Dear opsi users,
I am very happy to announce that opsi has found it's way onto Github!
At https://github.com/opsi-org you will find the official repositories containing source code for components and documentation.
You will still find repositories at https://svn.opsi.org/.
As of this day not all repositories have been migrated to git.
If you find a repository with the same name on Github it is safe to assume that the git version contains the more recent code.
If there is no such repo on Github you should go with the Subversion repo.
In the future we plan to do some cleanup on svn.opsi.org and continue to publish repositories on Github - so you better keep an eye on it
With kind regards
Niko Wenselowski
opsi at Github
opsi at Github
- SisterOfMercy
Re: opsi at Github
Yay! This will hopefully make navigating the code far easier! :-D
Re: opsi at Github
I hope so!SisterOfMercy hat geschrieben:Yay! This will hopefully make navigating the code far easier!
You even can check out specific tags to compare what changed between versions
If you're at it we're happy to receive some stars on Github
