[GELÖST] powershellCall_list - no valid Expressionstr for a string list
isnoguter
Beitrag von isnoguter »
ich habe endlich Zeit gefunden mich mit dem Thema powershellCall zu beschäftigen. Leider finde ich meinen Fehler nicht.
Ich habe folgendes Beispiel aus dem opsi script manual kopiert. https://download.uib.de/opsi_stable/doc ... lCall_list
comment "1"
DefVar $exitcode$
set $exitcode$ = powershellCall('Get-Process -ProcessName "opsi*"')
comment "2"
DefStringList $list2$
set $list2$ = powersshellCall('Get-Process -ProcessName "opsi*"')
Log:
(133)     [5] [Mai 13 08:39:11:603] [lra_test]   comment: 1
(134)     [6] [Mai 13 08:39:11:604] [lra_test]   Set  $exitcode$ = powershellCall('Get-Process -ProcessName "opsi*"')
(135)     [5] [Mai 13 08:39:11:604] [lra_test]   PowerhellCall Executing: Get-Process -ProcessName "opsi*" ; mode: sysnative
(136)     [6] [Mai 13 08:39:11:604] [lra_test]   ShellCall Executing: "C:\WINDOWS\\cmd64.exe" /C "powershell.exe get-executionpolicy"
(137)     [6] [Mai 13 08:39:12:334] [lra_test]   ShellCall Executing: "C:\WINDOWS\\cmd64.exe" /C "powershell.exe set-executionpolicy RemoteSigned"
(138)     [6] [Mai 13 08:39:13:056] [lra_test]
(139)     [6] [Mai 13 08:39:13:056] [lra_test] Execution of tmp-internal powershell.exe winst /sysnative
(140)     [6] [Mai 13 08:39:13:602] [lra_test]   ExitCode 0
(141)     [6] [Mai 13 08:39:13:610] [lra_test]   Search "c:\opsi.org\tmp\"
(142)     [6] [Mai 13 08:39:13:610] [lra_test]   Search "c:\opsi.org\tmp\_opsiscript_*"
(143)     [6] [Mai 13 08:39:13:612] [lra_test] ShellCall Executing: "C:\WINDOWS\\cmd64.exe" /C "powershell.exe set-executionpolicy Restricted"
(144)     [6] [Mai 13 08:39:14:339] [lra_test]     The value of the variable "$exitcode$" is now: "0"
(145)     [5] [Mai 13 08:39:14:339] [lra_test]   comment: 2
(146)     [6] [Mai 13 08:39:14:340] [lra_test]   Set  $list2$ = powersshellCall('Get-Process -ProcessName "opsi*"')
(147)     [2] [Mai 13 08:39:14:341] [lra_test]   Syntax Error in Section: Actions (Command in line 45 in section: Actions; file: setup.opsiscript; section start at line: 1; origin: setup.opsiscript; line: 45): $list2$ = powersshellCall('Get-Process -ProcessName "opsi*"') -> powersshellCall('Get-Process -ProcessName "opsi*"') no valid Expressionstr for a string list
(148)     [2] [Mai 13 08:39:14:341] [lra_test]   Syntax Error in Section: Actions (Command in line 46 in section: Actions; file: setup.opsiscript; section start at line: 1; origin: setup.opsiscript; line: 46): EndIf -> expected
(149)     [1] [Mai 13 08:39:14:341] [lra_test] ___________________
(150)     [1] [Mai 13 08:39:14:341] [lra_test] script finished: failed
(151)     [1] [Mai 13 08:39:14:341] [lra_test] 2 errors
Was mache ich falsch?
Zuletzt geändert von isnoguter am 13 Mai 2020, 13:50, insgesamt 1-mal geändert.
Der-Matze
Re: powershellCall_list - no valid Expressionstr for a string list
Beitrag von Der-Matze »
ich vermute in dieser Zeile ist in powershellCall ein "s" zuviel:
Das sollte funktionieren:
set $list2$ = powershellCall('Get-Process -ProcessName "opsi*"')
Da hat sich wohl ein Typo eingeschlichen :-)
Ich werde das in der Doku korrigieren.
isnoguter
Danke. Das war der Fehler. Mir ist das echt nicht aufgefallen.
