Hi, is there any way to export software/hardware inventory to excel data? i only found creating pdf. If there isn't that could be a good suggestion to future
Anyway, what everything can i do with this inventory?
i'll be happy if i can found every user whose had some random program for example : i'm looking for users which had the latest updated microsoft office on their PC so i click microsoft office 365 and i found list with PC1,PC3,PC8 and so on
Is there some more functionality than sort them by name, version etc. and in list of only one client?
Thx for answers
Jacob
Software inventory report to excel
jakub.mrvc@gmail.com
Re: Software inventory report to excel
Hi Jacob,
I did not completely understand what you actually want to do.
it is well possible to lauch a search request and find programs installed on computers. these will be marked in the Clients tab.
if you want to export this list, press Strg+C and Strg+V in your Calc program .
furthermore, you can concatenate your search queries, if they become more complex.
hoping to help
-- no PN support --
Andre
hoping to help
-- no PN support --
Andre
For example, I want to choose one of my package and see a list of pc clients where it is instaled. I cant find how can i do this.
Or add new tab (like productId, productVersion, etc) in Opsi Configuration editor/Properties of Depots/Product default- properties to see how many times it is installed somewhere
I need to know that because i want to know how many users has installed my multi licence programs such as word
Thx
Thx
- SisterOfMercy
In opsi configed:jakub.mrvc@gmail.com hat geschrieben:For example, I want to choose one of my package and see a list of pc clients where it is instaled. I cant find how can i
selection -> define search
under 'select by opsi product criteria'
set 'opsi product/ID' to the productID of the package you would like to know about
set 'opsi product/Status' to 'installed'
-> apply
Yes, thats great thank you, but is there any chance that results will be exported to some excel format?
Jacob
Jacob
Hi Jacob,
Kind regards
You can just copy + paste this from configed.jakub.mrvc@gmail.com hat geschrieben:Yes, thats great thank you, but is there any chance that results will be exported to some excel format?
Kind regards
