opsi 4.0 updates
bhubal
opsi 4.0 updates
Beitrag von bhubal »
Dear opsi users,
we published the following opsi-products:
As testing:
- opsi-client-agent_4.0-13.opsi (from 2011/01/28 see here below))
and
- opsi-winst 4.10.8.14
This version fixes an error calling 'opsiLicenseManagementEnabled'
This error exist probably since opsi-winst 4.10.8.9 (testing)
Regards B. Hubal
Here the changelogs since the actual stable version : 4.10.8.7
opsi-winst (4.10.8.14) stable; urgency=low
* widatamodul: TOpsi4Data.getOpsiModules : ISuperObject; with opsi 4 methods
-- Detlef Oertel <d.oertel@uib.de> Tue, 28 Dec 2010:17:00:00 +0200
opsi-winst (4.10.8.13) stable; urgency=low
* widatamodul: TOpsiMethodCall.getJsonHashListString:
to avoid datatype conversion values can be prefixed with:
'opsistring:'
opsi-winst (4.10.8.12) stable; urgency=low
* new constants: %CurrentAppDataDir%, %ScriptDir%, %CommonProfileDir%,
* constant names changed: %StartmenuDir% -> %CurrentStartmenuDir%,
%DesktopDir% -> %CurrentDesktopDir%,
%StartupDir% -> %CurrentStartupDir%,
%ProgramsDir% -> %CurrentProgramsDir%,
%SendToDir% -> %CurrentSendToDir%
-- Detlef Oertel <d.oertel@uib.de> Fri, 10 Dec 2010:17:00:00 +0200
opsi-winst (4.10.8.11-1) stable; urgency=low
* wimemo: window in screen center, larger font, no more autosize -> for showmessagefile, fixes #184
* wisynth: product / version at the end of the log , fixes #110
* wimain: ProcessNonZeroScript: logmessage 'no script file name given' now LLNotice instead of warning
* wisynth: getLocaleInfoMap: system_default_language_id now from HKLM\System\CurrentControlset\Control\Nls\Language','InstallLanguage', fixes #113
* wimain: StartProgramModes: No interactive message if no connection to service, fixes #117
* wiglob: DependentAdd: possibility to abort trace mode, fixes #129
* widatamodul: getOpsiServerVersion: avoid check for serverversion 3 if we get a 'HTTP/1.1 401 Unauthorized' at the first try
* wisynth: No registry redirection for win2k even at /64Bit /Sysnative (win2k can't handle this), fixes #197
* widata: TOpsiMethodCall.getJsonUrlString : String quoted if not in {} (a JSON Object), fixes #198
* wispecfolder: get folder locations now from API instead from Registry
* new constants: %CommonStartmenuDir% ,%CommonDesktopDir%, %CommonStartupDir%, %CommonProgramsDir%, %AppDataDir%, %StartmenuDir%, %DesktopDir%, %StartupDir%, %ProgramsDir%, %SendToDir%, fixes #175
-- Detlef Oertel <d.oertel@uib.de> Tue, 3 Dec 2010:17:00:00 +0200
opsi-winst (4.10.8.10-1) stable; urgency=low
* bugfix: progress was not set on running setup script. fixed in widatamodul:TOpsi4Data.setProductState
* new function: TOpsi4Data.setProductProgress (myprogres : String);
-- Detlef Oertel <d.oertel@uib.de> Tue, 25 Nov 2010:17:00:00 +0200
opsi-winst (4.10.8.9-1) stable; urgency=low
(4.10.8.9a)
* bugfix: at getOpsiServerVersion: if not opsi 4, try to ask opsi3 server
* cleanup: Topsi4data: remove not used functions
(4.10.8.9b)
* uJson removed and replaced by superobject
(4.10.8.9c)
* TJsonThroughHTTPS.retrieveJSONObjectByHttpPost uses at opsi4 compressed stream (sendlog) (part of #114)
* TJsonThroughHTTPS.retrieveJSONObject uses at opsi4 compressed streams
* TJsonThroughHTTPS.retrieveJSONArray uses at opsi4 compressed streams
-- Detlef Oertel <d.oertel@uib.de> Tue, 9 Nov 2010:17:00:00 +0200
opsi-winst (4.10.8.8-1) stable; urgency=low
* bugfix: at getOpsiServerVersion reduce errorcounter by 1 if not opsi 4 (bugfix silent installation)
-- Detlef Oertel <d.oertel@uib.de> Wed, 26 Okt 2010:17:00:00 +0200
Dear opsi user,
in testing there is a new opsi-client-agent package:
http://download.uib.de/opsi4.0/testing/ ... .0-13.opsi
Significant Changes:
- Improved deinstallation scrips
- Bugfixes in opsiclientd
- Include all known depots as "trusted share"
regards
The changelog:
opsi-client-agent (4.0-13) testing; urgency=low
* bugfixes in register all known depots as trusted:
* also use hostname (netbiosnames)
* try to authenticate at the webservice if in bootimage mode
-- Detlef Oertel <d.oertel@uib.de> Thu, 27 Jan 2011 19:00:00 +0100
opsi-client-agent (4.0-12) testing; urgency=low
* opsigina.dll 1.3
- prevent gina chain loop (NextGina = opsigina.dll)
- read config from HKLM\Software\opsi.org\opsi-client-agent with fallback to ..\preloginloader
* opsiclientd 4.0.25: Close socket in HTTP
* make/delete Registry settings at HKLM\Software\opsi.org\opsi-client-agent (and preloginloader)
* workaround for bug #197 removed
* make/delete and lock new directory $OCD_OpsiVarDir$ (c:\opsi.org) for caching, logging, etc
* setup.ins: Aborts with interactive message if copy fails
* kills notifier.exe on uninstall
* uninstall: fallback to deactivation if first gina is not a well known opsi gina
* new product property: on_uninstall , possible values: deactivation, uninstall
* ask for all known depots and set register them all as trusted
-- Jan Schneider <j.schneider@uib.de> Tue, 11 Jan 2011 20:16:00 +0100
