /SysNative
[5] [Mrz 27 15:10:47:609]
[6] [Mrz 27 15:10:47:611] Info: Registry key [HKEY_CURRENT_USER\Software\Häger+Busch] could not be opened by RegOpenKeyEx, Errorno 2 "Das System kann die angegebene Datei nicht finden.<"
[6] [Mrz 27 15:10:47:612] Registry key [HKEY_CURRENT_USER\] opened
[6] [Mrz 27 15:10:47:614] Info: key "Software\Häger+Busch" not found
[6] [Mrz 27 15:10:47:615] Key closed
[1] [Mrz 27 15:10:47:620] ___________________
[1] [Mrz 27 15:10:47:621] script finished: success
[1] [Mrz 27 15:10:47:622] 0 errors
[1] [Mrz 27 15:10:47:624] 0 warnings
[1] [Mrz 27 15:10:47:625]
[1] [Mrz 27 15:10:47:626]
