Dear opsi-users
we publish some new server-packets:
As stable:
- opsi-configed (4.0.1.2-1)
- opsi-linux-bootimage (20101203-1)
- opsi-utils (4.0.0.5-1)
- opsiconfd (4.0.0.3-1)
- python-opsi (4.0.0.18-1)
As testing:
(http://download.opensuse.org/repositori ... 40-testing)
you will find
- opsi-depotserver_4.0-5
- opsi-configed (4.0.1.4-1)
opsi-products:
As stable:
opsi-adminutils 4.0.1.2
As testing:
- opsi-winst 4.10.8.12
- opsi-winst-test 4.0-1 (One script that calls (almost) all winst-functions)
The pakets contain some bugfixes and some new features.
Here the detailed changelogs:
opsi-configed (4.0.1.4-2) testing; urgency=low
* optimization of first call of license management
-- Rupert Roeder <r.roeder@uib.de> Wed, 12 Dec 2010 12:07:20 +0100
opsi-configed (4.0.1.3-1) testing; urgency=low
* depot values page added
-- Rupert Roeder <r.roeder@uib.de> Wed, 11 Dec 2010 12:07:20 +0100
opsi-configed (4.0.1.2-1) testing; urgency=low
* asks for username/password
-- Rupert Roeder <r.roeder@uib.de> Tue, 30 Nov 2010 12:07:20 +0100
opsi-depotserver (4.0-5) stable; urgency=low
* fix spec file
-- Jan Schneider <j.schneider@uib.de> Thu, 02 Dec 2010 20:11:13 +0100
opsi-depotserver (4.0-4) stable; urgency=low
* Add config clientconfig.depot.protocol
-- Jan Schneider <j.schneider@uib.de> Thu, 02 Dec 2010 12:06:03 +0100
opsi-linux-bootimage (20101203-1) stable; urgency=low
* master.py 4.0.0.1: honor clientconfig.depot.protocol
* python-opsi 4.0.0.18-1
* french keyboard
-- Jan Schneider <j.schneider@uib.de> Fri, 03 Dec 2010 08:16:01 +0100
opsi-linux-bootimage (20101129-1) stable; urgency=low
* kernel 2.6.36.1
* python-opsi 4.0.0.15-1
* master.py: reset network devices
-- Jan Schneider <j.schneider@uib.de> Mon, 29 Nov 2010 17:44:50 +0100
opsi-linux-bootimage (20101117-1) stable; urgency=low
* kernel config CONFIG_PCI_MSI=y
* python-opsi 4.0.0.10-1
-- Jan Schneider <j.schneider@uib.de> Wed, 17 Nov 2010 18:18:50 +0100
opsi-linux-bootimage (20101022-1) stable; urgency=low
* kernel 2.6.36
* python-opsi 4.0.0.9-1
-- Jan Schneider <j.schneider@uib.de> Fri, 22 Oct 2010 12:28:55 +0200
opsi-utils (4.0.0.5-1) stable; urgency=low
* opsi-makeproductfile 4.0.0.2: Use ZsynFile from OPSI.Util.File
* opsi-product-updater 1.0.4: Use ZsynFile from OPSI.Util.File
-- Jan Schneider <j.schneider@uib.de> Wed, 01 Dec 2010 14:31:00 +0100
opsi-utils (4.0.0.4-1) stable; urgency=low
* opsi-product-updater 1.0.3
- fix setting of action for shutdownProduct
-- Jan Schneider <j.schneider@uib.de> Tue, 30 Nov 2010 17:03:24 +0100
opsi-utils (4.0.0.3-1) stable; urgency=low
* opsi-product-updater 1.0.2
- http_proxy for zsync
-- Jan Schneider <j.schneider@uib.de> Fri, 19 Nov 2010 13:31:43 +0100
opsiconfd (4.0.0.3-1) stable; urgency=low
* forceHostId fqdn
-- Jan Schneider <j.schneider@uib.de> Tue, 23 Nov 2010 12:21:54 +0100
opsiconfd (4.0.0.2-2) stable; urgency=low
* Fix postinst script for ucs
-- Jan Schneider <j.schneider@uib.de> Mon, 22 Nov 2010 09:43:38 +0100
python-opsi (4.0.0.18-1) stable; urgency=low
* Util: objectToHtml() Escape &
* Backend/Backend: reimplemented configState_getClientToDepotserver
-- Jan Schneider <j.schneider@uib.de> Thu, 02 Dec 2010 15:29:10 +0100
python-opsi (4.0.0.17-1) stable; urgency=low
* Util/File: ZsyncFile
-- Jan Schneider <j.schneider@uib.de> Wed, 01 Dec 2010 14:30:18 +0100
python-opsi (4.0.0.16-1) testing; urgency=low
* Fix LDAP.py: Don't delete HostObject on ucs-Servers, if
deleteCommand is not set.
-- Erol Ueluekmen <e.ueluekmen@uib.de> Tue, 30 Nov 2010 13:33:26 +0000
python-opsi (4.0.0.15-2) stable; urgency=low
* new package version for build service
-- Jan Schneider <j.schneider@uib.de> Mon, 29 Nov 2010 18:08:50 +0100
python-opsi (4.0.0.15-1) stable; urgency=low
* Move method getDepotSelectionAlgorithm into new config file
70_dynamic_depot.conf
* Backend/Backend: Fix _objectHashMatches for version numbers
* System/Posix: Fix getBlockDeviceContollerInfo for device/vendor ids
with len < 4
-- Jan Schneider <j.schneider@uib.de> Mon, 29 Nov 2010 17:04:37 +0100
python-opsi (4.0.0.14-1) stable; urgency=low
* Util/Repository: fix upload
-- Jan Schneider <j.schneider@uib.de> Thu, 25 Nov 2010 15:09:27 +0100
python-opsi (4.0.0.13-1) stable; urgency=low
* Backend/JSONRPC: fix username/password kwargs
-- Jan Schneider <j.schneider@uib.de> Wed, 24 Nov 2010 09:09:57 +0100
python-opsi (4.0.0.12-1) stable; urgency=low
* Util/HTTP
- change default to not reuse HTTP connection in pool
- fix urlsplit
* Util/Repository: retry upload
* Backend/Backend: fix key error in _productOnClient_processWithFunction
-- Jan Schneider <j.schneider@uib.de> Tue, 23 Nov 2010 12:16:39 +0100
opsi-adminutils (4.0.1.2-1) stable; urgency=low
* opsi-configed 4.0.1.2 (29.11.2010)
- detlef oertel <d.oertel@uib.de> 06 Dec 2010
opsi-adminutils (4.0.1.1-2) stable; urgency=low
* changed form -Xmx256m -jar parameters: -Xmx512m -jar
- Bardo Wolf <b.wolf@uib.de> 6 Dec 2010
opsi-winst (4.10.8.12) stable; urgency=low
* new constants: %CurrentAppDataDir%, %ScriptDir%,
%CommonProfileDir%,
* constant names changed: %StartmenuDir% -> %CurrentStartmenuDir%,
%DesktopDir% -> %CurrentDesktopDir%,
%StartupDir% -> %CurrentStartupDir%,
%ProgramsDir% -> %CurrentProgramsDir%,
%SendToDir% -> %CurrentSendToDir%
-- Detlef Oertel <d.oertel@uib.de> Fri, 10 Dec 2010:17:00:00 +0200
opsi-winst (4.10.8.11-1) stable; urgency=low
* wimemo: window in screen center, larger font, no more autosize
-> for showmessagefile, fixes #184
* wisynth: product / version at the end of the log , fixes #110
* wimain: ProcessNonZeroScript: logmessage 'no script file name
given' now LLNotice instead of warning
* wisynth: getLocaleInfoMap: system_default_language_id now from
HKLM\System\CurrentControlset\Control\Nls\Language','InstallLanguage',
fixes #113
* wimain: StartProgramModes: No interactive message if no
connection to service, fixes #117
* wiglob: DependentAdd: possibility to abort trace mode, fixes #129
* widatamodul: getOpsiServerVersion: avoid check for
serverversion 3 if we get a 'HTTP/1.1 401 Unauthorized' at the first try
* wisynth: No registry redirection for win2k even at /64Bit
/Sysnative (win2k can't handle this), fixes #197
* widata: TOpsiMethodCall.getJsonUrlString : String quoted if
not in {} (a JSON Object), fixes #198
* wispecfolder: get folder locations now from API instead from
Registry
* new constants: %CommonStartmenuDir% ,%CommonDesktopDir%,
%CommonStartupDir%, %CommonProgramsDir%, %AppDataDir%, %StartmenuDir%,
%DesktopDir%, %StartupDir%, %ProgramsDir%, %SendToDir%, fixes #175
-- Detlef Oertel <d.oertel@uib.de> Tue, 3 Dec 2010:17:00:00 +0200
opsi-winst (4.10.8.10-1) stable; urgency=low
* bugfix: progress was not set on running setup script. fixed in
widatamodul:TOpsi4Data.setProductState
* new function: TOpsi4Data.setProductProgress (myprogres : String);
-- Detlef Oertel <d.oertel@uib.de> Tue, 25 Nov 2010:17:00:00 +0200
opsi-winst (4.10.8.9-1) stable; urgency=low
(4.10.8.9a)
* bugfix: at getOpsiServerVersion: if not opsi 4, try to ask
opsi3 server
* cleanup: Topsi4data: remove not used functions
(4.10.8.9b)
* uJson removed and replaced by superobject
(4.10.8.9c)
* TJsonThroughHTTPS.retrieveJSONObjectByHttpPost uses at opsi4
compressed stream (sendlog) (part of #114)
* TJsonThroughHTTPS.retrieveJSONObject uses at opsi4 compressed
streams
* TJsonThroughHTTPS.retrieveJSONArray uses at opsi4 compressed
streams
-- Detlef Oertel <d.oertel@uib.de> Tue, 9 Nov 2010:17:00:00 +0200
opsi-winst (4.10.8.8-1) stable; urgency=low
* bugfix: at getOpsiServerVersion reduce errorcounter by 1 if
not opsi 4 (bugfix silent installation)
-- Detlef Oertel <d.oertel@uib.de> Wed, 26 Okt 2010:17:00:00 +0200
Regards
Birgit Hubal
