Just downloaded opsi-configed-setup.exe on https://download.uib.de/opsi4.1/misc/helper/
I have tried to install on 2 win7-x86. On both, i get a wrong architecture error when launch.
And i get the same error when trying to launch javaw.exe in "c:\Program Files\opsi.org\opsi-configed\bin" directory
Wrong arch in embedded java ? Or my mistake ?
Regards,
Nico
[SOLVED] Opsi-configed doesn't launch on win7 32bits
nicolaslebrun
Zuletzt geändert von nicolaslebrun am 28 Okt 2019, 10:49, insgesamt 1-mal geändert.
Re: Opsi-configed doesn't launch on win7 32bits
Not your mistake, but the configed-setup.exe is a secondary helper program which indeed addresses only the 64bit architecture.
The opsi-configed package from https://download.uib.de/opsi4.1/stable/ ... localboot/ includes the logic to select the java engine so that it matches the architecture.
If you want to use the configed on a non-opsi pc you may use the configed-setup.exe and manually correct the start menu link so that it does not call the included 64bit JRE.
Hope that helps.
Rupert
Hope that helps.
Rupert
nicolaslebrun
Thanks for your answer.
I'll manage to deliver opsi-configed package wher we really need it.
regards,
Nico
regards,
Nico
