opsi 4.0.1 updates in Stable und Testing
bhubal
Beitrag von bhubal »
Dear opsi customers,
the following packages are released as stable or as testing:
STABLE:
os-packages:
opsi-configed (4.0.1.24-1)
opsi-linux-bootimage (20120119-1)
opsi-utils (4.0.1.16-1)
opsi-packages:
jedit 4.5-1
opsi-winst 4.11.2.5-1
opsi-winst-test 4.11.2.3-1
opsi-template 4.0.1-5
nt6 Produkte 4.0.1-10
config-win-base 4.0.1-1
opsi-client-agent 4.0.1-26
TESTING:
opsi-packages:
jedit 4.5-2
opsi-winst 4.11.2.6-1
+ opsi-winst-manual
+ opsi-winst-reference-card
Please notice, that it may take some time until the os-packages are released in all repositories.
The topics:
STABLE:
- treeview modul available for free
- Security Update SSL libraries
- Internationalization (especially for french)
- Product config-win-base replaces xpconfig
- Div. bug fixes and improvements
TESTING:
- opsi-winst 4.11.2.6 with ChangeDirectory command
With kind regards
B. Hubal
Die Changelogs:
opsi-linux-bootimage (20120119-1) stable; urgency=low
* kernel 3.2.1
* fix french-localisation
* added gptfdisk toolset
* python-opsi 4.0.1.37-1
-- Erol Ueluekmen <e.ueluekmen@uib.de> Thu, 19 Jan 2012 15:01:04 +0100
opsi-linux-bootimage (20111114-1) stable; urgency=low
* kernel 3.1.1
* python-opsi 4.0.1.35-1: createPartitions: Added BlockAlignment support
-- Erol Ueluekmen <e.ueluekmen@uib.de> Mon, 14 Nov 2011 16:01:19 +0100
opsi-linux-bootimage (20111106-1) stable; urgency=low
* kernel 3.0.8
* python-opsi 4.0.1.33-1
-- Erol Ueluekmen <e.ueluekmen@uib.de> Sun, 06 Nov 2011 23:19:17 +0100
opsi-utils (4.0.1.16-1) stable; urgency=low
* opsi-product-updater: autoSetup is not allowed for netbootproduct.
-- Erol Ueluekmen <e.ueluekmen@uib.de> Wed, 21 Dec 2011 15:32:06 +0100
opsi-configed (4.0.1.22-1) testing; urgency=low
* no more dependency of the treeview from the existence of the
corresponding module
* fix of the bug that filter activation was not displayed in the
context menu
* new editing function for mac and ip addresses
-- Rupert Roeder <r.roeder@uib.de> Fri, 09 Dec 2011 12:38:32 +0200
opsi-configed (4.0.1.21-1) testing; urgency=low
* keyboard call for remote control tool
opsi-configed (4.0.1.20-1) testing; urgency=low
* Report column shows failed in addition to cancelled when an installation
"failed" by being cancelled
-- Rupert Roeder <r.roeder@uib.de> Thu, 02 Dec 2011 12:38:32 +0200
opsi-configed (4.0.1.19-1) testing; urgency=low
* Supergroup GROUPS independently inserted into tree
-- Rupert Roeder <r.roeder@uib.de> Thu, 01 Dec 2011 10:38:32 +0200
opsi-configed (4.0.1.18-1) testing; urgency=low
* Remote controls can be activated by space key
* Context menu in client list is activated by shift-F10 (as the
standard requires
* Bugfix: The list editor updates its data when the data in the
calling table changes
-- Rupert Roeder <r.roeder@uib.de> Wed, 30 Nov 2011 14:38:32 +0200
opsi-template (4.0.1-5) stable; urgency=low
* added /nocancel at Inno example
* added login.ins for 'user profile management'
* moved changelog to control file
-- detlef oertel <d.oertel@uib.de> Mon, 02 Jan 2012 16:01:53 +0200
opsi-template (4.0.1-4) stable; urgency=low
* removed uncommented test for installation success via registry entries
-- detlef oertel <d.oertel@uib.de> Thu, 30 Nov 2011 16:01:53 +0200
jedit_4.5-2 stable; urgency=low
* updated opsi-winst mode file (4.11.2.6): ChangeDirectory
-- detlef oertel <d.oertel@uib.de> Wed, 13 Feb 2012 16:01:53 +0200
jedit_4.5-1 stable; urgency=low
* update to version 4.5
* propery startserver (default=off)
-- detlef oertel <d.oertel@uib.de> Wed, 02 Jan 2012 16:01:53 +0200
jedit_4.4.1-4 stable; urgency=low
* modify mode file FILE_NAME_GLOB="*.asciidoc"
-- karsten köpke <k.koepke@uib.de> Wed, 05 Oct 2011 16:01:53 +0200
jedit_4.4.1-3 stable; urgency=low
* updatet opsi-winst mode file (4.11.2.1): profileactions
-- detlef oertel <d.oertel@uib.de> Wed, 05 Oct 2011 16:01:53 +0200
jedit_4.4.1-2 stable; urgency=low
* added /SUPPRESSMSGBOXES to setup call and comment out autoit call
* version 4.3 removed
* test for java 1.6 and 1.7
opsi-winst (4.11.2.6) stable; urgency=low
* new winst function: ChangeDirectory <dir>
- set the working directory of the winst to <dir>
- will be reset to the start value at the end of every script
-- Detlef Oertel <d.oertel@uib.de> Fri, 13 Feb 2012:15:00:00 +0200
opsi-winst (4.11.2.5) stable; urgency=low
* update openSSL to 1.0.0g
(http://www.openssl.org/news/secadv_20120118.txt)
-- Detlef Oertel <d.oertel@uib.de> Fri, 20 Jan 2012:15:00:00 +0200
opsi-winst (4.11.2.4) stable; urgency=low
* added: wisynth: getProductMap: actionrequest
-- Detlef Oertel <d.oertel@uib.de> Fri, 13 Jan 2012:15:00:00 +0200
opsi-client-agent (4.0.1-26) stable; urgency=low
* opsi-winst 4.11.2.5
* change: setup.ins: DosInAnIcon_lock_opsiclientagent : make winst
executable for user
* opsiclientd 4.0.68:
* fix: WAN/VPN localhost Bad FQDN
* fix: delete configs from config-file which are deleted from
Hostparamaters
* fix: wait for trusted installer only when gui_startup event and no
user is logged in (on booting nt6)
* added: french localization of messages in in opsiclientd.conf
-- Detlef Oertel <d.oertel@uib.de> Fri, 20 Jan 2012 15:00:00 +0100
windows (4.0.1-10) stable; urgency=low
* multilanguage control file
* additional locales and keyboard layouts
-- uib GmbH <info@uib.de> Tue, 24 Jan 2012 14:19:15 +0000
windows (4.0.1-9) stable; urgency=low
* blockAlignment added.
-- uib GmbH <info@uib.de> Wed, 16 Nov 2011 11:06:24 +0000
windows (4.0.1-8) stable; urgency=low
* descriptions now englisch
* Added new properties for patching unattend.xml Component
Microsoft-Windows-International-Core-WinPE
winpe_uilanguage
winpe_uilanguage_fallback
winpe_inputlocale
* added new properties to unattend.xml.template
* show_drivers.py
-- bardo wolf <b.wolf@uib.de> Mon, 31 Oct 2011 09:09:50 +0000
windows (4.0.1-7) stable; urgency=low
* unattend.xml patched for postinst-routines like 2008-r2
* show_drivers.py modified to show right list of drivers; now with
messages for duplicate drivers.
-- uib GmbH <info@uib.de> Thu, 22 Sep 2011 14:19:15 +0000
windows (4.0.1-6) stable; urgency=low
* Remove Display settings from unattend.xml.template
-- uib GmbH <info@uib.de> Thu, 25 Aug 2011 12:25:50 +0000
opsi-winst-test (4.11.2-3) stable; urgency=low
* fix in registry test
-- detlef oertel <d.oertel@uib.de> Thu, 02 Feb 2012 17:00:13 +0200
config-win-base (4.0.1-1) stable; urgency=low
* deleted: ProductProperties for flag_networkpostscriptprinter,
networkpostscriptprintername, networkpostscriptprinterurl
* consolidation: one Property to show all systemfiles
* flag_i386Path changed for more facilities, default no change
* renamed from xpconfig
* required winst >= 4.11.2
* use of [profile actions] and user profile management support
* flag_numlockon: default switched to 0
* new property: force_login_script
* removed: noStandardShares (moved to config-secure)
-- karsten koepke <k.koepke@uib.de> Wed, 12.Dez 2011 8:44:00 +0200
