Updated packages for 4.0.7 in stable and testing
News and announcements
Dear opsi users,
we released new packages to stable and testing.
openSUSE Leap 42.1 leaves the testing status and is now an officially
supported distribution for running an opsi server on.
We release an opsi netboot product for deploying Windows Server 2016.
Please keep in mind that:
- The template unattend.xml uses the pass "Nt123?"
- We tested Windows Server 2016 1607 Server Standard / Server Standard Core with
- opsi-client-agent_4.0.7.10-1
- and the package config-win10 http://download.uib.de/opsi4.0/products ... 0.6-7.opsi
We also transfered some updated packages from testing to stable. These changes have been described in more detail at viewtopic.php?f=10&t=8779
Updated documentation can be read at http://download.uib.de/opsi4.0/doc/
Changed packages in the stable branch:
Client-side:
* opsi-winst 4.11.6.10-1
* opsi-wim-capture 4.0.7.1-3
* win2016 4.0.7.1-4
* opsi-clonezilla 4.0.7.2-3
* ubuntu16-04_4.0.7.1-2
* redhat70_4.0.7.1-4
* sles12_4.0.7.1-3
* sles11sp4_4.0.7.1-3
* sles12sp1_4.0.7.1-3
To the testing branch we released a new opsi-linux-bootimage and
corresponding netboot products with compatibility for eMMC devices.
We updated our config-win10 localboot product.
Please refer to the manual for more information.
Translations for opsi-utils and python-opsi have been updated. Thanks to
all translators.
Changed packages in the testing branch:
Server-side:
* opsi-linux-bootimage 20161114-2
* python-opsi 4.0.7.28-2
* opsi-utils 4.0.7.7-3
Client-side:
* config-win10 4.0.7-2 -- changelog fehlt
* win* 4.0.7.1-4
* centos70 4.0.7.1-4
* debian 4.0.7.1-2
* debian7 4.0.7.1-3 -- version noch nicht oben
* debian8 4.0.7.1-3 -- version noch nicht oben
* opensuse13-2 4.0.7.1-3
* opensusel42-1 4.0.7.1-4
* redhat70 4.0.7.1-5
* sles11sp4 4.0.7.1-4
* sles12 4.0.7.1-4
* sles12sp1 4.0.7.1-4
* ubuntu 4.0.7.1-2
* ubuntu14-04 4.0.7.1-3
* ubuntu16-04 4.0.7.1-4
With kind regards
Niko Wenselowski
PS: Changelogs:
The changelog for python-opsi can be found at https://github.com/opsi-org/python-opsi ... /changelog
The changelog for opsi-utils can be found at https://github.com/opsi-org/opsi-utils/ ... /changelog.
config-win10 (4.0.7-2); testing; urgency=low
* fixed syntax error in profile section
-- Mathias Radtke <m.radtke@uib.de> Thu, 08 Dec 2016 12:23:00 +0100
config-win10 (4.0.7-1) ; testing urgency=low
* disable: windows updates, feedback sending, wifi sense, defender, account communication, advertising ID
-- m.radtke <m.radtke@uib.de> Tue, 10 Aug 2016 11:00:00 + 0200
windows (4.0.7.1-4) stable; urgency=low
* opsisetuplib, opsipreparelib: added eMMC compatability & EFI partitioning fix when not running on sda device
-- Mathias Radtke <m.radtke@uib.de> Fri Nov 11 12:24:53 2016 +0100
windows (4.0.7.1-3) stable; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Fri Nov 11 12:25:33 2016 +0100
windows (4.0.7.1-2) stable; urgency=low
* work.cmd: bypass other network drivers as soon as one is correctly working
-- Mathias Radtke <m.radtke@uib.de> Thu Sep 15 10:03:54 2016 +0100
centos70 (4.0.7.1-4) stable; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Fri Nov 11 12:25:18 2016 +0200
debian (4.0.7.1-2) stable; urgency=low
debian7 (4.0.7.1-3) stable; urgency=low
new property: dependency_level to install recommended or just depending packages
--Mathias Radtke <m.radtke@uib.de> Wed, Nov 16 11:35:00 2016 +0100
debian7 (4.0.7.1-2) stable; urgency=low
debian8 (4.0.7.1-3) stable; urgency=low
debian8 (4.0.7.1-2) stable; urgency=low
opensuse13-2 (4.0.7.1-3) stable; urgency=low
opensusel42-1 (4.0.7.1-4) stable; urgency=low
opensusel42_4.0.7.1-3 stable; urgency=low
* whole drive is mounted on "/"
-- Mathias Radtke <m.radtke@uib.de> Fri, 30 Sep 2016 10:00:00 +0200
opensusel42_4.0.7.1-2 stable; urgency=low
redhat70 (4.0.7.1-5) stable; urgency=low
redhat70_4.0.7.1-4 stable; urgency=low
* added new property to create different sized swap partitions
* opsisetuplib: using mkfs option -F as default
--Mathias Radtke <m.radtke@uib.de> Tue, 4 Oct 2016 17:00:00 +0200
sles11sp4 (4.0.7.1-4) stable; urgency=low
sles11sp4_4.0.7.1-3 stable; urgency=low
sles12 (4.0.7.1-4) stable; urgency=low
sles12_4.0.7.1-3 stable; urgency=low
sles12sp1 (4.0.7.1-4) stable; urgency=low
sles12sp1_4.0.7.1-3 stable; urgency=low
ubuntu (4.0.7.1-2) stable; urgency=low
ubuntu14-04 (4.0.7.1-3) stable; urgency=low
ubuntu14-04 (4.0.7.1-2) stable; urgency=low
ubuntu16-04 (4.0.7.1-4) stable; urgency=low
ubuntu16-04 (4.0.7.1-3) stable; urgency=low
-- Mathias Radtke <m.radtke@uib.de> Fri Nov 11 12:25:18 2016 +0100
ubuntu16-04_4.0.7.1-2 stable; urgency=low
* added customSwap partitioning to enable a larger swap partition
-- Mathias Radtke <m.radtke@uib.de> Thu, 06 Oct 2016 10:30:00 +0200
opsi-local-image-ubuntu (4.0.7.1-3) stable; urgency=low
opsi-local-image-opensuse13-2 (4.0.7.1-3) stable; urgency=low
* incremented package version, homogeneous versioning
opsi-linux-bootimage (20161114-2) experimental; urgency=medium
* corrected megaraid driver
* corrected nodhcp behaviour when using client boot cd
* added emmc compatability
* surface 3 is now deployable
-- Mathias Radtke <m.radtke@uib.de> Mon, 14 Nov 2016 08:00:00 +0100
opsi-clonezilla (4.0.7.2-3) stable; urgency=low
* property imageshare normally auto or empty. If auto or empty will be the opsi_images share on the clients depot
-- detlef oertel <d.oertel@uib.de> Wed, 02 Nov 2016 15:00:00 +0200
opsi-wim-capture (4.0.7.1-3) stable; urgency=low
* fix for capture on depots
* property opsi_depot_rw_host with new default auto (= empty)
-- detlef oertel <d.oertel@uib.de> Mon, 31 Oct 2016 15:00:00 +0000
opsi-wim-capture (4.0.7.1-2) stable; urgency=low
* new property: verify_clonezilla_images :
* set in clonezilla runcommand --skip-check-restorable to avoid verify or not
-- detlef oertel <d.oertel@uib.de> Thu, 27 Oct 2016 15:00:00 +0000
opsi-winst/opsi-script (4.11.6.10) stable; urgency=low
* osfuncwin: RunCommandAndCaptureOut: transfer exitcode if process could not start
* osparser: execShellCall: new parameter FatalOnFail : boolean = true
* osparser: execShellCall: returns exitcode on fail
* osparser: evaluateBoolean: FileExists* : call execshellCall with FatalOnFail=false
-- Detlef Oertel <d.oertel@uib.de> Wed, 09 Nov 2016:15:00:00 +0200
opsi-winst/opsi-script (4.11.6.9) stable; urgency=low
* osregistry: TuibRegistry.ReadEntry: use RegQueryValueExW on trdString, trdExpandString
* osregistry: fix encoding in deletekey
-- Detlef Oertel <d.oertel@uib.de> Fri, 04 Nov 2016:15:00:00 +0200
opsi-winst/opsi-script (4.11.6.8) stable; urgency=low
* osconf: global bool variable readconfig_done which is set by readconfig to true
* osparser: CreateAndProcessScript: do not call readconfig if readconfig_done
* should fix: uib#2016101810000104
-- Detlef Oertel <d.oertel@uib.de> Fri, 28 Oct 2016:15:00:00 +0200
opsi-winst/opsi-script (4.11.6.7) stable; urgency=low
* new unit oskeyboard
* linkfolder knows now parameter shortcut for key like Shift-Alt-O
-- Detlef Oertel <d.oertel@uib.de> Fri, 21 Oct 2016:15:00:00 +0200
opsi-winst/opsi-script (4.11.6.6) stable; urgency=low
* osmain: GetParameter: log error if readconfig failed
* osparser: CreateAndProcessScript: log error if readconfig failed
* osparser: CreateAndProcessScript: backup depot path and restor if rad config failed
* osparser: evaluateBoolean: Fileexists* calling execShellCall architecture dependent
* osparser: produceStinglist: getFileInfoMap32, getFileInfoMap64, getFileInfoMapSysnative
-- Detlef Oertel <d.oertel@uib.de> Thu, 20 Oct 2016:15:00:00 +0200
