New opsi 4.0.7 packages in Testing
m.scalese
Beitrag von m.scalese »
Dear opsi-users,
Today we publish new packages in Testing for opsi 4.0.7. In addition to the packages, there are also new versions of some manuals, which can be found at the following link:
http://download.uib.de/opsi4.0/testing/opsi-v407/doc/
As Testing we publish the following opsi-packages:
opsi-client-agent (4.0.7.9-2)
swaudit (4.0.7.2-1)
opsi-winst/opsi-script (4.11.6.5)
opsi-winst-test (4.11.6.4-1)
jedit (5.3.0-2)
opsi-configed (4.0.7.3.1-1)
The following OS packages are also published as testing:
Opsi-utils (4.0.7.7-1)
Opsi-linux-bootimage (20160921-1)
Python-opsi (4.0.7.26-1)
Important changes:
The package opsi-client-agent has received three important fixes in this release.
1.) The Windows Agent is now built specifically for each Supported Windows Platform. This should correct the DLL load problems. Therefore, the opsi package size is also now bigger.
2.) A bug was found in WAN / VPN mode, which came from a change on the opsihwaudit.conf. Also there is a fix in the new opsi-client-agent problem. Since the client can not be deployed via WAN / VPN in such a case, the client have to be re-deployed over the standard mechanisms on the WAN clients.
3.) The install_by_shutdown module has sporadically caused issues during operation. This should now be fixed.
As always, kind regards,
Martin Scalese
Changelogs:
opsi-client-agent (4.0.7.9-2) stable; urgency=low
* opsiclientd 4.0.90
-- Erol Ueluekmen <e.ueluekmen@uib.de> Tue, 05 Oct 2016:22:06:00 +0200
opsi-client-agent (4.0.7.9-1) stable; urgency=low
* update to openSSL 1.0.2j
* replacing opsiclientd_shutdown_starter by opsiclientd_event_starter
* opsiclientd_event_starter 4.0.7.0
* changes for installation
-- Detlef Oertel <d.oertel@uib.de> Tue, 04 Oct 2016:15:00:00 +0200
opsi-client-agent (4.0.7.8-1) stable; urgency=low
* opsiclientd 4.0.89
-- Erol Ueluekmen <e.ueluekmen@uib.de> Wed, 21 Sep 2016 15:01:01 +0200
opsiclientd (4.0.90) stable; urgency=medium
* based on python 4.0.7.26-1
* new plattform dependend build for windows
-- Erol Ueluekmen <e.ueluekmen@uib.de> Tue, 11 Oct 2016 23:32:02 +0200
opsiclientd (4.0.89) stable; urgency=low
* do not use proxy if connecting to localhost (WAN-Mode)
* based python-opsi 4.0.7.21-1
-- Erol Ueluekmen <e.ueluekmen@uib.de> Wed, 21 Sep 2016 14:58:32 +0200
swaudit (4.0.7.2-1) stable; urgency=low
* fix for readfromfile
* mask single quotes by double single quotes before sending
-- detlef oertel <d.oertel@uib.de> Wed, 12 Oct 2016 15:00:00 +0100
swaudit (4.0.7.1-1) stable; urgency=low
* code cleanup
* complete redesign of webservice connection
* requires opsi-scrip 4.11.6
* removed opsi3 support
* cleanup removed property extended_search
* removed win2k support
* usekeyfinder now has default off
* new property debug_send: Send data using one serviceall per object
-- detlef oertel <d.oertel@uib.de> Wed, 05 Oct 2016 15:00:00 +0100
opsi-winst/opsi-script (4.11.6.5) stable; urgency=low
* osjson: fix at jsonAsObjectGetKeyList
* osparser: fix at jsonAsObjectDeleteByKey
* osencoding: new overloaded version of reencode with destEncoding
* osfunc: fix TXStringlist.savetofile (use new reencode verion)
* osparser: fix reencodestr (use new reencode verion)
-- Detlef Oertel <d.oertel@uib.de> Mon, 10 Oct 2016:15:00:00 +0200
opsi-winst/opsi-script (4.11.6.4) stable; urgency=low
* osjson: jsonAsObjectGetKeyList: also true on empty keylist
* osjson: new functions: jsonAsObjectDeleteByKey, jsonAsArrayDeleteObjectByIndex
* osparser: new functions: jsonAsObjectDeleteByKey, jsonAsArrayDeleteObjectByIndex
* osencoding: : trim of found encoding ; fixes #2411 ; viewtopic.php?p=38236#p38236
* oswebservice: sendlog: no more reencoding to uft8 ; Perhaps Fehler #2408
* osparser: getMSVersionMap: Do not try to read ReleaseID if below win10; fixes #2316
* osparser / osmain: use LLCritical in fatal situations; fixes #2263
* osparser: CompareDotSeparatedNumbers (str/bool): better wrong parameter handling fixes #2045 #2369
* osparser: new boolean command savetextfilewithencoding(<list>,<filename>,<endoding>)
* osregistry: readentry: trdString, trdExpandString: expicit use empty value if 0 bytes
-- Detlef Oertel <d.oertel@uib.de> Wed, 05 Oct 2016:15:00:00 +0200
opsi-winst/opsi-script (4.11.6.3-2) stable; urgency=low
opsi-winst/opsi-script (4.11.6.3) stable; urgency=low
* osfunc: new functions: isValidUtf8String(str:string) : boolean;
getFixedUtf8String(str:string) : string;
* osparser : new opsiscript functions:
-- Detlef Oertel <d.oertel@uib.de> Thu, 08 Sep 2016:15:00:00 +0200
jedit_5.3.0-2 stable; urgency=low
* opsi-script.xml for opsi-script 4.11.6.4
-- d.oertel <d.oertel@uib.de> Tue, 11 Oct 2016 15:00:00 + 0100
opsi-winst-test (4.11.6.4-1) stable; urgency=low
* json: new test for jsonAsObjectDeleteByKey, jsonAsArrayDeleteObjectByIndex
* new test savetextfilewithencoding(<list>,<filename>,<endoding>)
-- detlef oertel <d.oertel@uib.de> Fri, 07 Oct 2016 15:00:00 +0200
opsi-configed (4.0.7.3.1-1) stable; urgency=low
* Bugfix: WakeOnLan is again working
-- Rupert Roeder <r.roeder@uib.de> Tue, 11 Oct 2016 16:30:00 + 0100
opsi-utils (4.0.7.7-1) testing; urgency=medium
* opsi-makeproductfile: new options --keep-versions, --package-version
and --product-version for non-interactive use.
* opsi-package-manager: it is now possible to specifiy a product id to
use with --new-product-id when installing a package.
This allows installation of a package with a different product id.
-- Niko Wenselowski <n.wenselowski@uib.de> Fri, 23 Sep 2016 15:44:11 +0200
opsi-utils (4.0.7.6-1) testing; urgency=medium
* Raising more specific exceptions.
* opsi-makeproductfile: set rights to created files after creation.
* opsi-makeproductfile: explicit set of default encoding to utf-8.
* Small changes to texts.
-- Niko Wenselowski <n.wenselowski@uib.de> Fri, 16 Sep 2016 09:30:57 +0200
opsi-linux-bootimage (20160921-1) testing; urgency=medium
* added support for enx<MACADDRESS> named network devices
* updated internal python-opsi-version
* /etc/init.d/opsi doesn't fail when network device is not connected
* dhclient timeout is now set to 30 seconds
-- Mathias Radtke <m.radtke@uib.de> Tue, 20 Sep 2016 15:59:41 +0200
python-opsi (4.0.7.26-1) stable; urgency=medium
* SQLite backend: Fix syntax error that may occur during an ALTER TABLE
if more than one column should be altered.
-- Niko Wenselowski <n.wenselowski@uib.de> Mon, 10 Oct 2016 17:54:42 +0200
python-opsi (4.0.7.25-1) testing; urgency=medium
* DepotserverBackend: Fix problem with package installation.
-- Niko Wenselowski <n.wenselowski@uib.de> Thu, 29 Sep 2016 18:16:54 +0200
python-opsi (4.0.7.24-1) stable; urgency=medium
* ConfigurationData: On UCS we preferably read the domain from UCR.
If this fails we resort to the Samba config file.
-- Niko Wenselowski <n.wenselowski@uib.de> Tue, 27 Sep 2016 12:37:43 +0200
python-opsi (4.0.7.23-2) stable; urgency=medium
* Correct entry in changelog.
-- Niko Wenselowski <n.wenselowski@uib.de> Mon, 26 Sep 2016 15:29:35 +0200
python-opsi (4.0.7.23-1) stable; urgency=medium
* OPSI.System.Posix: added missing 'datetime' import.
* OPSI.System.Posix: fix wrong reference in getBlockDeviceBusType
-- Niko Wenselowski <n.wenselowski@uib.de> Mon, 26 Sep 2016 13:18:20 +0200
python-opsi (4.0.7.22-1) testing; urgency=medium
* DepotserverBackend: function depot_installPackage now has parameter
'forceProductId' to force a specific product id when installing a
product. The installation will be made into the corresponding directory
of the given product id.
* OPSI.Util.File.Archive.getFileType now follows symlinks.
-- Niko Wenselowski <n.wenselowski@uib.de> Fri, 23 Sep 2016 14:15:56 +0200
python-opsi (4.0.7.21-1) stable; urgency=medium
* New BackendMethod changeWANConfig
* OPSI.System.Posix: added enx network device support
* small fix in Repository-Handling
-- Erol Ueluekmen <e.ueluekmen@uib.de> Wed, 21 Sep 2016 01:22:59 +0200
python-opsi (4.0.7.20-1) stable; urgency=medium
* Various internal refactorings.
* OPSI.System.Posix.which now throws CommandNotFoundException instead of
a basic Exception to make catching errors easier.
-- Niko Wenselowski <n.wenselowski@uib.de> Tue, 13 Sep 2016 09:39:56 +0200
python-opsi (4.0.7.19-1) testing; urgency=medium
* OPSI.Util.Task.UpdateBackend.MySQL: temporary disable foreign key checks
when altering the depotId / hostId.
-- Niko Wenselowski <n.wenselowski@uib.de> Tue, 06 Sep 2016 14:11:02 +0200
python-opsi (4.0.7.18-1) stable; urgency=medium
* OPSI.System.Posix: added sleep function when using ms-sys to write
partition
boot record
* Corrected some typos.
* Make header verify_server_cert work with current Python 2.7.
* OPSI.Util.Task.Samba.configureSamba: warn if oplocks are present in
Samba configuration.
* OPSI.System.Posix: Wait a few seconds before running ms-sys to avoid
timing problems on systems with NVME storage.
-- Niko Wenselowski <n.wenselowski@uib.de> Wed, 24 Aug 2016 17:08:55 +0200
