Fehler Meldung beim Startetn vom opsi config editor
rene-fuchs
Beitrag von rene-fuchs »
seit dem Update auf die Version 4.0.7.5.22 2017/04/26 bekomme bei jedem Start des Tools folgende Fehler meldung:
Jun 16 09:59:58.521 2017 -- Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
Jun 16 09:59:58.548 2017 -- JSONReMapper: Exception on reproducing null, java.lang.NullPointerException
[3] (INFO)     [Jun 16  09:59:58.520  2017]    [Thread[Thread-24,6,main]]      de.uib.opsicommand.JSONthroughHTTPS   exception on receiving json javax.net.ssl.SSLException: SSL peer shut down incorrectly
[3] (INFO)     [Jun 16  09:59:58.520  2017]    [Thread[Thread-24,6,main]]         Exception javax.net.ssl.SSLException: SSL peer shut down incorrectly
STACK:
     sun.security.ssl.InputRecord.readV3Record(InputRecord.java:596)
     sun.security.ssl.InputRecord.read(InputRecord.java:532)
     sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:973)
     sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:930)
     sun.security.ssl.AppInputStream.read(AppInputStream.java:105)
     java.io.BufferedInputStream.fill(BufferedInputStream.java:246)
     java.io.BufferedInputStream.read1(BufferedInputStream.java:286)
     java.io.BufferedInputStream.read(BufferedInputStream.java:345)
     sun.net.www.MeteredStream.read(MeteredStream.java:134)
     java.io.FilterInputStream.read(FilterInputStream.java:133)
     sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3375)
     java.util.zip.InflaterInputStream.fill(InflaterInputStream.java:238)
     java.util.zip.InflaterInputStream.read(InflaterInputStream.java:158)
     sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:284)
     sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:326)
     sun.nio.cs.StreamDecoder.read(StreamDecoder.java:178)
     java.io.InputStreamReader.read(InputStreamReader.java:184)
     java.io.BufferedReader.fill(BufferedReader.java:161)
     java.io.BufferedReader.readLine(BufferedReader.java:324)
     java.io.BufferedReader.readLine(BufferedReader.java:389)
     de.uib.opsicommand.JSONthroughHTTP.retrieveJSONObjects(JSONthroughHTTP.java:570)
     de.uib.opsicommand.JSONthroughHTTP.retrieveJSONObject(JSONthroughHTTP.java:282)
     de.uib.opsicommand.JSONExecutioner.getListOfMaps(JSONExecutioner.java:544)
     de.uib.opsidatamodel.OpsiserviceNOMPersistenceController.retrieveListOfMapsNOM(OpsiserviceNOMPersistenceController.java:4631)
     de.uib.opsidatamodel.DataStubNOM.retrieveInstalledSoftwareInformation(DataStubNOM.java:872)
     de.uib.opsidatamodel.DataStubNOM.getInstalledSoftwareInformation(DataStubNOM.java:851)
     de.uib.opsidatamodel.OpsiserviceNOMPersistenceController.getInstalledSoftwareInformation(OpsiserviceNOMPersistenceController.java:6787)
     de.uib.configed.ConfigedMain.preloadData(ConfigedMain.java:888)
     de.uib.configed.ConfigedMain.initGui(ConfigedMain.java:422)
     de.uib.configed.ConfigedMain$3.run(ConfigedMain.java:675)
[3] (INFO)     [Jun 16  09:59:58.521  2017]    [Thread[Thread-24,6,main]]      de.uib.utilities.thread.WaitCursor    stop wait cursor 10, was located at (de.uib.opsicommand.JSONthroughHTTPS)
[3] (INFO)     [Jun 16  09:59:58.535  2017]    [Thread[Thread-24,6,main]]      de.uib.configed.gui.FShowList   created by constructor 3
[3] (INFO)     [Jun 16  09:59:58.535  2017]    [Thread[Thread-24,6,main]]      de.uib.configed.gui.FShowList   registerWithRunningInstances
[3] (INFO)     [Jun 16  09:59:58.536  2017]    [Thread[Thread-24,6,main]]      de.uib.configed.gui.FShowList   setButtons [ok]
[1] (ERROR)    [Jun 16  09:59:58.521  2017]    [Thread[Thread-24,6,main]]      de.uib.opsicommand.JSONthroughHTTPS   Exception while data reading, de.uib.opsicommand.JSONthroughHTTP$JSONCommunicationException: receiving json
[3] (INFO)     [Jun 16  09:59:58.547  2017]    [Thread[Thread-24,6,main]]      de.uib.opsicommand.JSONthroughHTTPS   retrieveJSONObject ready
[3] (INFO)     [Jun 16  09:59:58.548  2017]    [Thread[Thread-24,6,main]]      de.uib.utilities.thread.WaitCursor    stop wait cursor 10, was located at (de.uib.opsicommand.JSONthroughHTTPS)
[1] (ERROR)    [Jun 16  09:59:58.548  2017]    [Thread[Thread-24,6,main]]         JSONReMapper: Exception on reproducing  null, java.lang.NullPointerException
induce loglevel 6
induce loglevel null
[3] (INFO)     [Jun 16  09:59:58.548  2017]    [Thread[Thread-24,6,main]]      de.uib.opsidatamodel.DataStubNOM   retrieveInstalledSoftwareInformation produced softwarelist with entries 0
[3] (INFO)     [Jun 16  09:59:58.548  2017]    [Thread[Thread-24,6,main]]      de.uib.utilities.thread.WaitCursor    stop wait cursor 2, was located at (preloadData)
[3] (INFO)     [Jun 16  09:59:58.550  2017]    [Thread[Thread-24,6,main]]      de.uib.utilities.thread.WaitCursor    stop wait cursor 1, was located at (initGui)
[3] (INFO)     [Jun 16  09:59:58.599  2017]    [Thread[SwingWorker-pool-1-thread-2,5,main]]      de.uib.utilities.thread.WaitingWorker    doInBackground finished: ready, stopped, elapsedMillis < waitingSleeper.
die Meldung habe auf der CLI
java version "1.8.0_131"
kann ich den Fehler erstmal ignorieren?
Welche logs oder infos wären sinvoll für euch?
René
volkera
Re: Fehler Meldung beim Startetn vom opsi config editor
Beitrag von volkera »
Schau mal hier
viewtopic.php?f=6&t=9220#p40962
wenn ich richtig gelesen habe ist es die gleiche Fehlermeldung.
rene-fuchs
okay man hätte nur mal suchen müssen.....
.bashrc
alias opsi="/usr/bin/opsi-configed -u adminuser -p ganzgeheimesdudepw --sslversion 1"
okay damit ist der Fehler weg
