Mises à jour de OPSI 4.0.1 et opsi4ucs 4.0.1 dans testing
poterealpopolo
Beitrag von poterealpopolo »
Chers utilisateurs de OPSI,
nous publions ces nouveaux paquets opsi pour la version testing:
opsi-winst (4.11.1.5-1)
opsi-client-agent (4.0.1-18)
opsi-adminutils (4.0.1.12-1)
nous publions ces nouveaux paquets serveur opsi pour la version testing:
opsiconfd_4.0.1.9-4_all.deb
opsi4ucs_4.0.1.4-1_all.deb
opsi4ucs-ldap-schema_4.0.1.4-1_all.deb
Bien à vous
Giuliano Di Vito
opsi-winst (4.11.1.5-1) testing; urgency=low
* wiwin32: KillProcessbyname: fix: UpperCase(exename)
-- Detlef Oertel <d.oertel@uib.de> Fri, 09 Sep 2011:17:00:00 +0200
opsi-winst (4.11.1.4-1) testing; urgency=low
* wisynth: execDOSBatch / execPython : use tempfile name with
incremented number
* wifunc: TXStringList.SaveToFile: 5 retries
* wifunc: new boolean function FuncSaveToFile
* wisynth: execDOSBatch / execPython / ExecWith : FuncSaveToFile
instead of proc saveToFile
* wisynth: execDOSBatch / execPython / ExecWith : switch to
fatal if FuncSaveToFile returns false
-- Detlef Oertel <d.oertel@uib.de> Fri, 31 Aug 2011:17:00:00 +0200
opsi-client-agent (4.0.1-18) stable; urgency=low
* opsi-winst 4.11.1.5
* go back to setacl.exe 2.2.0
* check for WMI Service before try to get MAC
-- Detlef Oertel <d.oertel@uib.de> Thu, 19 May 2011 15:00:00 +0100
opsi-client-agent (4.0.1-17) stable; urgency=low
* using setacl.exe 2.2.0 on Win2k now
* using setacl.exe 2.3.0 on not Win2k-OS
-- Bardo Wolf <b.wolf@uib.de> Tue, 31 Aug 2011 10:49:00 +0100
* opsi-deploy-client-agent 4.0.1.4
fixes handling of "_"
-- Jan Schneider <j.schneider@uib.de> Tue, 31 Aug 2011 10:49:00 +0100
opsi-client-agent (4.0.1-16) stable; urgency=low
* fixes http://redmine/issues/311
service_setup fails, if vcredist not installed
* setacl.exe 2.3.0
-- Bardo Wolf <b.wolf@uib.de> Tue, 30 Aug 2011 10:49:00 +0100
opsi-client-agent (4.0.1-15) stable; urgency=low
* opsiclientd 4.0.63
- replace %service_session% in action processor command with
current session id or none
-- Jan Schneider <j.schneider@uib.de> Wed, 17 Aug 2011 15:49:00 +0100
opsi-client-agent (4.0.1-14) experimental; urgency=low
- Use smbclient for file transfers
* new product property "allow_reboot"
opsi-client-agent (4.0.1-13) experimental; urgency=low
* opsiclient 4.0.62
- New feature: create desktops
- Fix shutdown_cancel_counter
* opsi-deploy-client-agent 4.0.1.3
- New option "-o": start opsiclientd service after installation
-- Jan Schneider <j.schneider@uib.de> Thu, 04 Aug 2011 18:32:00 +0100
opsi-adminutils (4.0.1.12-1) stable; urgency=low
* opsi config editor starts via java webstart
* new property opsiadmin for opsiconfiged
- Bardo Wolf <b.wolf@uib.de> 08 Sep 2011
opsi-adminutils (4.0.1.8-2) stable; urgency=low
* putty 0.61
* putty UTF-8
* winscp 4.3.4
- Bardo Wolf <b.wolf@uib.de> 24 Aug 2011
opsiconfd (4.0.1.9-4) stable; urgency=low
* Fix init script for restart
-- Jan Schneider <j.schneider@uib.de> Thu, 08 Sep 2011 16:03:36 +0200
opsi4ucs and opsi4ucs-ldap-schema Changelogs:
opsi4ucs (4.0.1.4-1) stable; urgency=low
* cleanup-backend productOnClient fix
-- Erol <e.ueluekmen@uib.de> Fri, 09 Sep 2011 15:26:16 +0200
opsi4ucs (4.0.1.3-1) stable; urgency=low
* Remove attribute opsiPcpatchPassword to schema
-- Erol Ueluekmen <e.ueluekmen@uib.de> Fri, 09 Sep 2011 01:32:10 +0200
opsi4ucs (4.0.1.2-1) stable; urgency=low
* opsi-setup
- cleanup-backend fix: productOnClient and productOnDepot
-- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 08 Sep 2011 13:52:53 +0200
opsi4ucs (4.0.1.1-1) stable; urgency=low
* opsi-setup:
- add params --backend-config, --update-univention
-- Jan Schneider <j.schneider@uib.de> Tue, 06 Sep 2011 16:16:02 +0200
opsi4ucs (4.0.1-3) stable; urgency=low
* Add attribute opsiPcpatchPassword to schema
-- Jan Schneider <j.schneider@uib.de> Tue, 23 Aug 2011 13:52:44 +0200
opsi4ucs (4.0.1-2) stable; urgency=low
* opsi-setup: fix creation of db user
-- Jan Schneider <j.schneider@uib.de> Tue, 16 Aug 2011 10:35:36 +0200
opsi4ucs (4.0.1-1) stable; urgency=low
* opsi-setup
- --update-ldap fixes for univention
-- Jan Schneider <j.schneider@uib.de> Mon, 15 Aug 2011 14:17:39 +0200
opsi4ucs (4.0-7) stable; urgency=low
* Added objectClass opsiProductGroup in opsi4ucs-ldap-schema
-- Erol Ueluekmen <e.ueluekmen@uib.de> Tue, 07 Dec 2010 16:31:22 +0000
http://www.opsi.org/fr
