New opsi packages in 4.0.5 testing
News and announcements
m.scalese
Beitrag von m.scalese »
Dear opsi-users,
Today we publish new packages as testing.
Important note for the UCS Update:
In opsi4ucs the dependency to the DHCP-server has been removed. This, is in
the other distributions already so for some time. And the DHCP is not used by opsi, instead is mantained and delivered over the UCS. It may also be that the DHCP package was installed by opsi4ucs over the corresponding dependency. In these cases, after updating the Univention-dhcp package will be displayed as not needed. In the case that you actually receive a warning message because of the DHCP-package is no longer needed, you can manually mark the package as installed with the following
command:
univention-install univention-dhcp
In a nutshell, here are the following OS packages:
opsi4ucs (4.0.5.8-1) python-opsi (4.0.5.20-1)
Changelog:
opsi4ucs (4.0.5.8-1) stable; urgency = low
* Dependency univention DHCP removed.
- Erol Ueluekmen <e.ueluekmen@uib.de> Tue, July 7, 2015 10:28:18 +0200
Python opsi (4.0.5.20-1) stable; urgency = medium
* Hwaudit: Added translations for COMPUTER_SYSTEM.sku
- Niko Wenselowski <n.wenselowski@uib.de> Tue, July 7, 2015 17:04:11 +0200
As always, kind regards,
Martin Scalese.
