MS-Hotfix 201103-1 schlägt fehl (Win7 64Bit w/SP1)
matth46
Beitrag von matth46 »
dpkg -l | grep opsi
ii  opsi-atftpd                             0.7.dfsg-1.4                            advanced TFTP server - opsi version with pcre, fifo and max-blksize patches
ii  opsi-configed                           4.0.1.7-3                               OPSI config editor
ii  opsi-depotserver                        4.0.1-6                                 opsi depotserver configuration package
ii  opsi-linux-bootimage                    20110117-1                              Linux-Bootimage fuer das Softwareverteilungssystem OPSI
ii  opsi-utils                              4.0.1-3                                 opsi utils
ii  opsiconfd                               4.0.1-8                                 opsi configuration service
ii  opsipxeconfd                            4.0-1                                   opsi pxe configuration daemon
ii  python-opsi                             4.0.1-21                                opsi python library
opsi-client-agent 4.0-11
Auszug instlog.err:
[1] [14.04.2011 09:54:58] ============ Version 4.10.8.14 WIN32 script "Z:\install\mshotfix\mshotfix.ins"
[1] [14.04.2011 09:54:58]              start: 2011-04-14  09:54:58
[1] [14.04.2011 09:54:58]              on client named    "client123.test.local"
[1] [14.04.2011 09:54:58]              user account    "SYSTEM"
[1] [14.04.2011 09:54:58] [executing: "C:\Program Files (x86)\opsi.org\opsi-client-agent\opsi-winst\winst32.exe"]
[1] [14.04.2011 09:54:58] system infos:
[1] [14.04.2011 09:54:58] 00:50:56:C0:00:08  -  PC hardware address
[1] [14.04.2011 09:54:58] CLIENT123.TEST.LOCAL  -  IP name
[1] [14.04.2011 09:54:58] 192.168.2.138  -  IP address
[1] [14.04.2011 09:54:58] DEU  -  System default locale
[1] [14.04.2011 09:54:58] opsi service version : 4
[1] [14.04.2011 09:54:58] LogLevel was 6
[1] [14.04.2011 09:54:58] LogLevel set to 4
[1] [14.04.2011 09:54:58]   LogLevel was 4
[1] [14.04.2011 09:54:58]   LogLevel set to 7
[1] [14.04.2011 09:54:58]   LogLevel was 7
[3] [14.04.2011 09:54:58]   Error: Fatal: Servicepack Service Pack 1 found. Required Servicepack:
[1] [14.04.2011 09:54:58] ___________________
[1] [14.04.2011 09:54:58] script finished
[1] [14.04.2011 09:54:58] 1 error
[1] [14.04.2011 09:54:58] 0 warnings
[1] [14.04.2011 09:54:58] installed Produkt: mshotfix Version: 201103-1
[1] [14.04.2011 09:54:58] opsi service version: 4
ueluekmen
Re: MS-Hotfix 201103-1 schlägt fehl (Win7 64Bit w/SP1)
Beitrag von ueluekmen »
danke für die Info. Wir haben den Fehler gefixed und werden beim nächsten Patchday (der übrigends schon kurz vor der Auslieferung steht) den Bugfix ausliefern.
e. ueluekmen
s.ehlers
Beitrag von s.ehlers »
das Paket mit dem Fix ist jetzt hoch geladen - das Problem sollte behoben sein.
Viele Grüße,
S. Ehlers
