Proof of concept and design: new opsi kiosk client (Update 1)
News and announcements
Hello everyone,
we are working on a new client for the opsi kiosk mode (software-on-demand).
This is a small application 'opsiclientkiosk.exe' which will be integrated in the opsi-client-agent package in opsi 4.0.7.
At the moment it is not all finished but you may test it under some special conditions.
For testing download the zip file:
http://download.uib.de/opsi4.0/experime ... client.zip
Extract it anywhere on a 64bit Windows change to the opsikioskclient directory
and start the 'opsiclientkiosk.exe' as Administrator
The start as administrator is needed because the experimental version connect directly to the server.
The final release will connect to the local opsiclientd and will work with every user and on 32bit as well.
The application supports multiple software-on-demand groups.
We also ask interested testers to help us with the localization of this application.
This can be done on transifex.
https://www.transifex.com/signin/
Where also the other opsi GUI stuff can be translated:
https://www.transifex.com/opsi-org/opsiorg/dashboard/
After a login on transifex the link to opsi.org/opsikioskclient is:
https://www.transifex.com/opsi-org/opsi ... ntkioskpo/
We are happy on every feed back
cheers
detlef oertel
http://www.opsi.org
