WinBatch_test
[WinBatch_test]
"C:\windows\system32\cmd.exe" /c "echo test"
WinBatch_test
[WinBatch_test]
[1] [Jan 08 11:52:52:250] --
[1] [Jan 08 11:52:52:252] --
[1] [Jan 08 11:52:52:253] C:\Users\Lukas\AppData\Local\Temp\opsi-script-part-Hs97Zn28.log
[1] [Jan 08 11:52:52:256] opsi-script 4.12.1.5 started at >>
[1] [Jan 08 11:52:52:258] opsi-script log file with encoding utf8
[1] [Jan 08 11:52:52:259] startmessage opsi-script created at CentralForm.FormCreate: 08.01.2020 11:52:43
[1] [Jan 08 11:52:52:261] Loading skin from: P:\opsi-winst-stable\files\opsi-winst\winstskin
[1] [Jan 08 11:52:52:263] startmessage StartProgramModes and create log: 08.01.2020 11:52:43
[1] [Jan 08 11:52:52:265] pm: 2 08.01.2020 11:52:43
[3] [Jan 08 11:52:52:269] readconfig failed: Perhaps got defaults
[6] [Jan 08 11:52:52:271] Depot path from readconfig: p:\
[6] [Jan 08 11:52:52:275] Restoring depot path from backup
[1] [Jan 08 11:52:52:278] Prog: force_min_loglevel: 4
[1] [Jan 08 11:52:52:281] Prog: default_loglevel: 7
[1] [Jan 08 11:52:52:284] Prog: debug_prog: False
[1] [Jan 08 11:52:52:287] Prog: debug_lib: True
[1] [Jan 08 11:52:52:290] Prog: ScriptErrorMessages: False
[1] [Jan 08 11:52:52:293] Prog: AutoActivityDisplay: False
[6] [Jan 08 11:52:52:295] Using new Depot path:
[1] [Jan 08 11:52:52:302]
[1] [Jan 08 11:52:52:305] ============ Version 4.12.1.5 script ""
[1] [Jan 08 11:52:52:308] used script encoding:
[1] [Jan 08 11:52:52:310] used system encoding: cp1252
[1] [Jan 08 11:52:52:314] start: 2020-01-08 11:52:52
[1] [Jan 08 11:52:52:317] on client named "xxx"
[1] [Jan 08 11:52:52:320] loggedin user "Lukas"
[1] [Jan 08 11:52:52:322] opsi-script running as "Lukas"
[1] [Jan 08 11:52:52:324] opsi-script running with admin privileges
[1] [Jan 08 11:52:52:327] opsi-script running in standard script mode
[1] [Jan 08 11:52:52:330] executing: "P:\opsi-winst-stable\files\opsi-winst\winst32.exe"
[1] [Jan 08 11:52:52:333] system infos:
[1] [Jan 08 11:52:52:345] 00-19-99-92-EF-27 - PC hardware address
[1] [Jan 08 11:52:52:348] xxx - IP name
[1] [Jan 08 11:52:52:350] xxx - IP address
[1] [Jan 08 11:52:52:354] DEU - System default locale
[7] [Jan 08 11:52:52:357] Registry started without redirection (64 Bit)
[1] [Jan 08 11:52:52:360] MS Windows 10.0 64 Bit, Edition: Enterprise Edition
[1] [Jan 08 11:52:52:362]
[7] [Jan 08 11:52:52:366] Registry started readonly
[7] [Jan 08 11:52:52:369] Registry started without redirection (64 Bit)
[6] [Jan 08 11:52:52:372] Registry key [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion] opened
[6] [Jan 08 11:52:52:375] Key closed
[5] [Jan 08 11:52:52:444] Execution of: WinBatch_test
[5] [Jan 08 11:52:52:448]
[6] [Jan 08 11:52:52:450] Call ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:52:453] Waiting until the called process is finished
[6] [Jan 08 11:52:52:456] Start process as invoker: Lukas
[6] [Jan 08 11:52:53:473] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:480] Call "[1] [Jan 08 11:52:52:250] --"
[6] [Jan 08 11:52:53:487] Waiting until the called process is finished
[6] [Jan 08 11:52:53:495] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:517] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:250] -- : 2
[6] [Jan 08 11:52:53:523] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:530] Call "[1] [Jan 08 11:52:52:252] --"
[6] [Jan 08 11:52:53:537] Waiting until the called process is finished
[6] [Jan 08 11:52:53:541] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:551] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:252] -- : 2
[6] [Jan 08 11:52:53:554] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:557] Call "[1] [Jan 08 11:52:52:253] C:\Users\Lukas\AppData\Local\Temp\opsi-script-part-Hs97Zn28.log"
[6] [Jan 08 11:52:53:561] Waiting until the called process is finished
[6] [Jan 08 11:52:53:564] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:572] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:253] C:\Users\Lukas\AppData\Local\Temp\opsi-script-part-Hs97Zn28.log : 2
[6] [Jan 08 11:52:53:575] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:579] Call "[1] [Jan 08 11:52:52:256] opsi-script 4.12.1.5 started at >>"
[6] [Jan 08 11:52:53:582] Waiting until the called process is finished
[6] [Jan 08 11:52:53:586] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:598] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:256] opsi-script 4.12.1.5 started at >> : 2
[6] [Jan 08 11:52:53:601] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:605] Call "[1] [Jan 08 11:52:52:258] opsi-script log file with encoding utf8"
[6] [Jan 08 11:52:53:607] Waiting until the called process is finished
[6] [Jan 08 11:52:53:610] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:623] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:258] opsi-script log file with encoding utf8 : 2
[6] [Jan 08 11:52:53:627] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:630] Call "[1] [Jan 08 11:52:52:259] startmessage opsi-script created at CentralForm.FormCreate: 08.01.2020 11:52:43"
[6] [Jan 08 11:52:53:634] Waiting until the called process is finished
[6] [Jan 08 11:52:53:637] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:650] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:259] startmessage opsi-script created at CentralForm.FormCreate: 08.01.2020 11:52:43 : 2
[6] [Jan 08 11:52:53:653] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:656] Call "[1] [Jan 08 11:52:52:261] Loading skin from: P:\opsi-winst-stable\files\opsi-winst\winstskin"
[6] [Jan 08 11:52:53:659] Waiting until the called process is finished
[6] [Jan 08 11:52:53:663] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:675] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:261] Loading skin from: P:\opsi-winst-stable\files\opsi-winst\winstskin : 2
[6] [Jan 08 11:52:53:678] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:682] Call "[1] [Jan 08 11:52:52:263] startmessage StartProgramModes and create log: 08.01.2020 11:52:43"
[6] [Jan 08 11:52:53:685] Waiting until the called process is finished
[6] [Jan 08 11:52:53:688] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:701] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:263] startmessage StartProgramModes and create log: 08.01.2020 11:52:43 : 2
[6] [Jan 08 11:52:53:705] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:708] Call "[1] [Jan 08 11:52:52:265] pm: 2 08.01.2020 11:52:43"
[6] [Jan 08 11:52:53:711] Waiting until the called process is finished
[6] [Jan 08 11:52:53:714] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:725] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:265] pm: 2 08.01.2020 11:52:43 : 2
[6] [Jan 08 11:52:53:728] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:731] Call "[3] [Jan 08 11:52:52:269] readconfig failed: Perhaps got defaults"
[6] [Jan 08 11:52:53:734] Waiting until the called process is finished
[6] [Jan 08 11:52:53:737] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:750] Exception in StartProcess_cp: Failed to execute [3] [Jan 08 11:52:52:269] readconfig failed: Perhaps got defaults : 2
[6] [Jan 08 11:52:53:753] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:756] Call "[6] [Jan 08 11:52:52:271] Depot path from readconfig: p:\"
[6] [Jan 08 11:52:53:759] Waiting until the called process is finished
[6] [Jan 08 11:52:53:762] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:774] Exception in StartProcess_cp: Failed to execute [6] [Jan 08 11:52:52:271] Depot path from readconfig: p:\ : 2
[6] [Jan 08 11:52:53:777] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:781] Call "[6] [Jan 08 11:52:52:275] Restoring depot path from backup"
[6] [Jan 08 11:52:53:784] Waiting until the called process is finished
[6] [Jan 08 11:52:53:787] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:800] Exception in StartProcess_cp: Failed to execute [6] [Jan 08 11:52:52:275] Restoring depot path from backup : 2
[6] [Jan 08 11:52:53:804] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:807] Call "[1] [Jan 08 11:52:52:278] Prog: force_min_loglevel: 4"
[6] [Jan 08 11:52:53:810] Waiting until the called process is finished
[6] [Jan 08 11:52:53:813] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:823] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:278] Prog: force_min_loglevel: 4 : 2
[6] [Jan 08 11:52:53:826] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:830] Call "[1] [Jan 08 11:52:52:281] Prog: default_loglevel: 7"
[6] [Jan 08 11:52:53:833] Waiting until the called process is finished
[6] [Jan 08 11:52:53:836] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:847] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:281] Prog: default_loglevel: 7 : 2
[6] [Jan 08 11:52:53:850] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:854] Call "[1] [Jan 08 11:52:52:284] Prog: debug_prog: False"
[6] [Jan 08 11:52:53:856] Waiting until the called process is finished
[6] [Jan 08 11:52:53:859] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:870] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:284] Prog: debug_prog: False : 2
[6] [Jan 08 11:52:53:873] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:876] Call "[1] [Jan 08 11:52:52:287] Prog: debug_lib: True"
[6] [Jan 08 11:52:53:879] Waiting until the called process is finished
[6] [Jan 08 11:52:53:883] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:893] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:287] Prog: debug_lib: True : 2
[6] [Jan 08 11:52:53:896] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:899] Call "[1] [Jan 08 11:52:52:290] Prog: ScriptErrorMessages: False"
[6] [Jan 08 11:52:53:902] Waiting until the called process is finished
[6] [Jan 08 11:52:53:905] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:916] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:290] Prog: ScriptErrorMessages: False : 2
[6] [Jan 08 11:52:53:919] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:922] Call "[1] [Jan 08 11:52:52:293] Prog: AutoActivityDisplay: False"
[6] [Jan 08 11:52:53:925] Waiting until the called process is finished
[6] [Jan 08 11:52:53:928] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:938] Exception in StartProcess_cp: Failed to execute [1] [Jan 08 11:52:52:293] Prog: AutoActivityDisplay: False : 2
[6] [Jan 08 11:52:53:941] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[6] [Jan 08 11:52:53:945] Call "[6] [Jan 08 11:52:52:295] Using new Depot path:"
[6] [Jan 08 11:52:53:948] Waiting until the called process is finished
[6] [Jan 08 11:52:53:951] Start process as invoker: Lukas
[3] [Jan 08 11:52:53:962] Exception in StartProcess_cp: Failed to execute [6] [Jan 08 11:52:52:295] Using new Depot path: : 2
[6] [Jan 08 11:52:53:966] ExitCode 0 Executed process ""C:\windows\system32\cmd.exe" /c "echo test""
[1] [Jan 08 11:52:53:973] ___________________
[1] [Jan 08 11:52:53:976] script finished: success
[1] [Jan 08 11:52:53:978] 20 errors
[1] [Jan 08 11:52:53:981] 0 warnings
[1] [Jan 08 11:52:53:984]
[1] [Jan 08 11:52:53:987]
