Die Datei instlog.txt wird nicht mehr an den OPSI-Server übertragen.
Programm-Versionen:
ii opsi-atftpd 0.7.dfsg-1.4
ii opsi-configed 1.4.22-1
ii opsi-depotserver 3.4-1
ii opsi-linux-bootimage 20100901-1
ii opsi-utils 3.4-4
ii opsiconfd 2.0.0.25-1
ii opsipxeconfd 0.3.8-1
ii python-opsi 3.4.0.14-1
Im Log von opsiconfd steht folgendes:
[1] [Sep 30 14:45:15] Traceback (most recent call last):
File "/usr/lib/python2.5/site-packages/twisted/internet/defer.py", line 312, in _startRunCallbacks
self._runCallbacks()
File "/usr/lib/python2.5/site-packages/twisted/internet/defer.py", line 328, in _runCallbacks
self.result = callback(self.result, *args, **kw)
File "/usr/lib/python2.5/site-packages/twisted/internet/defer.py", line 289, in _continue
self.unpause()
File "/usr/lib/python2.5/site-packages/twisted/internet/defer.py", line 285, in unpause
--- <exception caught here> ---
File "/usr/sbin/opsiconfd", line 226, in _getRpc
self.rpc = json.loads(self.query)
File "/var/lib/python-support/python2.5/simplejson/__init__.py", line 313, in loads
return _default_decoder.decode(s)
File "/var/lib/python-support/python2.5/simplejson/decoder.py", line 321, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/var/lib/python-support/python2.5/simplejson/decoder.py", line 338, in raw_decode
obj, end = self._scanner.iterscan(s, **kw).next()
File "/var/lib/python-support/python2.5/simplejson/scanner.py", line 53, in iterscan
rval, next_pos = action(m, context)
File "/var/lib/python-support/python2.5/simplejson/decoder.py", line 185, in JSONObject
value, end = iterscan(s, idx=end, context=context).next()
File "/var/lib/python-support/python2.5/simplejson/decoder.py", line 219, in JSONArray
File "/var/lib/python-support/python2.5/simplejson/decoder.py", line 158, in JSONString
return scanstring(match.string, match.end(), encoding, strict)
exceptions.ValueError: Invalid control character at: line 1 column 41 (char 41)
(opsiconfd|642)
[2] [Sep 30 14:45:15] Failed to process rpc: Invalid control character at: line 1 column 41 (char 41) (opsiconfd|646)
In Zeile 1, Zeichen 41 von instlog.txt befindet sich allerdings nur ein Leerzeichen ...
Woran könnte das liegen?
instlog.txt wird nicht von Client an Server übertragen
Re: instlog.txt wird nicht von Client an Server übertragen
http://www.opsi.org
http://www.opsi.org
dpkg -l | grep json
ii python-json 3.4-2
ii python-simplejson 1.9.2-1
ii python2.3-json 3.4-1
bitte mal die instlog.txt als zip (damit alle Zeichen erhalten bleiben) an d.oertel (at) uib.de senden.
danke
danke
http://www.opsi.org
http://www.opsi.org
Re: Ursache: Ältere Winst-Version (4.8.6)
Seit eine neuere Winst-Version installiert wurde (4.10.8.4 statt 4.8.6), funktioniert die Übertragung wieder.
