Updates for opsi 4.1 in stable
Dear opsi-users,
today we released the new opsi-client-agent version 4.1.1.16-2 and opsi-linux-client-agent version 4.1.1.6-1 for opsi 4.1 in Stable.
The main changes in opsi-client-agent are:
  • opsiclientd was updated to 4.2.0.47
  • Fixed logging problems of opsi-deploy-client-agent with opsi 4.1
  • The opsiclientd binaries are now included as an zip-archive.
  • Vcredist-2015 installation does not trigger a reboot.
  • If an error occurs while moving the opsiclientd binary dir during installation, the directory is copied instead.
  • Opsiclientd kiosk api can be deactivated completly by setting config opsiclientd.control_server.kiosk_api_active = false
  • Obsolete configuration options are removed from opsiclientd.conf automatically.
  • The caching mechanisms in WAN/VPN extension are more fault tolerant.
The main changes in opsi-linux-client-agent are:
  • opsi-deploy-client-agent supports deployment via ip address instead of a hostname.
  • An error of opsi-deploy-client-agent in combination with non-root users whas been fixed.
  • An installation error on UCS 4.4 has been fixed.
Best regards,
