New opsi produkts in 4.0.6 Stable and Testing
m.scalese
Beitrag von m.scalese »
Dear opsi-users,
We hereby publish a series of fixes as stable and as testing
The server packages, it may take some time until they become available in the stable repository.
As stable we publish:
* Opsi-local-image-capture (4.0.6.1-4) (the latest version is broken)
* Config-win10 (4.0.6-5)
* Opensuse13-2_4.0.6.2-3
* Opsi-linux-client-agent (4.0.5.9-3)
* Opsi depot server (4.0.6.4-2)
* Opsi linux boot image (20151125-3)
And as testing we publish:
* Opsi-client-agent (4.0.6.3-6) (SSL Update and fixes)
* Hwaudit (4.0.6.1-3) (SSL Update)
* Opsi-winst / opsi script (4.11.5.14-2) (SSL Update)
* Opsi-linux-client-agent (4.0.5.10-1)
* NetBoot NT6: Windows (4.0.6.2-2) (fixes for driver integration)
* NetBoot opsi-local-image NT6: Windows (4.0.6.1-3) (fixes for driver integration)
* Opsi linux boot image (20151217-1)
The testing packages can be found at:
http://download.uib.de/opsi4.0/testing/ ... /products/
Special instructions:
There are two packages that have been released as a hotfix directly Stable: opsi linux boot image (20151125-3) and opsi depot server (4.0.6.4-2)
opsi linux boot image (20151125-3) (affected only UCS installations)
In the last stable release of the bootimages (opsi linux boot image 20151125-1) something went unfortunatly wrong.
For a PXE boot examined UCS system in another folder by the PXE configuration. The required files were linked to the appropriate folder. In this operation, an error occured, which ensures that the file default is not linked correctly and therefore no PXE boot into the PXE Menu is possible.
This bug is now fixed in the hotfix from the boot image and available in the Stable repository (opsi linux boot image 20151125-3).
Should there any problem arise during PXE boot, please check /tftpboot/linux/pxelinux.cfg/default the file whether this was linked clean it after upgrading to this version. By default, this file is a symbolic link that points to default.menu.
opsi depot server (4.0.6.4-2):
This version will also be released directly into stable, since a "opsi-setup init-current-config 'must be promoted after the last update of Python opsi. Besides the version does not differ comparing to the package of the latest stable version.
opsi linux boot image (20151217-1) in testing now with Hyper-V support:
Furthermore, there are in testing Respository a boot image (including what is mentioned above hotfix) with support for Hyper-V.
From Kernel 3.19 there were side effects, which made sure that the drivers for the network card and disk did not work correctly. This has now been fixed in the opsi linux boot image 20151217-1.
Before I go, I would like to wish you all a Merry Christmas and a Happy New Year 2016!!
As always, kind regards,
Martin Scalese
Changelogs:
Win *
Windows (4.0.6.2-2) stable; urgency = low
* Setup.py: Only extend sytempartition after deletion of WinPE if DATAPARTITIONNAME CREATE OR (windows partition size = "100%")
- Detlef Oertel <d.oertel@uib.de> Wed, 16 Dec 2015: 15: 00: 00 +0200
Windows (4.0.6.2-1) stable; urgency = low
* Updated create_driver_links.py for better handling link.
* Setup.py: Fix reference to undefined variable.
* Show_drivers.py: Fixed symbolic links in byAudit (fixes # 1569); Fixed problem: directory names ending with. or
whitespace
- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 10 Dec 2015 22:25:00 +0200
opsi-local-image:
Windows (4.0.6.1-3) stable; urgency = low
whitespace
opsi-local-image-capture (4.0.6.1-4) stable; urgency = low
* Fix default for opsi_depot_rw_host (hn fix not defined error)
* New Property: checkdisk_before_capture (default = false)
* Update to openssl 1.0.2e
- Detlef Oertel <d.oertel@uib.de> Mon, 14 Dec 2015 15:00:00 +0200
opsi-local-image-capture (4.0.6.1-3) stable; urgency = low
* Preferr ServiceUrl from config.ini
- Detlef Oertel <d.oertel@uib.de> Wed, 20 Oct 2015 15:00:00 +0200
hwaudit (4.0.6.1-3) stable; urgency = low
* Fixes # 1886 update to openssl 1.0.2e in lib subdirectory (ssleay32.dll libeay32.dll)
- Bardo Wolf <b.wolf@uib.de> 08 Dec 2015
opsi-winst / opsi script (4.11.5.14-2) stable; urgency = low
- Detlef Oertel <d.oertel@uib.de> Mon, 14 Dec 2015: 15: 00: 00 +0200
opsi-client-agent (4.0.6.3-6) stable; urgency = low
* Updated opsi-deploy-client-agent to 4.0.6.11. (nw)
* Update GetMsVersionInfo (for win10)
* Call subconfig from setup script and disable update
* UpdateScript checks if it's installed to Version
* Uninstall entry for Windows now references uninstall.opsiscript (instead of uninstall.ins)
opsi-linux-client-agent (4.0.5.10-1) stable; urgency = low
* Update to opsi script / opsi script nogui 4.11.5.15
* Disabled winbind at jessie .. (Bug in winbind 4.1.7: https://bugzilla.samba.org/show_bug.cgi?id=10604)
- D.oertel <d.oertel@uib.de> Thu, September 17, 2015 15:00:00 + 0100
opsi-linux-client-agent (4.0.5.9-3) stable; urgency = low
* Fix systemd opsiclientd startscript: # Required-Start: $ network
- D.oertel <d.oertel@uib.de> Tue, 27 Oct 2015 15:00:00 + 0100
opensuse13-2_4.0.6.2-3 stable; urgency = low
* Fix (style Exception) in setup.py
- Detlef Oertel <d.oertel@uib.de> Tue, 27 Oct 2015: 15: 00: 00 +0200
opensuse13-2_4.0.6.2-2 stable; urgency = low
* Changes for 4.0.6 bootimage (> = 20150707):
* Property for Network Interface name ignored
* No copy kexec
- Detlef Oertel <d.oertel@uib.de> Mon, 13 Jul 2015: 15: 00: 00 +0200
config-win10 (4.0.6-5) stable; urgency = low
* Added new property to disable Update search
- M.radtke <m.radtke@uib.de> Tue, November 3, 2015 14:30:00 + 0100
opsi depot server (4.0.6.4-2) stable; urgency = low
* Version bumped to force init-current-config run.
- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 17 Dec 2015 16:18:22 +0100
opsi linux boot image (20151217-1) testing; urgency = medium
* Hyper-V broken drivers fixed (network & storage)
* Integrated UCS hotfix (opsi-linux-bootimage_20151125-3)
- Mathias Radtke <m.radtke@uib.de> Thu, 17 Dec 2015 14:15:51 +0100
opsi linux boot image (20151125-3) stable; urgency = medium
* Fixed broken link handling is debian / postinst
- Mathias Radtke <m.radtke@uib.de> Thu, 16 Dec 2015 12:48:17 +0100
